Old Feb 27, 2012, 12:12 PM
MADISONMaster is offline
Find More Posts by MADISONMaster
MADISONMaster's Avatar
France, Burgandy, Dijon
Joined Jun 2010
L-39 Albatros 90mm Fiberglass EDF Jet (Triones) - Build and Mods
Hello
Today, I ordered a legendary aircraft :
L39 ALBATROS (Triones)
(for 100mm EDF)
http://www.trionesmodel.com/L_39.html
I open this forum and I hope it will be full of ideas for the construction and setting flights of this jet
L-39 ALBATROS SPECIFICATIONS
Wing Span: 49.4 in /1254 mm
Wing area: 480.5 sq in / 31 sq dm
Flying weight: 6.6 lb / 3.2kg ( - estimated at 4,5 kg for me)
Fuselage length: 59 in /1495 mm
I think using the Skyworld fan JP 1000 - 101 mm Special Metal EDF Unit (7 blades) with ARC 3675-1 and ESC 120A (8S 5000 45C) and Lander Full Metal Tricycle Electric Retract System (3.5 - 7.5Kgs Flying Weight) with EUROKIT legs
See you soon with your ideas, photos and videos
was soon with more information on weight and wing area
MADISONMaster
MADISONMaster is offline Find More Posts by MADISONMaster
Old Feb 27, 2012, 12:25 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Nice L39, wish they were sold in the states
Where did you orders yours from?
Thx in advance
erh7771 is online now Find More Posts by erh7771
Old Feb 27, 2012, 12:58 PM
Joined Jun 2010
L39 ALBATROS (Triones)- seller
Thx in advance
Hello erh7771
These jets are rarely available and always in order with the supplier, so I did not hesitate to order it
I ordered this L39 here (France)
http://www.miniplanes.fr/avions-jets...f-p-34970.html
the least expensive (for me) for shipping! (20 $ for shipping in France )
MADISONMaster
Old Feb 27, 2012, 01:26 PM
Joined Nov 2005
Originally Posted by MADISONMaster View Post
Hello erh7771
MADISONMaster
Thx, I've asked triones for a list of distributors but I doubt I'll get a response
Old Feb 29, 2012, 12:48 PM
Joined Jun 2010
L39 ALBATROS - receved
Hello
I just got the L39 from Miniplanes (France)
Wings weight without landing gear : 490 gr
Fuse weight without landing gear : 1580 gr
Total weight plane only without landing gear : 2070 gr
wing area with cans of wingtip : 33.5 dm2
width of the fuselage to the wing : 18 cm
wingspan : 126 cm
Total weight estimated 4.6Kg with strong landing gear (5-7.5kg)
views of some parts (very good quality)
MADISONMaster
Old Feb 29, 2012, 04:41 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Looks great MADISONMaster!
Be sure to at least, static balance the rotor by it's self using a prop balancer. (add weight to the light side with putty, coated with a very thin layer of 5 min epoxy.
If your not using tools (IE: dynamic balancer or cell phone balancing), dynamically the balance the complete fan setup while running a low rpms, by turning the spinner 90 degrees and feeling for the smoothest position.
Please mount the fan securely to the bench, take safey precautions, and do not run the fan at high speed in close proximity to yourself. This applies to all EDFs.
Have fun, Gary
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Feb 29, 2012, 06:39 PM
Joined Nov 2005
Hello
wingspan : 126 cm
MADISONMaster
That's around 4.5lbs, that's 8oz more than my FF F100 weights and it's a floater, should be interesting
Anyone know were to buy this in the US?
Thx
Old Mar 01, 2012, 01:15 PM
Joined Jun 2010
static balance rotor
Hello
efflux RC
Thanks - static balance the rotor ... yes i always do that because it is very dangerous if we neglect this ...... by cons, I do not know the method in Dynamics !
there is 7 blades in this Skyworld fan JP 1000
For information, the fixed landing set weighs 150 gr with 3 wheels (foam 65mm) and rhodo´d trust tube weighs 50g
MADISONMaster
Old Mar 02, 2012, 10:58 AM
Joined Jun 2010
retractable landing gear for the L39
Hello
I received my landing gear legs Eurokit
DU-BRO front wheel 57mm
Main wheel 60mm Eurokit
Total weight landing gear witht electric RC Lander about 416 gr (5 to 7.5kg and these Main landing can turn 90░ - 266 gr more than the fixed gear )
It will provide a small bump on the extrado because of the thickness of the landing gear
MADISONMaster
Resumption of activities at the end of the year
Old Aug 08, 2012, 03:03 PM
QQHeaD is online now
Find More Posts by QQHeaD
Russian Federation, Murmanskaya oblast, Kirovsk
Joined Nov 2011
Hi guys! Somebody has a video with this plane?
QQHeaD is online now Find More Posts by QQHeaD
Old Aug 08, 2012, 03:28 PM
Joined Nov 2005
I wish, seems like it has potential
General hobbies has them
http://www.generalhobby.com/albatros...ane-p-407.html
Madison master, pray tell where did you get the landing gear?
Regards
Old Aug 13, 2012, 12:25 PM
Joined Jun 2010
The main landing gear....
Regards
Hello erh7771
The landing gear is available on this following links
http://www.der-schweighofer.at/en/pr..._gefedert_zlin
MADISONMaster
Old Aug 25, 2012, 06:41 AM
Joined Nov 2011
Whoosh all!
Here is my albatross. Theme built here (in Russian).
Not fly very fast because of key problems of the speed controller.
Flying weight 3,5kg.
L-39 Trionesmodel (5 min 5 sec)
Old Aug 26, 2012, 02:18 AM
Joined Jun 2010
Whoosh all!
http://www.youtube.com/watch?v=MjQuY...layer_embedded
Very nice - what is your engine and how many cells?
retracts?
Old Aug 26, 2012, 02:44 AM
Joined Nov 2011
Build thread http://forum.rcdesign.ru/f101/thread287437-2.html
motor Warhead 1850kv, Battery 6S 5000mah, carbon EDF
The throttle limited to 70% on transmitter, because the max current of 146A!
Not have retracts.
Today download HD video.
Off Site Sapac L39 Albatros 70mm edf Depron Dave Aircraft - Electric - Jets (FS/W) 0 Jan 04, 2012 12:31 AM
Discussion whats it worth? gp l39 albatros veggieslinger Electric Ducted Fan Jet Talk 3 Jan 02, 2012 09:35 AM
Build Log L39 Albatros Waltjg Scratchbuilt EDFs 90 Nov 14, 2011 09:05 PM
Question FMS L39 albatros CG Seeyou57 Foamies (Kits) 0 Aug 24, 2011 04:20 AM
L39 Albatros drawings Ralf Paehl Electric Ducted Fan Jet Talk 17 Sep 05, 2002 04:54 PM
