Old Sep 21, 2012, 07:00 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Originally Posted by EXTREME FLIGHT View Post
Another video is posted from this mysterious Pilot X character, this time of the Laser. Pretty good pilot!
https://vimeo.com/49854258
AWESOME!! That dude can Huck!
Manta1 is offline Find More Posts by Manta1
Old Sep 22, 2012, 09:16 AM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Well, I still say he must be a Speed Racer fan based on his pseudonym.
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
Old Sep 22, 2012, 09:22 AM
C_Watkins is offline
Find More Posts by C_Watkins
This is NOT a TOY?
C_Watkins's Avatar
United States, GA, Atlanta
Joined Jul 2011
Maybe he's somebody's long lost brother.
C_Watkins is offline Find More Posts by C_Watkins
Old Sep 22, 2012, 09:28 AM
EXTREME FLIGHT is online now
Find More Posts by EXTREME FLIGHT
EXTREME FLIGHT CEO
EXTREME FLIGHT's Avatar
United States, GA, Cumming
Joined Feb 2004
Pilot X is the name of our helmet head pilot series
EXTREME FLIGHT is online now Find More Posts by EXTREME FLIGHT
Old Sep 22, 2012, 09:34 AM
They Call him Dead!
Joined Jul 2003
So you are the Speed Racer fan
Old Sep 22, 2012, 09:36 AM
EXTREME FLIGHT CEO
Joined Feb 2004
Yup, I was as a kid.
Old Sep 22, 2012, 09:39 AM
They Call him Dead!
Joined Jul 2003
Me too. Although I mostly watched on Black and White TV. Did not get color until I was older. But I loved Racer X. He was sooooo Cool!
Old Sep 22, 2012, 09:43 AM
This is NOT a TOY?
C_Watkins's Avatar
Joined Jul 2011
Sweet flying, whomever it is
Speaking of flying... it looks like an awesome day out there.
I think I'm off to burn a few electrons and a bit of gas
Old Sep 22, 2012, 09:46 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Racer X was awesome.
Racer X=Rex=Speed's brother
hone1er is offline Find More Posts by hone1er
Old Sep 22, 2012, 03:35 PM
blaiss is offline
Find More Posts by blaiss
Team Hillbilly
blaiss's Avatar
United States, OH, New Albany
Joined Jun 2006
I was able to maiden my Laser today. It got lots of compliments (at an unofficial 3DHS event nonetheless!)
Since the plane was tossed around in 15-25 mph winds, it was hard to get it locked in. I set the CG on the former just behind the wing tube, and that seemed to be about the right spot.
The only issue I had was it seemed anemic in vertical pullouts. Maybe I'm just used my 48 Edge EXP, which goes ballistic. My setup is: Torque 2814/820, 12X6E, Castle Phoenix 45 and 4s/2200 battery. I run a separate BEC for the servos.
Any suggestions?
blaiss is offline Find More Posts by blaiss
Old Sep 22, 2012, 03:48 PM
This is NOT a TOY?
C_Watkins's Avatar
Joined Jul 2011
Congrats on the maiden!
Does it do this with all your batteries? What kind of shape are the batteries in?
Are you running any sort of adapter, or extensions of the battery/ESC leads?
I've noticed I get less punch with a couple batteries where their internal resistance is higher.
(Probably from letting sit fully charged, which I know is a no no)
I also see it when using an adapter on a couple batteries that I haven't put a Dean's connector on yet.
On my 'good' batteries with the right connector, it seems just fine.
Also, are you sure your EP's are calibrated with that Castle?
Not sure how those setup, but make sure you're really getting your 100% full throttle signal I guess is what I'm saying.
Old Sep 22, 2012, 03:58 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
There is no reason in principal why the laser pull out should be any different from the Edge if both models are running the same hardware, weight of both planes is near enough identical, I'm guessing you are using the same batteries in both?
As noted in the last post it may be worth checking that your endpoints are properly calibrated. Castle have unusual procedures to follow to calibrate their ESC's.
For sure my Laser punches out vertically like the proverbial 'scalded cat' but I'm pulling a fair few more watts that the stock set up and spinning a bigger prop, having said that, the stock set up shouldn't be sluggish either.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Sep 22, 2012, 04:13 PM
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Are you running a Xoar on the edge? I switched my APC on my Extra (with the torque setup) to a Xoar and the difference was amazing!
--Tom K.
Tom K. is offline Find More Posts by Tom K.
Old Sep 22, 2012, 04:24 PM
Aberdeen
Joined Mar 2006
Yep, the Xoar does give a fair bit more thrust, they pull a fair few more amps too but the motor should be good for it. Might be pushing the 45A ESC a bit hard through.
Old Sep 22, 2012, 06:53 PM
blaiss is offline
Team Hillbilly
blaiss's Avatar
Joined Jun 2006
Thanks for all the suggestions.
Yes, I am running an adapter between the battery and the ESC, but I was on the Edge, too. I am also using the same batteries. They each have about 100 cycles.
The ESC is the same one that was on the Edge. Not the same model, the same unit. All the gear was pulled from the edge and put in the Laser. The Edge had a foliage encounter about a month ago (RIP). The only new item in the mix is a new APC prop. I am pushing about 40 amps with this setup.
I changed the bearings out on the motor, too.
End points are set to automatic, which is also how it was set on the Edge. I certainly could try setting end points. I run fixed end points my 74 Edge and Osiris now. I seem to be getting plenty of RPMs on the prop, although I haven't measured them yet.
Wanted Extreme flight 48 inch Extra EXP parts knifeedge63 Aircraft - Electric - Airplanes (FS/W) 5 Jun 23, 2014 11:10 PM
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Alert For sale Extreme flight 48 inch edge exp rtf cheap rudyhal Atlanta Area RC 7 May 28, 2011 12:32 PM
Sold Extreme Flight Extra EXP 48 inch w/ Airboss45 ESC- Torque2814/820 combo (Austin, TX) HKC3 Aircraft - Electric - Airplanes (FS/W) 17 Feb 05, 2011 10:49 PM
