Old Feb 27, 2012, 03:36 PM
Joined Feb 2012
Dimensions on EDF Micro 40mm ducted fan
Hey I'm working on a project for a professor at UC Riverside. We have come across these fans and need some dimensions. If any of you have bought one of these before I would appreciate a few measurements. The part is Micro 40mm EDF,including the unique 8-blade fan rotor and ducted housing, which can be found on http://www.nitroplanes.com/88e-adf40-housing.html. I have tried contacting the company but have failed. I am looking for the inner and outer diameter of the central hole through the housing component and the diameter of the center piece of the fan.
Thank you
mlefo is offline Find More Posts by mlefo
Old Feb 27, 2012, 03:40 PM
Flying Dutchman!
robertboxhoorn's Avatar
Nederland, FL, Emmeloord
Joined Sep 2011
why don't you just buy it? 10 buck's what is that
robertboxhoorn is offline Find More Posts by robertboxhoorn
Old Feb 27, 2012, 03:47 PM
Joined Feb 2012
I need it 5 of them by or a different fan by friday. just kinda of stretched for time and thought i could get a quick answer here. It seems right now i might just buy them and hope they are right.
Old Feb 27, 2012, 05:26 PM
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
If you want a good 40mm fan, get the GWS unit. Much better build and quality.
GWS 40mm fan dimensions.
It comes in two versions, one suitable for a 12mm motor and another using a 20mm motor.
Slaanesh is offline Find More Posts by Slaanesh
Old Feb 28, 2012, 01:55 PM
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
http://www.rcgroups.com/forums/showthread.php?t=1366846
Joe 1320 is offline Find More Posts by Joe 1320
Wanted Axon Micro F4 Phantom II 30mm/40mm EDF Jet John Boy Aircraft - Electric - Jets (FS/W) 0 Jan 23, 2012 09:31 PM
Wanted EDF 40mm Ducted Fans ronzer Aircraft - General - Miscellaneous (FS/W) 0 Aug 03, 2011 08:21 PM
Sold Delta-V (R) 32 80mm EDF and BL32 Ducted Fan Motor, 2150Kv New in box beachflyer Aircraft - Electric - Jets (FS/W) 1 Jul 17, 2011 12:08 PM
For Sale BL15 Ducted Fan Motor, 3200Kv and EDF unit tconners Aircraft - Electric - Power Systems (FS/W) 1 Mar 28, 2011 11:08 PM
Discussion Micro ducted fan with jet scream edf on an a10 LexusIS300 Indoor and Micro Models 13 Feb 13, 2009 01:41 PM
