Old Jan 03, 2013, 06:52 PM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Originally Posted by RCPilot1234 View Post
It was amazing how much of a difference Du-Bro hinge tape made to my MXS ailerons............Although maybe using monokote stuff is even better?
I use clear monokote. It ends up being invidible and lasts for the lifetime of the plane. Lately I have even been sealing the rudders too. I'm looking for any little advantage I can get to make the plane fly better and i think it helps.
Doc Austin is offline Find More Posts by Doc Austin
Old Jan 03, 2013, 06:57 PM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
Will try Monokote next time Every performance boost is essential, especially when us 3D pilots push these tiny 10g servos to the limit, haha!
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Jan 08, 2013, 04:50 PM
Trill is online now
Find More Posts by Trill
Trill's Avatar
United States, TN, Murfreesboro
Joined Oct 2008
60" Laser
What are the color schemes for the 60" Laser?
After reading Doc's comparison of the 48" EXP airframes, I think the Laser suits my flying style best.
Trill is online now Find More Posts by Trill
Old Jan 08, 2013, 06:10 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
I know it will have the red scheme from the 48'' but there is supposed to be a second scheme too i believe
hone1er is offline Find More Posts by hone1er
Old Jan 13, 2013, 08:47 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Here's an odd tidbit. I tore up the left wing on my Laser awhile back, so I put a new one on it. I took the servo, arm, and pushrod with both ball links straight out of the old wing and dropped it into the new one. I did not have to touch the trims, sub trims or even turn a ball link. The aileron was perfectly centered by making zero adjustments of any kind. I flew it today and never touched the tims.
Old Jan 14, 2013, 08:38 AM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
People don't realize how good they have it these days. Models are relatively straight and true compared to back in the day.
stgdz is offline Find More Posts by stgdz
Old Jan 14, 2013, 08:40 AM
_OZ_ is offline
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
I had the same experience on my 48 Edge.
_OZ_ is offline Find More Posts by _OZ_
Old Jan 14, 2013, 02:54 PM
wyo69cowboy is offline
Find More Posts by wyo69cowboy
USA, WY, Cody
Any word on a release date for the 60" Laser?
wyo69cowboy is offline Find More Posts by wyo69cowboy
Old Jan 14, 2013, 06:18 PM
killowatt is offline
Find More Posts by killowatt
ChangeBegins AtTheDinnerTable
killowatt's Avatar
Raleigh , N.C.
Joined Jun 2006
The Brown truck just backed down the drive and left one of these on the porch ! My first E.F bird and it looks good . I have been looking over this thread for the last couple of days and wondering whats the magic motor/battery combo ?
killowatt is offline Find More Posts by killowatt
Old Jan 14, 2013, 06:23 PM
C_Watkins is offline
Find More Posts by C_Watkins
This is NOT a TOY?
C_Watkins's Avatar
United States, GA, Atlanta
Joined Jul 2011
The Torque/Airboss combo with a 12x6 prop and a 2200-2600mAh 4s.
C_Watkins is offline Find More Posts by C_Watkins
Old Jan 14, 2013, 09:31 PM
Trill is online now
Trill's Avatar
Joined Oct 2008
The first one was the best one!
OK, here's the first one, but remember that the wind was really horiffic. It was blowing 20-25 constant with 30-35mph gusts. I really had no business flying at all, but I wanted to get at least one video out before the weather went completely bad. Today it is even worse and it is supposed to storm all week.
Doc,
I enjoyed/learned from this video for two reasons:
1) Without music I can hear the motor sounds and commentary.
2) The 20+ mph winds are a challenge for me and you showed how to fly in gusty conditions.
Thanks and keep em coming without music!
Old Jan 14, 2013, 09:43 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I may have to start making more that way, espicially with the 60" planes. That 4016 has a really pretty whooosh sound..
Old Jan 15, 2013, 12:26 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Personally I'd go for a Motrolfly. Either the DM2820 (685 or 750kv for 4s, 950Kv for 3s), or if you really want to go nuts the DM3615 750Kv (light-weight)
The 3615 is a bit heavier than the standard motor so you would need to use it in conjunction with a battery at the smaller end of the range (2200mAh) to get the balance right. The laser tends a little toward nose heavy so it's best not to go too big on the battery in any case.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Jan 15, 2013, 06:18 AM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
+1!!
With cooling scoops, and a larger air inlet for the esc, I've been running a Xoar 13x6(wood! Not a apc).. The numbers are only a hair higher than a 12x6apc, and still very Acceptable. The performance gain is great, with a bit more air over the control surfaces. After six minutes of hard flying the motor, and ESC are warm to the touch, and my 65c Genace 2200 Packs Stay very cool..
Be warned! don't just throw a 13x6 prop on your plane and expected to be fine. I went with a Xoar because The numbers are more mild. I also monitored the heat range until the set up was PERFECT. Proper cooling is a must on these planes, when you start pushing the numbers!
These days all of my planes are baffled. from 48 inch, up to 78", A must in my opinion..
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Jan 15, 2013, 06:26 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
wow 3615=beast!! vroom. I love the 2820. Bad to the bone motor. Id go 2820-750-ish kv for 13x6.5 prop (if the plane likes that prop.my mxs and the edge did) Or 950 for stupid power on 12x6. Smaller prop tho so not sure on the alpha moves on that prop. Probly just fine. oh 4s
Manta1 is offline Find More Posts by Manta1
Wanted Extreme flight 48 inch Extra EXP parts knifeedge63 Aircraft - Electric - Airplanes (FS/W) 5 Jun 23, 2014 11:10 PM
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Alert For sale Extreme flight 48 inch edge exp rtf cheap rudyhal Atlanta Area RC 7 May 28, 2011 12:32 PM
Sold Extreme Flight Extra EXP 48 inch w/ Airboss45 ESC- Torque2814/820 combo (Austin, TX) HKC3 Aircraft - Electric - Airplanes (FS/W) 17 Feb 05, 2011 10:49 PM
