Old Dec 07, 2012, 01:41 PM
Irg is offline
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
I doubt if you would see much difference with the digi, despite people claiming they have greater holding power. give it a try if you want, but imo the 85mg is perfect. it's a very robust servo.
Irg is offline Find More Posts by Irg
Old Dec 07, 2012, 02:04 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Originally Posted by aerosheldon View Post
what about a 5065?
IMHO the best option is the Savox SH-0255. it's faster and has more torque than the HS-85MG, plus it's lighter and it fits the standard servo cut-outs, and it's digital, and's it got super high tech titanium gears (and it's cheaper!)
As with any digital you need to take axtra care with set up to prevent binding/stalling but I've found then to be 100% reliable.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Dec 07, 2012, 02:07 PM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
I really want to try some MKS DS95's in one of these.
cwojcik is offline Find More Posts by cwojcik
Old Dec 07, 2012, 02:28 PM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
me too but a) wouldnt it be too long to fit in aelerons? b)wouldnt rudder benefit with a tad more torque vs more speed?
rimaarts is offline Find More Posts by rimaarts
Old Dec 07, 2012, 02:42 PM
blaiss is offline
Find More Posts by blaiss
Team Hillbilly
blaiss's Avatar
United States, OH, New Albany
Joined Jun 2006
Originally Posted by bryansifsof44 View Post
For sure it will way more powerful... What voltage were you running to the 65mg?
It's getting 6 volts.
blaiss is offline Find More Posts by blaiss
Old Dec 07, 2012, 02:45 PM
blaiss is offline
Team Hillbilly
blaiss's Avatar
Joined Jun 2006
Sounds like it's worth a try!
Old Dec 07, 2012, 04:44 PM
exeter_acres is offline
Find More Posts by exeter_acres
Extreme Flight Tech Support
exeter_acres's Avatar
Johns Creek, GA
Joined Jan 2005
I know I have mentioned in the past.. but I have been using Futaba S3156. Fits in the stock holes.. quick and holds just fine
exeter_acres is offline Find More Posts by exeter_acres
Old Dec 07, 2012, 05:18 PM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Looks great man!!
+6 on The hs85mg!! I have three of them that I can't ware out! I finally took two of the old ones and put them in a 52" P47 jug.. Still going strong, with no twitch..
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Dec 07, 2012, 05:27 PM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
Hey buddy, absolutely the same here! I've got a lot of academic work over the next month but once all my exams are finished in mid Janurary (was going to buy two months ago but didn't have the time to build it to my proper standards so I'll wait to mid Jan. ). I'm buying one of these with the absolute best equipment: Kontronik ESC, Western Robotics BEC, Hacker A30-14L motor , Thunder Power 2250 4S 65C... and... Yes, four MKS DS95s . Whilst it will bring this plane to a near 700 (about $1100), I really want to kit this plane out super nice I'm just thinking whether it should be all DS95s or whether I should put an HS5085MG in the elevator. I remember SpaceBat giving a helpful reply on this saying it should be the 5085MG due to the moment and torque is a bit low on the DS95s on the elevator but they're considerably more powerful and faster than the 65MGs so it might be okay I don't know, I'll just have to wait and see I think though they will make the plane absolutely incredible! twice the speed, twice the torque, and more precise than the 65MGs should just be incredible! What do you think about the elevator?
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Dec 07, 2012, 07:45 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
Originally Posted by blaiss View Post
I'm flying an HS-65 on the elevator. The blowback is horrible as I can't do a wall even though I have loads of throw. It kinda looks like a wounded duck. I'm hoping the HS-85 fixes this.
you shoulda told me...ive got a couple savox 0255mg's sitting at home getting no use. they arent super quick, but they are very torqey
rcbirk21 is offline Find More Posts by rcbirk21
Old Dec 07, 2012, 08:33 PM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
I've had the 85 in two different EXP elevators with over 600 flights... That in itself tells you they are up for the task. Should probably send em in for service, but I figure why when they run just as good as new. They are still tight.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Dec 08, 2012, 10:30 AM
Aberdeen
Joined Mar 2006
I put my new Motrolfly DM-3615 750kv in my Laser today, figured it should have some nice punch with a Xoar 14x7. The main concern was ending up nose heavy, the 3615 (lightweight) with cross mount and prop driver comes in at 190g whereas the DM-2820 it replaced weighs 172g. I moved the ESC back into the fuselage to offset the added weight and that seams to have done the trick.
I put 5 batteries through it and it didn't disappoint, incredible punch out of the hover and the big prop really helps with post stall control. All in all a recommended motor option providing you aren't using a battery any heavier than about 260g, if you do you might end up a bit nose heavy.
Old Dec 08, 2012, 10:44 AM
blaiss is offline
Team Hillbilly
blaiss's Avatar
Joined Jun 2006
I've been wanting to try Savox. Guess I'm going to have to start a new project.
Old Dec 08, 2012, 10:50 AM
Aberdeen
Joined Mar 2006
No, at 0.13s they aren't super fast but they are just as fast as the HS-65MG and significantly faster than the pedestrian HS-85MG (0.16s).
If you want super fast the SH-0257 is the one, and it still has a lot more torque that the HS-65MG and much faster (0.09s vs 0.13s)
Old Dec 08, 2012, 11:45 AM
Aberdeen
Joined Mar 2006
Here's the Motrolfly DM-3615 bolted up to the laser.. fits just fine:
Wanted Extreme flight 48 inch Extra EXP parts knifeedge63 Aircraft - Electric - Airplanes (FS/W) 5 Jun 23, 2014 11:10 PM
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Alert For sale Extreme flight 48 inch edge exp rtf cheap rudyhal Atlanta Area RC 7 May 28, 2011 12:32 PM
Sold Extreme Flight Extra EXP 48 inch w/ Airboss45 ESC- Torque2814/820 combo (Austin, TX) HKC3 Aircraft - Electric - Airplanes (FS/W) 17 Feb 05, 2011 10:49 PM
