Old Feb 27, 2012, 12:32 AM
cmdl is online now
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
Flyzone Albatros propeller
My Albatros propeller shaft is angled a bit down. I was unsuccessful in pulling it out of a dive earlier today and it hit the ground nose-first. Any suggestions on how to fix it? I don't know how to take this plane apart to get to the motor area.
cmdl is online now Find More Posts by cmdl
Old Feb 27, 2012, 01:51 AM
Digital Don is offline
Find More Posts by Digital Don
Digital Don's Avatar
United States, IL, Manteno
Joined Dec 2006
It's relatively easy to get it apart.
The fuselage halves are held together with double-faced tape. You can run a hobby knife down seam to separate them.
You must also detach the struts from the wings. The easiest way to do this is at the single point of contact on the bottom wing. Cut through the adhesive around the strut and pull it up. You don't want to cut through the wing so be careful!
Once both struts and the fuselage are free, you'll be able to get inside and see what's going on.
I built an Alabatros from parts and secured the fuselage with silicon adhesive. You can use that when you reassemble yours.
Don
Digital Don is offline Find More Posts by Digital Don
Old Feb 27, 2012, 07:33 AM
Pete Miller is offline
Find More Posts by Pete Miller
Beaumont, TX
Joined Feb 2007
You may not want to "fix" it if it aint broke. It is supposed to have some down thrust.
More help / info here:
http://www.rcgroups.com/forums/showthread.php?t=1236624
Pete Miller is offline Find More Posts by Pete Miller
Old Feb 27, 2012, 09:47 PM
Joined Dec 2006
I agree 100% Pete.
In his picture though, there seems to be a lot more space at the top of the spinner than at the bottom. That's not correct. I'd guess that the gearbox has either come loose or been pushed back.
If the gearbox is still secure and the spinner is not rubbing on the nose, it's OK. If not, at least he knows how to open it up!
Don
Old Feb 28, 2012, 07:08 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
I third the above. the DVa can use all the downthrust it can get. If the gearbox is solid, just fliegen ist.
UNGN is offline Find More Posts by UNGN
Old Feb 28, 2012, 03:59 PM
cmdl is online now
cmdl's Avatar
Joined Jan 2012
Thanks guys. I appreciate the responses and have been reading several of your posts in the thread cited by Pete (I actually went through all 50+ pages yesterday).
The white propeller/nose cone had been rubbing against the bottom fuselage end but with gentle pushing I managed to get it to the point it is in the picture. Didn't dare do more than that and after all your advice I think I will leave it as it is after all. And as Don said, if I need to then at least now I know how to take it apart.
Appreciate all the help.
Discussion Flyzone Albatros mikeflys Micro Ready-to-Fly 67 Jul 03, 2012 01:37 PM
Discussion which one; flyzone albatros or playmate? rcguy1234 Micro Ready-to-Fly 13 Feb 10, 2012 10:31 PM
Help! Flyzone Albatros Loose Propeller mu2freighter Micro Ready-to-Fly 3 Aug 07, 2011 06:56 PM
Discussion FlyZone Albatros Brushless Conversion Thread barmonkey Micro Ready-to-Fly 88 Jun 03, 2011 09:11 PM
Found Trade my Flyzone Playmate for your Flyzone Albatros Flyboy70 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Sep 07, 2010 05:25 PM
