Old May 12, 2012, 11:00 AM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
Beila 16x8 4-blade
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old May 12, 2012, 12:22 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
That is the prop you used on the Test run a couple pages back?
That over 3500 watts?! Right.
Sure does sound awesome. And Looks good too!
I was suprised the way that bird landed it looked like it didn't want to come down. Was it windy that day?
Thanks for the info, I've been looking for 12s setup.
TripleW is offline Find More Posts by TripleW
Old May 12, 2012, 01:00 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
3500 watts static pull on the ground. in the air it unloads substantially to around 2300 watts. Amps on static pull is 90, with around 73a in the air.
Administrator
Old May 12, 2012, 06:53 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Originally Posted by scatsob View Post
You gonna pick one of these up Walter?
I can't decide. I like the PC-21 too!
Old May 13, 2012, 07:06 AM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Man, I think flying the PC-21 from Riddles field would be difficult. Not a lot of room for error. I bet the T-6 lands slower. And isn't it cheaper.
scatsob is offline Find More Posts by scatsob
Old May 13, 2012, 11:38 AM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Brakes might be a good idea!
Old May 14, 2012, 06:48 AM
Snaer810 is offline
Find More Posts by Snaer810
Michigan
Joined Feb 2008
Motor Test Run.
Well I was bale to pull some initial numbers. There nothing like what my MotoCalc program had put together. But then in reading Matts numbers they do significantly drop when the prop finally unloads a bit in the air.
With the Turnigy 6374-192Kv
At WOT:
Volts avg. Vm = 37.62v
Peak Amps Ap = 101a
Peak Watts Wp = 3735
I have not put a tach on as yet. Just ordered one because I didn't have one for a 4blade prop.
Overall for about a 2min run (WOT was about 30sec.) and no extra airflow running over the motor and ESC, the motor and ESC were just warm, no problem putting my hand on it. The battery packs were luke warm at best. It was indiacted that just having another connection with the watt meter in the mix can provide enough resistance to cause some extra heating. As Matt had indiacted the Amps are a bit higher than what I was expecting also, but then accounting for a 10 to 20% unloading in the air that would drop me down to around 82-85 amps at WOT which is within the specs of the motor, so I don't think this would be a problem. Besides this would be for short bursts of 30 sec. or less on a high speed pass or areobatic manuver.
As I had mentioned when I started this thread, this is my first electric and I'm learning a lot from all of you. So please let me know what you think and provide some opinons on this set-up. It all looked good on paper.....LOL, but we all know thats not always what our final result is.
Right now I'm wondering if I need to come down in prop from the 18X12 to an 18X10 to cut back on the amp draw. Then on the other hand....I'm thinking maybe I just need to fly the aircraft first and see how it performs, then start making changes as needed. Everything I have read on this motor is that it is not a problem swinging the bigger prop....thats why I went to a lower Kv motor. Thats why we have a throttle right???
I definitly need to go to a Castle Creations ESC with a data logger. That sure seems like a handy tool and worth the extra money.
I'll be doing some additional testing later tonite to get some 50% and 75% power readings. I'll post when I have these. Hope to have some RPM readings also.
Snaer810 is offline Find More Posts by Snaer810
Old May 14, 2012, 08:39 AM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Mike, What prop did you use to get those numbers?
Thanks, Walter
Old May 14, 2012, 08:42 AM
Snaer810 is offline
Michigan
Joined Feb 2008
Walter,
The Prop is a Zinger Pro series 18 X 12 4 blade.
Old May 14, 2012, 09:31 AM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Thats a big four blade.I thought you were talking two blade.
Probably looks great on there.
Any idea what size a scale prop would be for this model?
Old May 14, 2012, 10:50 AM
Snaer810 is offline
Michigan
Joined Feb 2008
Walt,
The 18" Dia Prop would be scale.
See pictures on Post #81.
Old May 14, 2012, 11:29 AM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Oh yea that looks fantastic!
Good luck on your maiden.
Thanks for being patient with my redundant questions.
Old May 14, 2012, 11:30 AM
Arkole Blake is offline
Find More Posts by Arkole Blake
Arkole Blake's Avatar
United States, TN, Nashville
Joined Nov 2011
Went to the local air show this weekend and there was a T-6 on static display.
I snapped a bunch of shots as I have been considering building one of these models myself. Thought Id post em here incase any of you guys were thinking of adding extra scale details to your birds.
Arkole Blake is offline Find More Posts by Arkole Blake
Old May 14, 2012, 11:45 AM
Snaer810 is offline
Michigan
Joined Feb 2008
Not a problem Walt....
Ask away! Glad to have you on the forum.
Old May 14, 2012, 11:47 AM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Nice pics AB!
Discussion T-6 Texan II (Turboprop) Eddie P Electric Warbirds 12 Sep 06, 2011 09:04 PM
Discussion Unique model tech t-6 Texan II kc135boomer Electric Warbirds 2 Jul 18, 2011 09:31 PM
Build Log HOB T-6 Texan Build (electric conversion) IFLYRCAZ Scale Kit/Scratch Built 85 Jan 20, 2008 02:40 PM
T-37 or T-6 Texan II fuzzyhead Parkflyers 24 Nov 29, 2006 08:37 PM
ESM AT-6 Texan MR-STI Glow to Electric Conversions 1 Dec 11, 2005 05:51 AM
