Old Apr 30, 2012, 01:14 PM
Snaer810 is offline
Find More Posts by Snaer810
Michigan
Joined Feb 2008
Ver 2 gear
Big,
Not understanding completely. Am I understanding that when cycling the gear they will come up and then start back down all by themselves? Almost sounds like what mine started out doing. They finally gave out and got them replaced. The only other explanation would be they are hitting the current limit switch on the way up, which in turn will start them back down automatically. This is actually a fail safe in case it hits an obstruction .....etc that will send it in the other direction.
Let me know exactly what is happening....maybe we can help.
Snaer810 is offline Find More Posts by Snaer810
Old May 01, 2012, 09:33 PM
2Big is offline
Find More Posts by 2Big
2Big's Avatar
Joined Jul 2008
Still dealing with the retracts. Just recieved the canopy an installed it. ESM must be sourcing out because the new canopy is a thousand times better than the oeigional. Much stronger an also has an additional painted cross member located across the first pilots position. Glad the origional came with a crack....
2Big is offline Find More Posts by 2Big
Old May 01, 2012, 10:28 PM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
take a pic. I want to see
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old May 02, 2012, 09:36 AM
2Big is offline
2Big's Avatar
Joined Jul 2008
Here's a few picts of the canopys
Old May 02, 2012, 09:44 AM
2Big is offline
2Big's Avatar
Joined Jul 2008
forgot a closeup
Old May 06, 2012, 11:02 PM
Snaer810 is offline
Michigan
Joined Feb 2008
More work completed
Well got more parts in and completed some more things.
Got the Prop and Spinner back. Lightly sanded the prop down and put one coat of flat black and then applied the white tips and Hamilton Standard decals. Then she got 3 coats of satin clear. It really turned out nice.
Cut out the holes for the exhuast and cut out the ends of the stacks for a more realistic look. Found some Anidozed Bronze for the exhuast stacks and then misted them with a silver to give it that glazed metal look.
Cut out the speaker hole in the fusealage. The front speaker cover is 1/32 ply that will be painted to match the fusealage and there will be black screening mounted to the inside of the cover to blend everything in and protect the speaker.
Next will be to cut out the speaker hole in the center wing section and mount the second speaker. Once everthing is mounted will give it a test and see how it works without any speaker boxes. Dave Harrison said to give it a try this way first using the fuse as a big speaker box. The only problem I see is that it is not a completly sealed compartment. So we'll see.
I did a short test last night with the motor and prop and all I have to say is WOW!!! Havn't put my GT Watt meter on it yet but it sure is throwing out a lot of thrust and that was not even at 1/2 throttle. There was so mush thrust it blew one of my pictures off the wall in my shop area....LOL
Well I'll add more when I get a chance. Some pics below of some of the work completed.
Old May 11, 2012, 06:54 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Snaer810, Did you get any numbers off the wattmeter on you setup?
TripleW is offline Find More Posts by TripleW
Old May 11, 2012, 09:34 PM
Snaer810 is offline
Michigan
Joined Feb 2008
Triple W,
Welcome. I have not had the chance as yet, but I'm hoping to get some help at the feild to do a test run-up and get some numbers on this setup.
From what I can gather from other modeler's is that with this size prop, motor and batt set-up the output was amazing. Some had a problem keeping the motor cool, but I used the same baffle and ESC mount design that Matt had built. He believed it really helped keep the motor cool.
Hope to have some numbers by Sat. night.
Old May 11, 2012, 10:09 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
Troy Built Models ESM Texan II SEFF 2012 (2 min 41 sec)
Administrator
Old May 11, 2012, 10:24 PM
Snaer810 is offline
Michigan
Joined Feb 2008
Great Video Matt. !!!
Looks like its a lot of fun to fly.
Noticed that it looked like you were using mainly rudder to turn the aircraft when the flaps were down full. Does it want to tip stall at all? or is just better to use rudder more when at a slow airspeed?
The flaps really slow her down though....thats really nice.
GREAT JOB!
Old May 11, 2012, 10:27 PM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
I have not noticed any stall issues with the flaps down, I just like using rudder alot
Administrator
Old May 11, 2012, 11:01 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
S, I look forward to you numbers and your Maiden. Good Luck, Walter
WD, Sounds sweet! I guess it doesn't mind 12s?!
Did she run warm?
Old May 12, 2012, 07:24 AM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
WD, Sounds sweet! I guess it doesn't 12s?!
Did she run warm?
Its 12s 5000.
The motor is barely warm to the touch after a flight, thanks to the prop mostly, and the baffles I made that direct air up to the motor.
Administrator
Old May 12, 2012, 08:19 AM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Webdr, What size prop did you end up with?
Old May 12, 2012, 09:42 AM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
You gonna pick one of these up Walter?
scatsob is offline Find More Posts by scatsob
Discussion T-6 Texan II (Turboprop) Eddie P Electric Warbirds 12 Sep 06, 2011 09:04 PM
Discussion Unique model tech t-6 Texan II kc135boomer Electric Warbirds 2 Jul 18, 2011 09:31 PM
Build Log HOB T-6 Texan Build (electric conversion) IFLYRCAZ Scale Kit/Scratch Built 85 Jan 20, 2008 02:40 PM
T-37 or T-6 Texan II fuzzyhead Parkflyers 24 Nov 29, 2006 08:37 PM
ESM AT-6 Texan MR-STI Glow to Electric Conversions 1 Dec 11, 2005 05:51 AM
