Old Jul 31, 2012, 04:58 PM
Inverted-I-Fly's Avatar
United States, CA, Petaluma
Joined Mar 2011
Originally Posted by JetPlaneFlyer View Post
That's not so good.. did you CA all the joints around the gear plate like the manual says? Lets hope this isn't a sign of a inherent weakness, do you have any photos to show where it failed?
FWIW I bust the l/g leg on my Laser second time out, it didn't do anything to the mounting plate.
Yes I CA'ed the snot out of it
It's not that bad but....
It pushed in the mount about 3/8" on the rear side crushed a tiny bit of balsa sheeting and broke all 4 of the fiberglass cross braces, not sure how I'm going to reinforce it
Inverted-I-Fly is offline Find More Posts by Inverted-I-Fly
Old Jul 31, 2012, 07:30 PM
Play Dead!
Dead's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Yeah, it ain't easy cause you can't get in there to get at it without completely removing the covering
Dead is offline Find More Posts by Dead
Old Jul 31, 2012, 07:33 PM
United States, NV, Las Vegas
Joined Nov 2010
you don't have to peal THAT much back, I made numerous repairs on my 48" Extra that involved rebuilding the gear section and I only had to move about 2" of covering on either side of the plate.
At least with the Laser, it's all the same color!
-= GYRO =- is offline Find More Posts by -= GYRO =-
Reply With Quote  (Disabled)
Old Jul 31, 2012, 07:49 PM
Joined Mar 2011
I'm going to put it aside for a day or two or a week, got a new osiris on the bench I'm in the middle of building
Old Jul 31, 2012, 08:11 PM
VOLTS > AMPS
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
ever had a pattern plane before?
stgdz is offline Find More Posts by stgdz
Old Jul 31, 2012, 08:39 PM
Joined Mar 2011
No, just edges, slicks, extras and lasers and foamies and heli's
Old Jul 31, 2012, 09:49 PM
VOLTS > AMPS
stgdz's Avatar
Joined Jul 2011
My vanq is the one plane I can point at and say,
"That one there made me a better flyer!"
But I set it up with low rates as my high rates and the osiris and vanq are all but the same. These planes are a amazing and track like glass. Put the arm in the closet hole to the servo and max your throw rates through the tx. Due to the wing design these will tip stall and a handfull of elevator won't save you and may instead hurt you even more.
But like I said the patter planes are amazing.
Extreme flight vanquish one month later (7 min 32 sec)
Old Jul 31, 2012, 09:55 PM
Joined Mar 2011
Nice, I can't wait to get it going
Old Aug 06, 2012, 06:14 PM
Shut up and Fly!!!
jw357_23043's Avatar
United States, VA, Hartfield
Joined Aug 2011
Thread removed
jw357_23043 is offline Find More Posts by jw357_23043
Old Aug 09, 2012, 12:54 AM
Joined Nov 2010
Gents, I've got my laser for sale in the classifieds... Gotta pay for the new 60" MXS I ordered! If you're interested, PM me or check out the thread: http://www.rcgroups.com/forums/showpost.php?p=22387119
Old Aug 12, 2012, 06:25 PM
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Man i keep watching Daniels video of the Laser. Simply amazing! I really reaaaallly want one but don't want another 48''. I hope this comes out in a 60'' version. It's awesome to see something other than Edges and Extras.
hone1er is online now Find More Posts by hone1er
Old Aug 12, 2012, 06:57 PM
VOLTS > AMPS
stgdz's Avatar
Joined Jul 2011
its is
Old Aug 12, 2012, 09:21 PM
Team Twisted!
hone1er's Avatar
Joined Dec 2011
its is
Yaaaay
Old Aug 14, 2012, 07:27 PM
Joined Mar 2012
Throws in inches
Hey guys I've been enjoying this thread.
My Laser is almost complete and I'm dying to get it in the air. I need some help with setting the throws for both low and high rates. The manual gives the suggested throws in degrees. I don't have a throw meter, so I use a ruler. Can anyone give me the throws for aileron, rudder and elevator in inches. For both low and high rates.
As you can tell, I'm new to this, so any help would be great.
Scott
scott4687 is offline Find More Posts by scott4687
Old Aug 14, 2012, 07:36 PM
Joined Mar 2011
Scott
you can just print out a protractor and cut off the angle you need and use that, I like this method better than my gauge
http://www.dynapod.com/dyna-a-prot.html
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Alert For sale Extreme flight 48 inch edge exp rtf cheap rudyhal Atlanta Area RC 7 May 28, 2011 12:32 PM
Wanted Extreme flight 48 inch Extra EXP parts knifeedge63 Aircraft - Electric - Airplanes (FS/W) 3 Apr 05, 2011 11:30 AM
Sold Extreme Flight Extra EXP 48 inch w/ Airboss45 ESC- Torque2814/820 combo (Austin, TX) HKC3 Aircraft - Electric - Airplanes (FS/W) 17 Feb 05, 2011 10:49 PM
