Old Jul 15, 2012, 03:27 PM
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Originally Posted by Batfire2000 View Post
My laser is nose heavy. 2200 4 cell 293 gr. Hacker A30-14L 143 gr. Hacker ESC 45 gr. MKS DS 6100 servos 9.5 gr. Cg at the middle of the wing tube. Battery was pretty far foward. Flew nose heavy. Ended up moving battery all the way back to the wing tube and still flies nose heavy. Just does not make sence to me. Has anyone had to add weight to the tail ?? Thanks
What does it do when you flip it inverted at 3/4 throttle?
--Tom K.
Tom K. is offline Find More Posts by Tom K.
Old Jul 15, 2012, 03:50 PM
Batfire2000 is offline
Find More Posts by Batfire2000
Joined Oct 2010
Continues to drop, fast
Batfire2000 is offline Find More Posts by Batfire2000
Old Jul 15, 2012, 03:51 PM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
IMHO the Laser does tend slightly to nose heaviness. It needs to balance at the former behind the wing tube for neutral handling but if you use a heavy battery that's hard to achieve.
I think your problem is very light servos and a rather heavy battery. I used Savox servos (SH-0255 and 0257) which add about 13g to the tail compared to yours and my battery (Gens Ace 4s 2200mAh) is only 250g. With this kit I need the battery to be almost at the wing tube, so I can see how you will be nose heavy.
I certainly recommend beefier servos anyway, you really need them, especially on the elevator. The other easy change is go for a wood prop (if you haven't already), that can take 10-15g off the nose. lighter batteries would be good too, I'd recommend the Gens Ace 30c.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Jul 15, 2012, 04:07 PM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Yikes! That sounds extremely odd. Normally these EF planes balance around the same area or at least within reason.
--Tom K.
Old Jul 15, 2012, 04:32 PM
Joined Oct 2010
What seems so strange to me is when you CG the plane on the ground it seems tail heavy. So I move the battery foward and it balances. Fly it, nose heavy, move the battery back several inches, nose heavy. ???
Old Jul 15, 2012, 04:34 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
So what does it do when you put it in a dive 3-400 ft up?
stgdz is offline Find More Posts by stgdz
Old Jul 15, 2012, 04:42 PM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Maybe something's screwy. I'll probably get my head bit off for saying this, but have you checked the incidence and/or thrustline? It's a possibility. To check for thrustline (easiest), trim for upright level flight at 3/4-full throttle. Fly across the field upright at 3/4-full throttle into the wind, and chop the throttle and take your fingers off the sticks. If the plane climbs, too much downthrust (Motor pulls plane down, counter with up trim. Motor no longer pulling plane down, up trim only factor), if it dives, too much upthrust (visa versa), if it keeps going straight, then the thrustline is fine. The other thing to do would be to level the fuse up on a workbench and use an incidence meter to check the incidence of the wings and stab. Sometimes people mistake a mechanical issue like this for CG, so it's understandable. I had a brand X have way too much downthrust AND incidence issues, and the dang thing flew around like it had an elephant riding in the trunk!
Thrustline is easy to fix... just shim the motor up or down with washers or other shims. Incidence is a bit tougher to mess with, so hopefully it's either thrustline or CG.
Good luck! If you have any in-depth questions or comments feel free to PM me.
--Tom K.
Old Jul 15, 2012, 04:51 PM
_OZ_ is offline
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
All that matters is how it flies. The published CG is just a starting point to tune from. It takes quite a few flights to get things right.
I don't have the Laser but I do have the 48" Extra 300 and the two wont be dramatically different. I added 7 grams to the tail of mine Extra and that allowed me to move the pack forward and off the wingtube.
I followed the procedures outlined in my blog link below.
It took some time, but I feel the efforts were worth and I learned a lot about how different things affect how the plane flies.
Tom is an excellent pilot form what I have seen and his advice is usually just as excellent, but I would not go changing thrust lines and incidences yet. The Goldsmith guide will address those issues after you have set your CG. Give it a shot, I think you will like the results.
_OZ_ is offline Find More Posts by _OZ_
Old Jul 15, 2012, 05:00 PM
Aberdeen
Joined Mar 2006
Did you read my previous post? I have a Laser, it needs to balance at the former behind the wing joiner tube for neutral trim. if it balances much further forward than that then it will be nose heavy in flight..
So where does it balance?
Steve
PS.. i agree , whatever you do dont even think about adjusting thrust lines or incidence angle.. this simply sounds like you are balanced nose heavy, the CG location advised in the manual is a bit far forward, so don't pay much attention to it.
Old Jul 15, 2012, 05:44 PM
_OZ_ is offline
It's gone...
_OZ_'s Avatar
Joined Aug 2004
Originally Posted by JetPlaneFlyer View Post
...it needs to balance at the former behind the wing joiner tube for neutral trim. if it balances much further forward than that then it will be nose heavy in flight..
That is the same place my Extra balances too.
Old Jul 31, 2012, 09:43 AM
djmoose is offline
Find More Posts by djmoose
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
Hey guys, just wanted to let you know that thanks to Chris Hinson, ATTF is giving away a Laser EXP as one of our grand prizes for August.
http://allthingsthatfly.com/prize.php
Thanks Chris!
moose
djmoose is offline Find More Posts by djmoose
Old Jul 31, 2012, 11:12 AM
Ducati Mechanic is online now
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Nice! I think I need a car decal..
Ducati Mechanic is online now Find More Posts by Ducati Mechanic
Old Jul 31, 2012, 04:03 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
Dam, ripped my landing gear block out today in a harder than expected harrier landing, landing gear is fine, pretty shocked that the block broke before the gear
3drcparts is offline Find More Posts by 3drcparts
Old Jul 31, 2012, 04:14 PM
Aberdeen
Joined Mar 2006
That's not so good.. did you CA all the joints around the gear plate like the manual says? Lets hope this isn't a sign of a inherent weakness, do you have any photos to show where it failed?
FWIW I bust the l/g leg on my Laser second time out, it didn't do anything to the mounting plate.
Old Jul 31, 2012, 04:50 PM
_OZ_ is offline
It's gone...
_OZ_'s Avatar
Joined Aug 2004
Thanks Chris!
moose
Entered! Thanks Moose and Chris!
Wanted Extreme flight 48 inch Extra EXP parts knifeedge63 Aircraft - Electric - Airplanes (FS/W) 5 Jun 23, 2014 11:10 PM
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Alert For sale Extreme flight 48 inch edge exp rtf cheap rudyhal Atlanta Area RC 7 May 28, 2011 12:32 PM
Sold Extreme Flight Extra EXP 48 inch w/ Airboss45 ESC- Torque2814/820 combo (Austin, TX) HKC3 Aircraft - Electric - Airplanes (FS/W) 17 Feb 05, 2011 10:49 PM
