Old Feb 26, 2012, 09:24 PM
g3f0rc3 is offline
Find More Posts by g3f0rc3
g3f0rc3's Avatar
United States, AZ, Phoenix
Joined Sep 2010
Help!
landing gear on an fpv radian. need advice. ne1 try it?
any 1 try landing gear on an fpv radian? couldn't possibly add much more drag than a gopro. any one whose tried a tricycle landing gear, which hardware did you use? i was thinking about getting the "heavy duty dubro landing gear". wasnt sure tho if it was to big. i need advice! or should i just hot glue some cardboard to the bottom and use it as a skid plate? see where i fly is zero grass and lots of pebbles that is ruining bottom of the foam.. even duct tape gets sanded off i h8 the desert lol.
g3f0rc3 is offline Find More Posts by g3f0rc3
Old Feb 27, 2012, 04:27 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Do you have just pebbles that it needs to clear??
When I had my easy star, I just pushed a pushrod tube through the foam near the bottom, then put a fiberglass rod through that. I put Slow Stick wheels on the rod, which kept the rod in place. This was just enough to clear short debris on the ground, but added almost no weight and very little drag. I think I either just used a skid or small tail wheel for the back.
ashdec87 is offline Find More Posts by ashdec87
Old Feb 27, 2012, 04:45 PM
g3f0rc3 is offline
g3f0rc3's Avatar
Joined Sep 2010
thats a good idea! i may try it and experiment. the dubro landing gears look kinda stiff. might be a problem for foam. so ill try and use the slow stick landing gear since its spongy. also, yeah just pebbles, small dried up twigs, and dried up scattered tumbleweed.
Old Feb 27, 2012, 07:59 PM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
just get some white glue & add a couple mil plastic skidplate. landing gear will just rip the foam to pieces the first time it catches
Toysrme is offline Find More Posts by Toysrme
Old Feb 27, 2012, 09:38 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
no no, not the landing gear.. just the wheels. Its pretty much just a straight axle going through the plane. There's nothing there to catch on anything.
Old Feb 27, 2012, 11:48 PM
aaronredbaron is offline
Find More Posts by aaronredbaron
Spektrum Dev Team
aaronredbaron's Avatar
United States, IL, Champaign
Joined Apr 2002
here is my buddy Rob's solution, makes it a very versatile model. He started with a wing mounted landing gear setup, but that was very prone to nosing over
aaronredbaron is offline Find More Posts by aaronredbaron
Old Aug 19, 2016, 05:29 PM
Bruce Gerow is offline
Find More Posts by Bruce Gerow
Joined May 2013
Hi, Is there a pic of this somewhere?
It sounds great!
Bruce Gerow is offline Find More Posts by Bruce Gerow
Help! Need advice on FPV Groundstation and ImmersionRC PowerBox nk4787 FPV Talk 1 Sep 04, 2013 10:27 AM
Discussion Need advice on which motor to buy for an EXI 450 jedi391 Mini Helis 8 May 31, 2011 08:41 PM
Help! Need advice on repairing laser cut plywood parts in fuselage/CF landing gear racemx43 Crash Discussion 4 May 21, 2010 10:42 AM
Discussion My thoughts on the Parkzone Radian as an FPV platform & request for next model ideas Craig9080 FPV Talk 20 Jan 12, 2010 04:46 PM
