Old Feb 27, 2012, 12:33 PM
sscherin is offline
Find More Posts by sscherin
sscherin's Avatar
USA, WA, Kennewick
Joined Nov 2005
Question
Drivers and Steppers for CNC Hot wire foam cutter
Anything know if 20 step (18) steppers will work for a CNC foam cutter?
I already have 4 of them and I was thinking maybe I should get from 200 or 400 step motors.
2nd question is on Driver boards..
What ones should I go with?
$15 Stepsticks off Ebay
http://www.ebay.com/itm/110803451669...84.m1438.l2649
Sparkfun's Big Easy Driver $22
http://www.sparkfun.com/products/10735
Linistepper (unipolar only. I would need new steppers)
http://www.piclist.com/techref/io/st...step/index.htm
thanks!
sscherin is offline Find More Posts by sscherin
Old Feb 27, 2012, 03:08 PM
sscherin is offline
sscherin's Avatar
USA, WA, Kennewick
Joined Nov 2005
OK I broke down and bought a set of Vexta PK266 steppers.
Now all I need to do is make up my mind on the drivers..
Wanted CNC hot wire foam cutter wanted RTSF Aircraft - General - Miscellaneous (FS/W) 2 Nov 29, 2012 07:41 PM
Wanted CNC Hot Wire Foam Cutter (4 axis) -Snowfly- Aircraft - General - Miscellaneous (FS/W) 0 Dec 07, 2011 04:13 PM
Discussion Appropriate for diy cnc hot wire cutter? Silent J CAD/CAM 2 May 10, 2011 12:57 PM
Discussion Hot wire foam cutter, hand held! Jim Hatch Foamies (Scratchbuilt) 7 Apr 29, 2011 04:59 PM
Alert For Sale CNC Hot Wire Foam Cutter Depdog Atlanta Area RC 9 Mar 24, 2010 10:35 AM
