Old Feb 27, 2012, 03:25 PM
C206 is offline
Find More Posts by C206
Kingdom of Sweden, Stockholm County, Stockholm
Joined Mar 2010
E-flite 90 and 105 nose retract
Hi
I have an e-flite 25-46 nose retract with 90 degree retraction (EFLG30190). I have realized I need 105 degrees retraction. E-flite have this type retract, but a little bit too costy when I already have bought the 90 retract.
http://www.e-fliterc.com/Products/De...odID=EFLG31190
http://www.e-fliterc.com/Products/De...dID=EFLG311105
Is it possible to modify the retract I have, by i.e. changing the trunnion?
Thanks for all input
C206 is offline Find More Posts by C206
Old Jul 17, 2012, 10:35 PM
Tartago is offline
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
Originally Posted by C206 View Post
Hi
Check on the Do-335 thread, I saw something there.
Tartago is offline Find More Posts by Tartago
Old Jul 18, 2012, 03:49 PM
Cougar429 is offline
Find More Posts by Cougar429
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
If you look closely between the two units, it appears the carrier travels further in a longer notch in the side plates to give you a greater sweep angle. That means the control board would also be longer to have the switches further apart.
The trunnion should be identical between the two units, with the side plates and control board likely the main differences, (on my units there is more than enough length to the drive screw to cover that difference). That comprises a good percentage of the total retract mech, so it would seem wiser to simply sell the one you have and grab the correct unit for your app.
Cougar429 is offline Find More Posts by Cougar429
Sold E-flite 10-15 electric nose retract brand new wyldkrd Aircraft - General - Miscellaneous (FS/W) 0 Mar 06, 2011 10:45 AM
Sold NEW Set Tri Air Retract / Spring Down System w/ 105 Degree Nose Retract $110 Shipped FlyBoyTha1 Aircraft - General - Miscellaneous (FS/W) 0 Feb 23, 2011 01:44 PM
Sold NEW Set Tri Air Retract / Spring Down System w/ 105 Degree Nose Retract $100 Shipped FlyBoyTha1 Aircraft - Fuel - Airplanes (FS/W) 0 Feb 23, 2011 01:07 PM
Sold NEW Set Tri Air Retract / Spring Down System w/ 105 Degree Nose Retract $100 Shipped FlyBoyTha1 Aircraft - Electric - Airplanes (FS/W) 0 Feb 23, 2011 01:05 PM
Sold NEW Set Tri Air Retract / Spring Down System w/ 105 Degree Nose Retract $100 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 0 Feb 23, 2011 01:01 PM
