Old Jun 10, 2012, 03:26 AM
Space Bat is offline
Find More Posts by Space Bat
Team Hillbilly (UK)
Space Bat's Avatar
United Kingdom, England, Cambs
Joined Oct 2011
Damn your lucky my missus will allow me to work on a plane on the kitchen table - but for no longer than necessary....so if I aint finished it aint staying....so have to pack everything up
Space Bat is offline Find More Posts by Space Bat
Old Jun 10, 2012, 07:58 AM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Originally Posted by Inverted-I-Fly View Post
You know, I have this plane on the work stand on my dining room table (bless my wife, she put up with my week long builds) and everytime I go to the kitchen or the bedroom I pass it. And all I can think............ dam, this is a great looking plane, really loving the style of the laser
I'm not sure how far you got but in noticed a couple of differences in building the laser.
1) Input the 85mg on the left side at the more forward mounting opening. Like I said the wood is thin so when you go to cut it to enlarge it for the 85mg don't apply downforce. Instead carve it out. I was worried I would break the play wood.
2) make certain you glue around the way king tabs. I had a gap in mine that I filled with some Med CA.
3) Since you have the cowl and canopy mounted it doesn't look like you drilled it into position the cowl is mounted so that the canopy fits under it. Well at least with a 42mm can length I found that out. Course I always mount the motor then cowl so I'm glad I noticed this.
stgdz is offline Find More Posts by stgdz
Old Jun 10, 2012, 09:38 AM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
Thanks for the tips, not understanding what the way king tabs are?
3drcparts is offline Find More Posts by 3drcparts
Old Jun 10, 2012, 09:59 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
'Wing tabs' maybe?.. As in the little tabs that the wing retaining screws go through?
If that's the case I'd not really be concerned about a gap where they come out of the wing because they are fixed into the wing structure internally.
My Laser should arrive tomorrow
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Jun 10, 2012, 10:26 AM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Steve they are fixed internally with epoxy but on one of my wings there is a gap between the tab and the wing rib. I added a the CA to wick it up. I wish ef would have made the tabs a t style so that the t would but up against the wing rib and the flat on the fuse but the tab is just a flat piece of wood and epoxy.
Old Jun 10, 2012, 10:34 AM
Aberdeen
Joined Mar 2006
stgdz,
Doesn't the tab extend into the wing and pick up a second rib?.. Also on the inside face of the root rib I think there is a plywood doubler which should give most of the strength.
This is based on how it's done on the HK Slick, and I suspect the Laser will be similar.
In any case the tab doesn't carry anything significant in the way of flight loads so i'm sure will be more than strong enough.
Steve
Old Jun 10, 2012, 11:11 AM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Originally Posted by JetPlaneFlyer View Post
stgdz,
Yeah, it's really in there. I did not look at it real hard.... only enough to run some CA in there, but the whole structure is pretty stout.
Looking at the wings on other EXP, and other brands of planes, most are held on by a nylon bolt threading into a blind nut that is mouned on a plywood plate, inside the root rib with no further reinforcing. The wings are really not stresed to where there is any pressure on that joint, so it does not have to be bulletproof.
Still, the Laser wing hold downs are really beefy and I am not worried about them.
Doc Austin is offline Find More Posts by Doc Austin
Old Jun 10, 2012, 12:14 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Agreed and I am nit picking because I know others may nit pick it also. I couldn't see a doubler on the back side but I seemingly miss more obvious things in the world according to my wife,
like why I went flying without doing the dishes, folding laundry, picking up the house, etc....
Needless to say I think the laser may surpass the extra as my go to plane.
Old Jun 10, 2012, 12:51 PM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Why? Why "needless to say"?
Just looking for your thoughts....
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
Old Jun 10, 2012, 04:47 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Mine probably wiii as soon as I can get another one. We shot some video in 20 moh winds today, but maybe some of it will be decent. I hope to have it in a couple of hours.
Old Jun 10, 2012, 06:20 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Doc,have you ripped the wings off your laser yet?
Manta1 is offline Find More Posts by Manta1
Old Jun 10, 2012, 06:44 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
No, but I did a death blender today that I thought was gonna sling the wheel pants off. We'll see if the video comes out.
Old Jun 10, 2012, 07:06 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
I've yet to tilt a wheel pant yet but I really tightened down those nuts.
Oh janole, that profile you liked looking at. It looks so good in the air! The side profile is completely different from anything out there currently. That bubble canopy is just plain cool.
Old Jun 10, 2012, 07:17 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
didn't get any work done on the laser today, but did go out and fly 5 pack on the 60" extra and 5 on my 48" edge (3dhs) I have to say I'm starting to like the extra a lot, it really likes to be flown fast, I might need to set up some kind of throttle curve as there is almost to much power in the middle, like when hovering and harrier-ing, is that something I should look into?
In all honesty, I'm really still more comfortable on the smaller 40-50" planes and that is why I'm so looking forwards to the laser
Old Jun 10, 2012, 07:27 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
then i wouldn't worry about the wing design on the plane either if you haven't flung em off teeheehee,
Wanted Extreme flight 48 inch Extra EXP parts knifeedge63 Aircraft - Electric - Airplanes (FS/W) 5 Jun 23, 2014 11:10 PM
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Alert For sale Extreme flight 48 inch edge exp rtf cheap rudyhal Atlanta Area RC 7 May 28, 2011 12:32 PM
Sold Extreme Flight Extra EXP 48 inch w/ Airboss45 ESC- Torque2814/820 combo (Austin, TX) HKC3 Aircraft - Electric - Airplanes (FS/W) 17 Feb 05, 2011 10:49 PM
