Hong Kong
Joined Jan 2010
Helipal has just uploaded a video comparing the Mini CP with MCPx. It seems they have done a demolition job against the MCPx. Critically, they are comparing the price of a MCPx with a DX8 transmitter against a Mini CP with Devo 8s transmitter i.e. $529.9 vs $329.9
With the two radios I think they tried to make the TX performance the same. If they would of tested with the mCP and 4x tx at $219 VS the miniCP and devo7 tx at $159 do you think that would of been better? The mini would of killed the mCP.
Latest blog entry: Logo build
But If he were to have a comparable radio such as the dx6-7 to the devo8 (devo8 is missing some switches and functions and sticks are not as nice so is more comparable to the spektrum 6-7 channel) It would have been a real landslide in way of the mini CP probably 5 stars to 2 stars. If going from the rtf mcpx and the rtf devo7/miniCP it would have been another landslide as rtf doesnt offer squat for programming and the devo7 albeit a crappy screen has programming to rival a dx6i as well but only for $30 over a BNF unit. On FET and such digikey is where i buy from |
All the devo tx have ball bearing sticks. They seem smoother than my Futaba. As for switches I think the devo 8 uses the touch screen for some built in mixes.
All ball bearings are not created equal as the devo8 is not as smooth as the dx8 or the 9503. Now the devo12 is pretty close to the x9503 feel but still has an ever-so-slight ratchet feeling in the throttle.
The devo8 lacks toggles and toggle positions compared to a dx8 and is why it is more simlar to a dx6-7 as functionality to them is much more similar. The dx8 has almost all 3 position toggles on it for more uses on the fly. The dx8 and above have fully progamable toggles as well whereas the devo8 doesn't and you cant switch a 3 position toggle switch to a two toggle such as with flight mode and THold via software swap. |
Tokyo
Joined Jan 2010
Regarding durability, IMO the mini cp needs the servo saver mod unless you're at indoorheli's skill level. Loosening the collar can help take the strain off the servos, but not like the saver mod.
Bottom Line: The mini cp can be as durable as the mcpx, but requires some modding (unless you're an expert pilot). my 2¢ anyway |
Hong Kong
Joined Jan 2010
I am thinking of getting a Mini CP but am a bit worried about the feed backs on the Devo 8. I wonder how does the screen brightness of the Devo 8 compares to the Devo 6 and Devo 12? Also, what is the effective flight time for the MIni CPs. My vendor claims a fight time of up to 4 minutes but he is not using a 100% flat throttle curve.
Tokyo
Joined Jan 2010
I'm sure they fixed problems without telling us...not just upgrading the radio module to the telemetry module. If you have a chance at all I would suggest handling it first (hobby shop, field, etc.). Some people rave about it, but I have also seen complaints: 1) Screen difficult to see outside 2) No timer mapping to throttle input 3) Battery can fall out of the battery cage. Flight time on stock mini with stock battery is poop...about 2m30s for me. However, I like the way it flies so I don't care much. I also get longer run times (~3m30s) with the fullriver 350mah 25C batteries (hard to find, see my blog). I was running a c05 but bent the shaft. Currently flying stock until more motors arrive (bl inrunners I'm going to test). p.s. I have a devo 6 and have a 6s on the way. Plan to use the 6 as a backup. I prefer the smaller form factor and I like the switch layout. |
United States, GA
Joined Dec 2011
Also if you use the GCP main motor in the Mini the flight time almost doubles. Of course the motor is an extra expense.
As far as the main gear I have used both the Mini and the GCP and the change in time is only slight. I like the robustness of the Mini gear better. Moto |
Australia
Joined Oct 2000
come on Walkera is a win win for all
| Thread Tools | |
| Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX | Tom Z | Micro Helis | 471 | Apr 26, 2013 05:05 PM |
| Wanted Nine Eagles Solo Pro 100d 3g or similar heli like mCPX or Genius CP | gaaunapoi | Aircraft - Electric - Helis (FS/W) | 0 | Feb 19, 2012 08:13 PM |
| Discussion NE solo pro v2 vs GW xieda 9958 | mg3 | Micro Helis | 27 | Feb 11, 2012 04:02 AM |
| Question Walkera Mini CP VS Genius CP | unj008 | Electric Heli Talk | 2 | Feb 09, 2012 05:14 PM |
| Discussion Which is better? the Solo pro 100D or the MCP X or the Genius CP | starscream4002 | Micro Helis | 14 | Dec 15, 2011 06:20 AM |
