Old Feb 27, 2012, 12:05 AM
congcon97 is offline
Find More Posts by congcon97
Joined Jun 2007
Accucel-6 can charges Li-On cell?
Does it charge Li-On batt? Talking abt cell phone battery? In the ad it says it does .
I bought this charger but in its menu it doesn't say LiOn. It says liFe & Lipo only.
Can I charge cell phone battery with this charger?
congcon97 is offline Find More Posts by congcon97
Old Feb 27, 2012, 05:25 AM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
The answer is "possibly", but you need to know more about your cellphone battery to be sure. Li-on is a generic term for a battery with lithium in it; LiFe and LiPo are more-specific terms for two different types of lithium batteries which we generally use in our hobby.
I've got a cellphone battery beside me which on its label says "Rechargable Lithium-ion battery ... 3.7VDC ... 1500mAh Max". Without more research I don't know if it's LiFe, LiPo, or Li-somethingelse; though 3.7v suggests that it's LiPo because other Li batteries I've used (A123 and Saphion) have different nominal voltages.
Hopefully someone who's done it will chip in. But, unless they do, I wouldn't seriously try charging it any way other than through my phone (which has a balancing circuit inside it, I believe) with a charger that's designed for the job.
abenn is online now Find More Posts by abenn
Old Feb 27, 2012, 06:21 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
If its anything like my charger (AC6) you need to access the menu option and change the voltage of Li-batteries.
Lilo voltage level: 3.6V/cell
LiPo voltage level: 3.7V/cell
LiFe voltage level: 3.3V/cell
Then when you go back to the Lixx battery charging menu it should be relabeled accrodingly.
freechip is offline Find More Posts by freechip
Old Feb 27, 2012, 06:34 AM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Scroll through till it says ( user set), then go to (li**V type), It will show the 3 types of batts by voltage. when you hit (voltage) it will show 3.7, 3.6 ,and 3.3 Pick the 3.6 for your Li-ion batts.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Feb 27, 2012, 11:59 AM
Joined Jun 2007
Thanks guys. I found it helpful
Old Oct 29, 2012, 07:46 PM
TheSelf is offline
Find More Posts by TheSelf
Los Angeles, CA
Joined Jan 2011
I'm trying to figure this out too- how would anyone suggest physically connecting the battery charger to my big new samusung galaxy note 2 3100 mAh spare Lithium ion battery? The terminals are tiny ( see picture of the battery at this site: http://www.clove.co.uk/product-image...-sam-n2bat.jpg ) - in the picture you can see there are 3 terminals- the 'positive' and 'negative' terminals are marked- what's the middle one? It would be great if there is a way to connect/ charge my spare batteries and not have to purchase an external cell phone battery charger that only charge at 0.5A when I could charge at 3.1A with this... Am I right in thinking these batteries are all '1cells'/1S'? - on the back it says"3.8V Li-ion" - I take it that means a 1S ( so no balancing required)- the accucel charger is supposed to charge Li-ion batteries but what setting is 3.8V? - that appears as 0.1V higher than even Lipos..?
Grateful for any feedback!
TheSelf is offline Find More Posts by TheSelf
Discussion How do you charge 1S Lipo on Accucel-6 msdumo Power Systems 7 Nov 14, 2011 05:47 PM
Discussion How can I figure out what "C" an accucel 6 charges at? Supercubflyer Batteries and Chargers 2 Nov 10, 2011 09:39 PM
Discussion Imax B6-Pro 6-Cell Li-PO charger dkrhardy Batteries and Chargers 0 May 13, 2011 03:53 PM
Wanted Accucel-6, Accucel-8, or similar AUaero Aircraft - Electric - Batteries & Chargers (FS/W) 2 Mar 31, 2011 11:47 AM
Discussion 3 Cell Pack only charges on 2 Cell Setting? Basil Batteries and Chargers 10 Feb 20, 2006 08:54 PM
