Old Feb 27, 2012, 08:23 AM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
Anderson Power Pole Metal Locking Pins Question?
Do you use the locking pins? I heard someone say they can vibrate out and get loose inside the airplane.
Thank you.
itsme2 is offline Find More Posts by itsme2
Old Feb 27, 2012, 08:47 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
They are split roll pins make out of a spring stell material. Some fit tight and some not so tight. You can use a screw driver pushed into the slot to spread them and make them tighter.
I never really liked using them so have always used squre / round toothpicks instead. box of 250 is around $1 and I use each end so cost is next to nothing. Push in and trim flush.
Charles
Old Feb 27, 2012, 09:02 AM
PGR is online now
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
I order mine from powerwerks.com and they sell the housings unassembled (individual connectors) and permanently bonded (already paired). Since I could only recall a couple of times that I've ever used an individual connector, I ordered the permanently bonded housings the last time ordered and I've never regretted it. I still have a pretty good inventory of individual housings in both red and black so I still have all the bases covered.
Pete
Note: I'll add that I've "permanently bonded" several housings on my older pigtails when the roll pin either disappeared or became loose.
PGR is online now Find More Posts by PGR
Old Feb 27, 2012, 09:23 AM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
CA if I want them bonded.
rampman is online now Find More Posts by rampman
Old Feb 27, 2012, 10:00 PM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
Same here, a tiny drop of CA in the dovetail, slide it together, and it will never come apart.
Ohmic is offline Find More Posts by Ohmic
Old Feb 28, 2012, 10:47 AM
itsme2 is offline
Joined Mar 2011
Thanks for the good responses! I sure do like these connectors..
Old Feb 28, 2012, 07:00 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
I've never locked any of mine. The fit varies , but most times they are plenty tight for me.
gulio is offline Find More Posts by gulio
Old Mar 01, 2012, 09:31 PM
Ohmic is offline
USA
Joined Jan 2002
I've only ever had to CA a few pairs together myself. I usually buy the 25 or 50 packs so I just keep trying until I get a tight fit. I was at the end of a bag all that was left were some loose ones so out came a tiny drop of CA.
Discussion Anderson Power Pole Assembly Question? itsme2 Batteries and Chargers 12 Feb 05, 2012 11:44 PM
Sold New Trex 500 belt tail case with metal hex pins + tail drive gear + tail shaft $25 Tomy. Aircraft - Electric - Helis (FS/W) 0 Jun 21, 2011 02:57 AM
Discussion Advice needed Removing/Replacing Link pins in Metal tracks roadwarrior RC Tanks 7 Jun 26, 2008 08:38 PM
Near miss of metal light pole gdouglas Aerial Photography 7 Oct 07, 2004 03:18 AM
Question about POT 02a motor locking up. sky guy Parkflyers 3 May 29, 2003 06:36 AM
