Old Oct 16, 2003, 05:12 PM
Cavi is offline
Find More Posts by Cavi
Joined Jul 2003
multiplex microjet questions
Is the jet good with the original motor or is there a better choice?
Also what batteries? Will the Kan 1050 cells fit? What configuration, stick or side by side?
Cavi is offline Find More Posts by Cavi
Old Oct 16, 2003, 06:32 PM
Helicool is offline
Find More Posts by Helicool
Helicool's Avatar
Toronto, ON Canada
Joined Jul 2002
Cavi -
I'm currently flying with the Stock Motor and 8xKAN950's in a twin-stick config (it took a little dremel'ing to make it all fit) - A brushless would be fun but a little pricey! Mine flies great stock - just be sure to use 8-cells, not 7.
I had to put my reciever in the nose - not something I would reccomend if you can aviod it (plus, using all those servo extension wires was quite a pain....)
Heli
Helicool is offline Find More Posts by Helicool
Old Oct 16, 2003, 06:39 PM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
Iif you were to do TWo Sticks of four and put them inSo one stick is laying on top of the other there will be lots of room in fact i think you would need some foam on both sides. I think a Mini AC 12/15/16 DD would be a good choice(With a 4x4 Prop) I have a Mega 3 turn on mine and 8 1700AUP`s. Pretty quick but still not as fast as the old Projeti. Fun little plane though. I find it a little more"Interesting" to fly than the Projeti thats for sure
Mal
kushal_22 is offline Find More Posts by kushal_22
Old Oct 16, 2003, 10:12 PM
Cavi is offline
Joined Jul 2003
what was the projecti?
Old Oct 16, 2003, 10:37 PM
kushal_22's Avatar
Kamloops
Joined Dec 2001
This is a Projeti
If you go to www.hobby-lobby.com and do a search for Projeti you can see a STOCK one fly. Then add Another 30 to 40MPH onto that and you have a Mega 3 turn Projeti(Close to 100MPH) if not a little over with the right batt Prop Combo. I have a Lipo setup which i am going to test when it stops raining this one should top 110MPH
Mal
Old Oct 17, 2003, 07:07 PM
zorro is offline
Find More Posts by zorro
Va.
Joined Mar 2003
I'm flying the yellow PJ with S400 with the esc made onto the motor (hobby-lobby) I un soldered the esc from the motor & rotated it 180 deg & re soldered in order to get the pusher rotation. Prop is gunther & using 1100 HE cells both 7 & 8 cell packs. Just finished 5 7 cell flights & 2 8 cell flights. Love this plane, I have a 480L also with esc mounted to motor just waiting for the Reno Racer to arrive have 2 8 cell Kan 1050 packs for the Reno. Sweet flying bird, usually fly 6 to 8 min per pack. Launches
great & lands super. After the 480L, will take my Mega /4 out of anouther plane & stick it in the Jeti. While flying the jeti other day, I decided to see if she would fly "topless" with the plastic cover removed. 1oz weight reduction, did great & motor much cooler, just had to firmly secure the rcvr & batt pack.
Ed
zorro is offline Find More Posts by zorro
Multiplex Microjet nasa_steve Foamies (Kits) 1 Jun 13, 2003 03:04 PM
Multiplex MicroJet & Wattage DF gear Phillybaby Electric Ducted Fan Jet Talk 36 Apr 28, 2003 11:09 AM
Multiplex cockpit questions. Jeff Charlot Radios 6 Feb 10, 2003 03:53 AM
Multiplex Cargo questions Jedimaster65 Foamies (Kits) 6 Nov 11, 2002 09:38 AM
