Old Sep 22, 2012, 07:04 PM
C_Watkins is offline
Find More Posts by C_Watkins
This is NOT a TOY?
C_Watkins's Avatar
United States, GA, Atlanta
Joined Jul 2011
RPM's are the first thing I would check, given your other info.
You should see right at 10,200. If it's not even close, then you have a problem.
Adapters aren't a big deal if they are heavy enough to carry the current, and are kept as short as possible.
If your adapter is getting warm or hot... it is causing you to lose power.
If it's cooler than the wires on either side of it... then it's probably not causing you any issue.
C_Watkins is offline Find More Posts by C_Watkins
Old Sep 22, 2012, 07:28 PM
blaiss is offline
Find More Posts by blaiss
Team Hillbilly
blaiss's Avatar
United States, OH, New Albany
Joined Jun 2006
Neither the adapters or the batteries come down hot. The batteries are slightly warm. I made the adapters out of 12-gauge wire and about 3.5 inches long.
A quick check of the RPMs -- I am getting 9,500, which is what I was getting in the Edge. I'll check again tomorrow in better light.
I did notice a difference in the frontal area of the cowl. The edge was about 5.3 inches across whereas the Laser is more than 6.5 inches.
blaiss is offline Find More Posts by blaiss
Old Sep 23, 2012, 02:31 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Originally Posted by blaiss View Post
End points are set to automatic, which is also how it was set on the Edge.
You do appreciate that with Castle 'auto-calibrate endpoint' requires that on every flight you power up to WOT for a few seconds on the ground for the ESC to learn the endpoint. This has to be done after arming with the motor running. This is why I'd never used auto-calibration on a castle ESC.
Failure to do this means that whatever throttle setting you go to after arming (could be half throttle as you taxi out) the ESC will 'think' is the WOT endpoint.
Screenshot from Castle-link:
I don't think this is your problem but something to bear in mind.
40A is rather low, I was pulling 46-47A on my Torque motor with the same prop. I suspect that your battery voltage is sagging. What brand are they? Something by Hobbyking by any chance? Many have had voltage sag problems with Nanotecs well before 100 cycles.
Best bet is to put a wattmeter on it and see how your voltage holds up under load, you would be looking for 3.8v per cell on a good battery at close to it's C rating. You should be pulling close on 700W. If your voltage is sagging a bit and you don't want to ditch the batteries just yet then you might be able to use an APC 13x6.5, just make sure the amps don't exceed 50.
BTW...The Laser Cowl doesn't make any measurable difference to thrust compared to the Edge (I have both of them)
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Sep 24, 2012, 11:40 AM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
With the 4016 development program, plus the 64" MXS build and fly project, the laser hasn't gotten very much love. Right now Ken Elder has it and he is putting my B & E Graphics package on it. I tried putting the decals on, but I get all dyslexsic and can't see it. Part of this is because my eyes are still healing. Ken's work is really good, so I am sure it will look awesome. We'll have some video just as soon as the Laser is back in action.
Doc Austin is offline Find More Posts by Doc Austin
Old Sep 24, 2012, 11:59 AM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Right on doc! Glad your getting those installed.
I'm working on a video with my laser also. It's amazing what this plane will do!
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Sep 24, 2012, 01:18 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I love the plane but I wanted to save it for when it was finished. Unfortunately it's already had a really hard life, but I plan to get another one soon.
Old Sep 24, 2012, 08:45 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Ken did a beautiful job of my applying Laser B & E Graphics package. Thanks, Ken.
Old Sep 24, 2012, 08:48 PM
stgdz is offline
Find More Posts by stgdz
One blade in the water is wet
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
This one is so much fun to fly as its so stable.
stgdz is offline Find More Posts by stgdz
Old Sep 24, 2012, 08:49 PM
This is NOT a TOY?
C_Watkins's Avatar
Joined Jul 2011
Sweet!
Looking like it's ready to star in another video
Old Sep 25, 2012, 10:00 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I'll probably pull off the yellow decals on the wheel pants and the yellow Torque decal. I thought they looked good until I saw the picture.
I like it now more than ever.
Old Sep 26, 2012, 12:56 AM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Looks better now.
Old Sep 26, 2012, 01:53 AM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
Which copes with weight better, this or the Extra?
Also, which pop tops and blenders better? And which of the two is more axially centred in rolling circuits?
I am very tempted by one of these!
As I understand, it's more stable than the Extra
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Sep 26, 2012, 08:33 AM
YellowJacketsRC is online now
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Doc,
Did you say that was custom vinyl? It looks same as stock, no?
YellowJacketsRC is online now Find More Posts by YellowJacketsRC
Old Sep 26, 2012, 08:48 AM
stgdz is offline
stgdz's Avatar
Joined Jul 2011
Originally Posted by Dead View Post
Doc,
Doc is currently cross eyed and just let's his fingers do the flying now
Old Sep 26, 2012, 11:09 AM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I think the edge is the floatiest of the bunch. between the Extra and Laser, though, the laser seems to float more, even if it does weigh the same as the Extra. I have no explaination for this.
The Laser does some weird gyroscopic stuff and I need to tumble it more and find out just how wierd it can get. it pop tops really sweet.... maybe a litle bit too easy.
It seems to be, which again I don't understand because I believe they share the same wing.
Wanted Extreme flight 48 inch Extra EXP parts knifeedge63 Aircraft - Electric - Airplanes (FS/W) 5 Jun 23, 2014 11:10 PM
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Alert For sale Extreme flight 48 inch edge exp rtf cheap rudyhal Atlanta Area RC 7 May 28, 2011 12:32 PM
Sold Extreme Flight Extra EXP 48 inch w/ Airboss45 ESC- Torque2814/820 combo (Austin, TX) HKC3 Aircraft - Electric - Airplanes (FS/W) 17 Feb 05, 2011 10:49 PM
