Old Feb 26, 2012, 10:19 PM
E-reevo is offline
Find More Posts by E-reevo
E-reevo's Avatar
Joined Aug 2010
Hobbypartz Optima 400 Compared to E-flite 400?
Is there much difference in between these that I missed?
http://www.hobbypartz.com/75m17-opti...215-920kv.html
http://www.e-fliterc.com/Products/De...rodID=EFLM1305
E-reevo is offline Find More Posts by E-reevo
Old Feb 27, 2012, 06:07 PM
E-reevo is offline
E-reevo's Avatar
Joined Aug 2010
Anyone?
Old Feb 28, 2012, 12:49 AM
E-reevo is offline
E-reevo's Avatar
Joined Aug 2010
Bump.
Old Feb 28, 2012, 06:58 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
The E-flite has more believable specs: 13A burst for its maximum is more realistic than the 28A for the Topband/Optima... that said, I've tested quite a few other Topband motors and they are pretty well made... keep the Optima 400 to about 150W and it will be okay.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Feb 28, 2012, 08:20 PM
E-reevo is offline
E-reevo's Avatar
Joined Aug 2010
I would be putting it in a Slow Stick, I just wanted to try and keep it as light as possible.
Old Feb 29, 2012, 07:12 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
For 3s, I'd start with 9x5 GWS HD... then 10x6 GWS HD... check the amp draw but you might even get away with 11x7 GWS HD... that's what I use with my SlowStick using an AXI 2212/34... but then again I only draw ~10A because my AXI is only ~740Kv.
Discussion Whats Hobbypartz closest motor to a E-flite 400 and 450? E-reevo Power Systems 9 Dec 13, 2011 01:30 PM
Discussion Turnigy 130 maH Size Compared To E-Flite 120 maH? edwong3 Micro Helis 2 Jun 19, 2011 10:51 PM
Discussion Hobbypartz Optima 450 1380kv on 6S? SidewaysLS4 Power Systems 5 Aug 19, 2010 10:17 AM
Sold E-Flite Park 400-4200kV in an E-Flite 6.6:1 gearbox turbodriven Aircraft - Electric - Power Systems (FS/W) 0 Oct 07, 2007 11:33 AM
E-Flite Park 370 Brushless Motor Question compared to Himax Zachary Power Systems 9 Oct 05, 2004 03:20 PM
