Old May 27, 2012, 12:16 PM
stgdz is offline
Find More Posts by stgdz
One blade in the water is wet
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Is there g10 on the firewall and the gear plate?
stgdz is offline Find More Posts by stgdz
Old May 27, 2012, 01:51 PM
Doc Austin is offline
Find More Posts by Doc Austin
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Gear plate. the motorbox now used a lot lof plywood. check the pictures on the blog report.
http://docaustinextreme.blogspot.com...r-explive.html
Doc Austin is offline Find More Posts by Doc Austin
Old May 27, 2012, 01:54 PM
Stark is offline
Find More Posts by Stark
Don't worry be happy :)
Stark's Avatar
Joined Sep 2001
Originally Posted by Doc Austin View Post
...I will probably put an HS5065 on the elevator so I can bump the throw up to 88 degree using the long hewavy duty Dubro arm...
Thanks for your excellent review!
Do you mean HS 5085MG? Aren't you using the HS 5065MG?
Have you got the weight of the plane without battery and ready to fly?
Stark is offline Find More Posts by Stark
Old May 27, 2012, 01:57 PM
C_Watkins is offline
Find More Posts by C_Watkins
This is NOT a TOY?
C_Watkins's Avatar
United States, GA, Atlanta
Joined Jul 2011
<checks clock>
Fly Laser.
Get video.
Go go.
C_Watkins is offline Find More Posts by C_Watkins
Old May 27, 2012, 02:25 PM
stgdz is offline
stgdz's Avatar
Joined Jul 2011
yeah I just couldn't see the firewall, I see what appears to be two g10 strips running down the lenght of the gearplate or is it a solid plate like the rest of the exp's?
Old May 27, 2012, 03:03 PM
_OZ_ is online now
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
Is the wing tab just glued in or is there some other reinforcement behind the tab?
Also, is the motor mounted if front of or behind the firewall?
_OZ_ is online now Find More Posts by _OZ_
Old May 27, 2012, 03:29 PM
Stark is offline
Stark's Avatar
Joined Sep 2001
I've the construction with wing tabs on my Sebart Katana and it is very solid.
Old May 27, 2012, 07:27 PM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
OZ,
as its the same structure as the hk slick, that wing tab has a block behind it and is very rigid.
I'd assume the motor mounts in front like all the exp's and as Doc used the torque motor on this laser and hasn't mentioned anything about reversing it.
bigroger is offline Find More Posts by bigroger
Old May 27, 2012, 07:36 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
You got me. I meant to say HS5085MG.
No. The UPS store where I weigh my planes is closed on weekends, but the Laser is very light. I think it is lighter than even the Edge EXP.
We shot one video today, but it was in ridiculous high wind. We'll post it as soon as we get it.
Old May 27, 2012, 07:38 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Strips. Still looks plenty strong.
Plywood.
Still on the front of the firewall.
Old May 27, 2012, 07:42 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
As you have asked the same question three times now and not got an answer, I will take it that the motor mount plate is just plain double layer ply wood, no more G10 plate glued onto the ply MOTOR mount.
Old May 27, 2012, 08:09 PM
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Nice write up Austin!
--Tom K.
Tom K. is offline Find More Posts by Tom K.
Old May 27, 2012, 08:19 PM
This is NOT a TOY?
C_Watkins's Avatar
Joined Jul 2011
Looked like Doc answered him right away, to me:
Maybe I'm just used to that sort of answer, so it parsed right away, for me.
(Sure he could've added "only" or "just" or further clarified... but he definitely answered)
Then Stgdz moved on from the firewall, asking for more on the gear plate. (solid or strips)
Doc answered that one, too... 4 minutes before you posted.
Old May 27, 2012, 08:35 PM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
Beats me what your quoting.
I still do not understand that answer; must be an American abbreviation of the English language. I would have expected the answer to be properly phrased " no G10 on motor mount, but there is a G10 strip on the landing gear plate area" or something along those lines.
Sorry Doc if I caused issues, perhaps its something lost in translation!!! :-)
Old May 27, 2012, 08:36 PM
_OZ_ is online now
It's gone...
_OZ_'s Avatar
Joined Aug 2004
Thanks Doc and BigRoger for the replies.
Wanted Extreme flight 48 inch Extra EXP parts knifeedge63 Aircraft - Electric - Airplanes (FS/W) 5 Jun 24, 2014 12:10 AM
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 03:45 PM
Alert For sale Extreme flight 48 inch edge exp rtf cheap rudyhal Atlanta Area RC 7 May 28, 2011 01:32 PM
Sold Extreme Flight Extra EXP 48 inch w/ Airboss45 ESC- Torque2814/820 combo (Austin, TX) HKC3 Aircraft - Electric - Airplanes (FS/W) 17 Feb 05, 2011 11:49 PM
