Old Sep 30, 2012, 09:12 PM
aerosheldon is offline
Find More Posts by aerosheldon
No one has more fun than me
aerosheldon's Avatar
United States, CO, Denver
Joined Sep 2003
Thanks guys... I will order one up. Will stick with 3S for now for weight and bigger prop. Plus I have the Thunder Power 65C 3S batts and don't want to buy any 4S packs! LOL
aerosheldon is offline Find More Posts by aerosheldon
Old Oct 01, 2012, 08:28 AM
flyinhigh025 is offline
Find More Posts by flyinhigh025
How can we stop winter?
flyinhigh025's Avatar
Frederick, CO
Joined Sep 2005
Get that Laser ordered! I have one with about 20 flights on it. I also had the Edge EXP and loved it. The Laser just feels to me like it's all around more refined.
-Jeff
flyinhigh025 is offline Find More Posts by flyinhigh025
Old Oct 01, 2012, 01:27 PM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
4s doesn't have to be heavier than 3s. In fact there is a sound argument that for equal power the 4s will be lighter because amps will be lower so ESC can be smaller.
Anyway.... I'm sure your 3s set up will fly the Laser fine but it's a plane that comes into it's own in high energy manoeuvres (like the Doc's videos show) so I think you will be missing out if you fly only on 3s. After all the Laser was designed from the ground up for 4s.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Oct 01, 2012, 01:44 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Its all about efficiency Steve. The 5s 600kv 13x7 combos I have really are the ticket for the 48" airframes from EF.
I wonder if they can handle a 6s wind that spins the 13x7 to 9500rpm though. I could use a pair of my 1800 gensace for a 300g battery weight.
stgdz is offline Find More Posts by stgdz
Old Oct 01, 2012, 02:04 PM
morrigan is offline
Find More Posts by morrigan
morrigan's Avatar
Deutschland, BW, Ebersbach an der Fils
Joined May 2011
I changed my Setup from 3s to 4s on my EDGE. Like it more now. It is only 50g more weight, but i did Not recordnice it.
It is floaty as before.
The extra bunch of the 4s Setup give me a bettet feeling and the savety, i Know, i can get out of trouble.
I was always looking look on the weight, but it is Not worth on these airframes.
Bernd
morrigan is offline Find More Posts by morrigan
Old Oct 01, 2012, 02:46 PM
Aberdeen
Joined Mar 2006
I've previously used a 6s 480kv motor spinning a 14x7 (or 15x7) on the 51" Hobbyking Slick, which is only slightly larger and about 3oz heavier than a 48" EXP. This worked really well and was both super powerful, efficient and cool running. So 6s is definitely do-able on this size of model. Two 3s 1500-1600mAh in series would make for a really light but mega powerful set up on a 480-500kv motor spinning a 14x7. You could use a lightweight 40-50A ESC yet still pump out around 1kW of power at WOT
I'm not sure the advantage over 4s (or 5s) would be significant but it would be good for bragging rights
Old Oct 01, 2012, 03:31 PM
Joined Sep 2003
Ordered.
One more question--I was using all HS65's on my 48" plane that died in a Death Slide yesterday, but the aileron servos were HB's. I have two sets of MG gears laying here and could change them out---do you think that is needed for ailerons?
Old Oct 01, 2012, 03:52 PM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Ordered.
If you're ever going to fly it fast, certainly. Since you already have the gears on hand, why risk flting without them?
Doc Austin is offline Find More Posts by Doc Austin
Old Oct 01, 2012, 03:54 PM
Joined Sep 2003
true.... I will switch them out. I fly fast enough, I was attempting full throttle crankshafts with the 48 Edge last weekend.
Old Oct 01, 2012, 04:10 PM
Frederick, CO
Joined Sep 2005
On a sweet new plane like the Laser I would go MG all the way...
Old Oct 01, 2012, 04:11 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Sounds like you're not only an MG kind of guy, but I predict you'll go to 4s soon enough.
I don't remember if I posted this or not, and I am too lazy to check.
Old Oct 01, 2012, 07:25 PM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
What kind of flight time would this give relative to the stock, 4s setup?
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
Old Oct 01, 2012, 08:14 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
I believe he was geting around 9-10 minute flight times
Old Oct 01, 2012, 09:40 PM
They Call him Dead!
Joined Jul 2003
9 -10 minutes? On 6s 1600 Mah Lipos? Really? Is that flying 3D? I get 5.5 to 6 minutes on 4s 2500 Mah....
Old Oct 01, 2012, 09:52 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
same reason i get 7-9 mins (depending on prop type for my 13" props) on my 5s 2200 packs
Efficiency
Wanted Extreme flight 48 inch Extra EXP parts knifeedge63 Aircraft - Electric - Airplanes (FS/W) 5 Jun 23, 2014 11:10 PM
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Alert For sale Extreme flight 48 inch edge exp rtf cheap rudyhal Atlanta Area RC 7 May 28, 2011 12:32 PM
Sold Extreme Flight Extra EXP 48 inch w/ Airboss45 ESC- Torque2814/820 combo (Austin, TX) HKC3 Aircraft - Electric - Airplanes (FS/W) 17 Feb 05, 2011 10:49 PM
