Old Feb 27, 2012, 01:46 PM
brandonwilcox is offline
Find More Posts by brandonwilcox
brandonwilcox's Avatar
CT
Joined Sep 2008
Cool
New! MaxAmps.com LiPo Battery Tester and Low Voltage Alarm
Spokane, WA MaxAmps.com is pleased is introduce the smallest and lightest Low Voltage Alarm on the market. Prolong your battery life by not allowing the voltage on your LiPo pack to drop too low. This unit plugs directly into the JST-XH style balancing tap on your battery pack during discharge and notifies you when to stop running the pack. It can also be used to check the status of your battery at any time. This Low Voltage Alarm (LVA) measures 40mm x 25mm x 11mm and weighs only 5 grams. Do NOT leave the unit plugged into your pack while not in use.
Can be used for a LiPo 3.7v (1-cell pack) up to a 29.6v (8-cell pack).
Voltage detection precision of 0.01v
Red LED will flash when a cell drops below programmed voltage setting (default is 3.3 volts but this can easily be changed to your preference).
A loud audible alarm will also sound when a cell drops below programmed voltage setting. This is your indication to stop your vehicle in order to prevent over-discharging your LiPo battery pack.
Unplug your battery pack from the speed control (ESC) and unplug the LVA from the battery pack.
brandonwilcox is offline Find More Posts by brandonwilcox
Site Sponsor
Old Feb 27, 2012, 02:40 PM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
This is a great device, I have one and love it. However the MaxAmps price of $19.99 is very high. They can be had for as low as $5.00 plus shipping from several sources.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Feb 27, 2012, 02:51 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Yep.
http://www.ebay.de/itm/1-8S-Lipo-Bat...item41630c4c41
I got two of those, they work great and are really loud.
Julez is offline Find More Posts by Julez
Old Mar 12, 2012, 06:06 PM
robin7278 is offline
Find More Posts by robin7278
United States, GA, Acworth
Joined Feb 2012
do you know how to hook this up or what to hookit to thanks
8S Lipo Battery Tester Checker Low Voltage Buzzer Alarm
robin7278 is offline Find More Posts by robin7278
Old Mar 12, 2012, 08:37 PM
USA, GA, Marietta
Joined Aug 2005
It connects to the balance connector of any two to 8 cell LiPo. It won't work with Thunder Power batteries because the Thunder Power pin spacing is to narrow.
Glen
Old May 14, 2012, 01:59 AM
Kittyhobby is offline
Find More Posts by Kittyhobby
Joined Jun 2011
One question: on the lipo checker/alarm, how can i set the voltage for the alarm?
I see the button, and have tried pressing it in different ways, but i must not be doing it right.
Belinda
Kittyhobby is offline Find More Posts by Kittyhobby
Reply With Quote  (Disabled)
Old May 14, 2012, 02:13 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Plug the alarm in and just tap the button. Every time you tap it it will move through OFF, 2.7, 2.8.....3.8V in 0.1V steps. Stop when you reach the alarm voltage you want.
Belinda
jj604 is online now Find More Posts by jj604
Old May 14, 2012, 01:16 PM
barry wilson is offline
Find More Posts by barry wilson
amherst,nova scotia,canada
Joined Nov 2003
If you do not require the meter reading there are two versions available from hobbyking at less than 2.00 each. One is for two and three cell batteries and one for two to four cell batteries.
Mine are on order so I do not know if the warning voltage setpoint can be altered. They also have leds on board as well. Quiite loud it is reported of the audiable warning. Stil far better than nothing or guessing I believe.
Just checked their site. Warning point is 3.3v for any cell and this means it is not adjustable on that one at least. They are listed under battery accessories.
barry wilson is offline Find More Posts by barry wilson
Old May 14, 2012, 06:34 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Barry, that is why the alarm featured in this thread is so attractive.
It is adjustable and very easy to set. (It is also very loud)
IMO 3.3V is too low these days for LiPo cut off. Particularly if you aren't drawing high C rate, then a modern battery with a very flat discharge curve is totally exhausted by the time it reaches 3.3V.
Just be aware that some of the $2 alarms are not very accurate, this one seems pretty good.
You can never be sure with small Chinese electronics which seem to get copied all over the place but the ones I bought for $3.50 including the postage from HK seem identical and work perfectly.
http://www.ebay.com.au/itm/1-8S-Lipo...ht_2467wt_1141
John
Old May 14, 2012, 10:56 PM
Joined Nov 2003
John
Thanks for the source information. I and a few others will probably order one. well me for certain anyways. The price is right I see as well.
Sold 1S - 8S Votage Meter and LiPo Low Voltage Alarm Dave8888 Aircraft - Electric - Batteries & Chargers (FS/W) 3 Feb 02, 2012 02:24 PM
Discussion 1s lipo led low voltage alarm scheme otoman Power Systems 0 Jan 09, 2012 09:14 AM
Discussion 2 in1 Lipo Battery Voltage Tester Low Voltage Alarm New 4stripes Foamy EDFs 2 Jun 20, 2011 05:07 PM
Discussion On-board low voltage battery alarm question---again Barbosa2 DIY Electronics 3 May 29, 2011 06:27 PM
