Feb 26, 2012, 10:56 PM
United States, PA, Punxsutawney
Joined Feb 2012
DURATRAX PARTS (evader, warhammer, fire hammer and more)
recently bought out a hobby shop and got alot of duratrax parts
listed all items in truck groupings. prices are shipped for each item in line
more you buy lower the price, and if the price is to high shoot me an offer
if you wanna buy it all as alot will make a killer deal on it. pm me what ya need and i'll be happy to get back to you
item # qty. description price each shipped
dtxc2526 1 clutch bell 18t $9
dtxc6186 1 ball cap 12 (sfgp2) $2
dtxc6810 2 bulk head front l & r $4
dtxc6811 2 bulk head l & r $5
dtxc6813 1 ft bulk head set (sfcp2) $6
dtxc7140 1 clutch bell 15t $8
dtxc7146 1 clutch bell w/o gears (2spd) $8
dtxc7147 1 clutch bell gear 15t $4.50
dtxc7150 1 clutch shoes $5
dtxc7160 2 clutch shoe spring $2
dtxc7200 1 counter gear $3
dtxc7350 1 diff. balls 1/8 (10) $2
dtxc7352 1 diff balls carbide $5
dtxc7361 1 diff case plastic $2
dtxc7368 2 diff joint long $3.50
dtxc7369 3 diff joint short $3.50
dtxc7381 1 diff pinion gear $6
dtxc7396 1 diff, screw & lockwasher (2) $1.50
dtxc7441 1 thrust balls carbide 6 $6
dtxc7451 1 center drive shaft ( vendetta ) $5
dtxc7897 2 gearbox bulkhead set $6
dtxc7900 2 gearcase $6
dtxc8254 1 manifold for tuned pipe ( maximam ) $5
dtxc8301 1 main gear 51t $5
dtxc8302 1 main gear 51t steel $20
dtxc8882 3 servo saver post left $2.50
dtxc8894 1 high rate servo saver $5
dtxc9140 1 shock shaft frt 2 $2.50
dtxc9145 1 shock shaft rear 2 $2.50
dtxc9195 2 shock tower ft $3
dtxc9252 2 shock tower rear $3
dtxc9300 1 slipper adjustment spring $4
dtxc9320 1 slipper pad (mx-mt/st) $2.50
dtxc9387 1 spring pin 2.5x12mm (10) $1.50
dtxc9390 1 spur gear 48t (2spd) $3
dtxc9400 2 spur gear 52t $2
dtxc9402 1 spur gear 52t metal $7
dtxc9407 1 spur gear 56t (2spd) $2
dtxc9410 1 spur gear 42t (2spd) $2
dtxc9414 1 spur gear mount (tq) $5
dtxc9416 1 stabilizer bar kit 2mm $5
dtxc9470 1 steering joint pin 2 (tq) $1
dtxc9548 3 suspension arm ft (2) $3
dtxc9660 4 suspension arm mount (2) $2
dtxc9691 6 tie rod joint male 2 (tq) $2
dtxc9692 3 tie rod joint female 2 (tq) $2
dtxc9744 1 upper arms f/r 2 (tq) $15
dtxc9753 1 turn buck upper 2 $3
dtxc9890 1 wheel w/o wheel caps $10
dtxg0415 1 carb spring $1.50
dtxg0570 1 head button $8
dtxg0595 4 head gasket $1.50
dtxg0635 1 oneway bearing $12
dtxg0640 1 piston pin $1.50
dtxg0771 1 recoil starter shaft G-27cx $10
dtxg0775 1 starter pin $1
dtxg0802 1 throttle arm $2
MICRO STREET FORCE
dtxc7992 1 hinge pin upper (2) $1
dtxc8655 1 2x6mm plate screw (2) $1
dtxc9147 5 front spring hard (2) $3
dtxc9872 1 10 spoke wheel cover $1.50
WARHEAD
dtxc4505 1 fly wheel set purple 10
dtxc6722 2 brake set $2
dtxc6827 1 bulkhead frt $2
dtxc7285 1 cv rebuild kit $2
dtxc7377 2 diff ring gear $6
dtxc7378 2 diff pinion drive unit $2
dtxc7379 1 diff pinion gear $4
dtxc7426 3 small bevel gear set $6
dtxc7427 2 diff joint set $3.50
dtxc7774 1 servo horn set (3) $1
dtxc8037 1 frt hub carriers $2
dtxc8038 6 rear hub carriers $2
dtxc8042 1 lower hinge pin set (8) $2.50
dtxc8043 2 lower hinge pin brace $2
dtxc8044 2 upper hinge pin brace $2
dtxc8817 1 servo mount set (4) $1
dtxc8876 2 servo saver set $2
dtxc9072 1 shock piston $1.50
dtxc9148 1 shock parts $1.50
dtxc9307 1 slipper spring $1
dtxc9398 1 2spd 1st gear 46t $1
dtxc9399 3 2spd 2nd gear 41t $1.50
dtxc9401 3 spur gear 49t $1.50
dtxc9417 2 2spd clutch hardware $1
dtxc9419 1 reverser shift fork $1.50
dtxc9421 1 reverser input $2
dtxc9422 2 reverser lock assembly $25
dtxc9423 2 reverser bevel gear set $8
dtxc9424 2 reverser bearing holder $2
dtxc9425 2 reverser bearing $3.50
dtxc9426 2 reverser output $2
dtxc9490 1 steering block post $4
dtxc9537 1 suspension arm lower $3.50
dtxc9746 1 turn buck 34mm $2.50
dtxp6033 1 super start back plate set $20
FIRE HAMMER
dtxc6863 1 frt bumper $4
dtxc7397 1 diff gear skid $1.50
dtxc9541 2 lwr rear arm set $6
dtxq5001 1 fuel line clip set $1.50
dtxq5012 1 screw set 6x41mm (10) $5
AXIS
dtxc6855 3 bumper $5
ctxc8305 9 pipe holder / spill tray $10
EVADER
dtxc6050 2 adj rear towin / anti squat $20
dtxc6180 1 axle washers $1
dtxc6181 2 ball caps $5
dtxc6290 4 batt strap. (2blk, 1yellow, 1blu) $2
dtxc6297 2 batt. Strap graph $5
dtxc6809 2 bulkhead frt $3
dtxc7015 2 chassis plate rear $4
dtxc7350 1 diff balls 1/8 (10) $2
dtxc7372 1 diff outdrive left $4
dtxc7386 2 diff rebuild kit $4.50
dtxc7402 4 diff gear $2.50
dtxc7440 2 diff thrust ball 1/16 (6) $1.50
dtxc7870 1 gear cover $2.50
dtxc7980 1 heat sink / motor mnt blue $15
dtxc8024 1 hinge pin set ti $14
dtxc8028 1 hinge pin set steel $3
dtxc8034 2 hub carrier graph $7
dtxc8070 3 hub rear $2
dtxc8073 2 hub rear graph $9
dtxc8080 2 idler gear and shaft $1.50
dtxc8199 3 king pin (2) $3
dtxc8220 5 knuckle arm frt $1.50
dtxc8226 2 knuckle arm graph $7
dtxc8261 3 motor brush springs (2) $1.50
dtxc8269 1 motor plate $2
dtxc8274 1 motor plate hard anodized $7
dtxc8791 3 servo brace graph $6
dtxc8884 1 servo saver shaft set $3
dtxc9201 1 shocktower frt (evbx) $3
dtxc9202 1 shocktower rear $3
dtxc9254 1 shocktower frt (evst) $3
dtxc9314 1 slipper plate hard anod $9
dtxc9552 2 suspension arm frt $3.50
dtxc9561 2 suspension arm frt graph $8
dtxc9576 1 swaybar frt $8
dtxc9577 1 swaybar rear $8
dtxc9601 3 swingshaft 85.5mm $6
dtxc9665 1 top shaft gear set $2
dtxc8031 2 hub carrier frt $2
dtxc6415 1 body mount ft $2
dtxc9305 1 slipper bushings $1.50
dtxc9667 2 tranny brace rear $1.50
dtxc6845 1 bumper frt $1.50
dtxc6281 1 battery sponge spaer $1.50
dtxc9452 1 steering bellcrank blue $3.50
dtxc9132 1 shock shaft rear $1.50
dtxc9820 1 turn buck 60mm steel $2.50
dtxc9033 1 shock bushings green $3
dtxc7293 1 diff rings $1.50
dtxc9321 2 slipper pads $2
