Old Feb 04, 2013, 06:09 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Originally Posted by Ducati Mechanic View Post
Hone1er is the best pilot here, take his advice.
He may be the best flyer but does Hone1er even have a Laser? (This being the Laser thread last time I checked). I also have less mix % on my Edge EXP, but why would anyone take set up advise based on an Edge in preference to the set up advise based on experience of the actual plane in question? Different planes have slightly different charecteristics and so often require different set up, even when the planes come from the same manufacturer.
I do slightly resent the implication that I dont know how to set up a mix. I dont think you need to be an expert flyer to know what mixes a plane needs, in fact you could argue the opposite. As an average flyer I need all the help I can get so I always take time to dial in the mixes as accurate as I can. For those with more skill perhaps they can fly round it and tht's fine if that's how you like it.
I dont see having a bit of mix as a negative thing, the Laser is superb in KE, it's one of it's strengths.
Steve
PS.. Hone1er.. not having a go at you in any way here, your post based of your experience of other models was very interesting.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Feb 04, 2013, 06:16 AM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Yeah,
13% mix indicates either a bad CG. When I say Wonky EXP, I mean you did something wrong in the build process or you have some warped wings or ailerons.
90% sure your CG is off.
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
Old Feb 04, 2013, 06:28 AM
Aberdeen
Joined Mar 2006
Originally Posted by Dead View Post
Yeah,
CG doent have much in any effect on the rudder to aileron mix in my experience (it has lots of effect on the rudder to elevator but that's a different issue).
The % of mix is much effected by how much control throw you have set in the firstplace and also I think how you have achieved that throw, be it long servo arms, increased end points etc.
For instance if flyer A has 80 degrees of elevator travel (dialed down with rates) and flyer B has 40 degrees (dialed up with increased endpoints on rates). Then flyer B will need twice the % of rudder to elevator mix compared to flyer A in order to achieve the exact same control surface deflection
So just going by % is pretty much meaningless.
Old Feb 04, 2013, 06:39 AM
They Call him Dead!
Joined Jul 2003
Interesting and enlightening info. Also, I just noticed that you said 13% mix on a Slick, not EXP. I know nothing of a Slick.
Old Feb 04, 2013, 06:46 AM
Aberdeen
Joined Mar 2006
It wasnt me that mentioned the Slick, though i do have one (51"). I honestly cant recall what % I have on my Slick but I dont think it's very much.
Old Feb 04, 2013, 09:07 AM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Originally Posted by rimaarts View Post
actually last time out i realised that laser looks sooooo much like slick... take off canopy, a tad different cowl, a bit more oval instead of round fuselage and would turn out nearly slick.... cant wait for next non-windy day to fly laser more... last time took my time and started mixing KE.... and it took whooping 13% rudder to aeleron...???
Something is very wrong with your set up if you needed 13% mix!!
most of us fly with zero mix, and this plane shouldn't need any more than one or 2%.. I would dial in the CG,and start again. I've been working on the KE snake(almost perfect!), and I have zero mix.
There was a guy in here, that needed 8% in one direction. that would be due to a bent(or tweaked) plane.
Biplanes usually have around 8- 11%+, And they seem to be the worst with mixing Due to the drag of the upper wing, But a symmetrical plane like the laser. should never need more than one or 2%
Yeah,
Point.., And yes we're talking EXP's
Don't you just Love when you're trying to help a guy with his setup, and some other guy with a bad set up gets insulted, and Insists he's correct? This ladies and gentlemen is why you see all the best pilots shying away from these threads. No one wants to spend their valuable time arguing over someone's hurt feelings, when they're just trying to pass on some helpful information.
The one thing I can tell you for sure is that all of my EXP's fly straight as an arrow with zero mix, when I do mix one its never more than 2%.
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Feb 04, 2013, 09:22 AM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
It's clearly a thrust issue.
Doc Austin is offline Find More Posts by Doc Austin
Old Feb 04, 2013, 09:23 AM
Joined Oct 2008
I would just slam a bunch of washers under the motor mount..
Old Feb 04, 2013, 09:54 AM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
Well, i have no problem keeping ke on laser, slick or edge mix free... I just played so just by keeping rudder i could ke 100m without falling out... And did not finish it... I was just surprised (as i mentioned after maiden) that laser is only ef plane wich i feel the need of mixing....
rimaarts is offline Find More Posts by rimaarts
Old Feb 04, 2013, 11:05 AM
Joined Oct 2008
As long as it works for you. It's just Interesting that you're having that problem with only one of your EXP's?. In general, It Doesn't seem to be a issue, I know I've seen the pro pilots talk about very low numbers with their mixing also. like dead mentioned, maybe something "tweaked" I would take a closer look at the airframe.
Old Feb 04, 2013, 12:27 PM
Aberdeen
Joined Mar 2006
Ducati Mechanic is right, anyone with differing views is wrong... I get it
Old Feb 04, 2013, 10:22 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Don't remember anything about this footage. Completely uncut it's the exact length of an old favorite song, so I put it all together for our UTube viewers.
Laser EXP__Uncut (5 min 9 sec)
Old Feb 05, 2013, 07:10 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Hey Rim, what kind of trim are you running for upright, level flight on your laser? Are both ailerons straigt and not warped? Also are you running a flight pack or big esc one one side of the plane or more in the middle. ( these questions aside, I got no qualms with mixes, if it makes the plane fly like you want, mix the beeitch. ) But, sometimes you can tweak the airframe to lessen the need to with cg, lateral balance, general adjustments. These tweaks and adjustments are part of the hobby that I love. You know scale pilots change the trim on their planes for load, and general flight also sometimes on each flight. No reason we shlnt have to cha ge trim or even mixes sometimes. Just part of the fun.
Manta1 is offline Find More Posts by Manta1
Old Feb 05, 2013, 02:17 PM
A Monell is offline
Find More Posts by A Monell
Gloucester Ma
Joined Dec 2002
New to EXPs
I just got a Laser to replace my Sebart Katana 30e that I lost last week.
I was wondering about servos I see some going to Hitec 85mg ones for elevator and wondered why no-one seems to use the Hitec 82mg as it is a little closer to the specified 65s. Also I have one of these, http://www.hobbyking.com/hobbyking/s...06sec_21g.html I might try, would this be overkill? I'm just worried there might be a trade off in resolution to get this to be so quick. The most important thing for me I think on elevator would be consistent centering. Any thoughts?
Alex
A Monell is offline Find More Posts by A Monell
Old Feb 05, 2013, 02:37 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Sorry to hear about your Katana, but airframe technology has come so fdar since that plane that you will be shocked at how good the Laser really is.
The 81s and 82s have a bad reputation for poor centering and reliability. The HS85MGs have enough torque, center fine and are nearly bullet proof.
However, the plane is set up for HS65MGs, and as long as you run an Airboss 45 ESC or a 6 volt bec, those will be fine.
That, and reliability. I like the 85s for that, but again the plain old HS65MG is fine. I ran those all the way around on my first Laser.
Wanted Extreme flight 48 inch Extra EXP parts knifeedge63 Aircraft - Electric - Airplanes (FS/W) 5 Jun 23, 2014 11:10 PM
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Alert For sale Extreme flight 48 inch edge exp rtf cheap rudyhal Atlanta Area RC 7 May 28, 2011 12:32 PM
Sold Extreme Flight Extra EXP 48 inch w/ Airboss45 ESC- Torque2814/820 combo (Austin, TX) HKC3 Aircraft - Electric - Airplanes (FS/W) 17 Feb 05, 2011 10:49 PM
