United States, NY, Albany
Joined Jan 2013
Props off. Made new Model Called it Test.
Motor at C1=none Tail Type=normal Aile/flpas=1Ail Brake Off+100%=In1 On the original setup I had: Motor at C1=front Tail Type=normal Aile/flpas=1Ail Brake Off+14%=In1 (not sure how this got to this value, I think I messed around with no change on results) These are Airplane not Heli types. That works for my Cinestar |
Ok great So here is what we will do first
ok step one if you have not done this sync your rec with your radio 2 plug the USB cable into the MC on your Quad but don't plug it into the Computer.\ 3. turn on your Radio. 4, make sure all switches and control knobs are at 0 and that your throttle is in the down position. 5 plug the the USB cable into your computer now. 6 launch the bumble bee software. |
No Problem Its all about giving back! I have a DJI f330 a Dualsky 460 a Bumble bee and to be honest once setup they all do well The crazy stuff is the DJI Naza with GPS you can send your Quad away and then just flip a switch and it comes home. And if your into video you can head lock it so even if you turn your quad to the left and are shooting video you can pull the stick back and the quad will stay pointed left but come back to you in a straight line. |
The Bumble Bee is a clone of the naza (no GPS no gimble) but 100% looks like a Naza on teh outside.
The software is 99% the same setup also I tried to hook my Naza up to my BB and almost lost a finger the motors would fire full speed just pluging in the battery. Then I read they did not work together. I might switch out the ESC's and upgrade at one point as the GPS lock on real good outside and the quad just sits there with almost 0 drift in any direction. |
Yes it was a big nightmare for me at the begining to try and fly the BB with the stock esc and a naza. I confirm and trust me : DJI NAZA and Hobbylord BB ESC are incompatibles ! Check this post : http://www.rcgroups.com/forums/showp...&postcount=339 cheers. ps: Bumblebee quad is not a bad multirotor if you got lot of knowledge of what you do and have a lot of time to improve flights and setting. |
The big problem was that the props that came with the kit are Hobbycool ST1038R & P type which do not match up to the motor or prop adapters. They have flat spots inside the hub that were to match up to the motor housing which the Hobbymates don't have. |
Blue Bell, PA
Joined Aug 2002
Bumblebee unstable
I have my Bumblebee 550 built and calibrated
First flights have been instant flip overs! any suggestions? Props --- Got a good source for props? 1038 props seem rare and center hole seems special Are there super flexible "learner" props? folding props This is going to be real expensive buying props Tnx Cozmic |
United States, TX, Katy
Joined Aug 2009
I purchase a Bumble bee 550 kit from Hobbyking some time ago, at the end I put 4 Turnigy Plush and the following Motors from RCTimer:
http://www.rctimer.com/index.php?gOo...9&productname= Using a 4s setup (5000mah 25c) with 11x4.5 Carbon Finer props. It flys very very good getting 10min+ with all the FPV gear (also using Naza as the controller) I really recomend this setup ![]() Quote:
| Thread Tools | |
| Build Log Bob Starr Bumble Bee ---video added--- | MIT KID | Indoor and Micro Models | 33 | Mar 17, 2013 06:00 PM |
| Bumble Bee - It's CUTE !! | ChrisP | Parkflyers | 26 | Jul 19, 2006 04:07 PM |
| Hobby-Lobby Bumble Bee | ratman | Parkflyers | 3 | Jun 12, 2002 05:42 PM |
| Hobby Lobby Bumble Bee Twin | Tom Smith | Foamies (Kits) | 12 | May 10, 2002 11:23 AM |
| Hobby Lobby Bumble Bee ? | Tom Smith | Parkflyers | 1 | May 06, 2002 03:34 PM |
