Old Aug 31, 2012, 05:37 AM
dambit is offline
Find More Posts by dambit
Most people are stupid!
dambit's Avatar
United Arab Emirates, Dubai
Joined Oct 2011
I am using the stock ESC's.
I had had several flights after I tried 4 cell and they were all great flights. I'm pretty confused as to what could be the problem. The ESC is getting power, but seems to not be receiving any signals from the controller. I have tested the other motors in the #3 slot and they all work fine, so it's not an issue with the controller, I'll recheck the solder joints etc.
dambit is offline Find More Posts by dambit
Old Aug 31, 2012, 05:50 AM
RolandGarros is offline
Find More Posts by RolandGarros
Peter
Sweden, Västra Götaland County, Gothenburg
Joined Dec 2011
The motors are spec. for 2-3S
http://www.b2bage.com/product-toy-pa...uadcopter.html
I would have swapped #3 motor with another one and tried it out. To see if the motor is burned or not. Hopefully its just a bad connection somewhere.
RolandGarros is offline Find More Posts by RolandGarros
Old Aug 31, 2012, 06:39 AM
dambit is offline
dambit's Avatar
Joined Oct 2011
Just checked the motor as suggested and it works fine. I think I'll just order a new esc and that'll be that.
Bit annoyed though as I can't find a direct reason for the issue.
Old Aug 31, 2012, 08:17 AM
Peter
Joined Dec 2011
If you run 4s instead of 3, of course you will draw more amps and maybe the ESC dont like that. But they are rated 20A so I think it should be ok, cause motors are rated 12A.
Old Aug 31, 2012, 08:41 AM
dambit is offline
dambit's Avatar
Joined Oct 2011
I don't think the 4s was the issue cause I was very gentle with the throttle and it worked for three more flights on 3s afterwards.
Oh well, ESC's are cheap.
Old Aug 31, 2012, 09:46 AM
Peter
Joined Dec 2011
Do you use the stock props? I used them until now, but I will change to Graupner E-prop 10x5. I read that stock props are not good and break easy during flight. I havent installed them yet but maybe this weekend. The olny issue is that you have to drill/bore them to 9 mm to get them to fit on the motors. I have no reamer tool so i use a drill and drill by hand and hope it will be centered.
Old Aug 31, 2012, 09:52 AM
dambit is offline
dambit's Avatar
Joined Oct 2011
I used the stock props and found them to be very good. I had a few flip overs today and they didn't break. I will be getting some spares though just in case
Old Aug 31, 2012, 11:51 AM
Peter
Joined Dec 2011
The problem seems that they will "explode" during flight, cause they wear out over time. Maybe visual inspection of the props is good b4 flight. Anyway, I read so much good about E-props so I will try them out.
Old Aug 31, 2012, 09:32 PM
dambit is offline
dambit's Avatar
Joined Oct 2011
I think as long as the props do the job that's good enough for me. Once I get this ESC thing sorted out I will be trying other prop combinations.
I powered up the quad this morning, and the problem esc actually worked.... for all of 5 seconds.
Now it's doing nothing again except blinking at me (slower than the others)
Old Aug 31, 2012, 10:33 PM
dambit is offline
dambit's Avatar
Joined Oct 2011
Ok Just thought I would power it up to see what would happen, and it worked
I had two great flights and then all of a sudden #3 ESC cuts out again.
Not sure what the deal is, but I will be definitely replacing it. I tell you what, this is one tough airframe.
Old Sep 01, 2012, 01:59 AM
Peter
Joined Dec 2011
Ok, I havent crashed yet but I am sure it will come. Unfortunally, I will not have much time to fly in the near future.
I guess you use BumbleBee FC? AS I said I will uses Naza GPS and think the GPS antenna will break if I crash. I can mount it inside the cover of BB, but its very sensitive and should be away from other electronics so I think I mount it on top of the cover.
Old Sep 01, 2012, 02:02 AM
Peter
Joined Dec 2011
Btw, whats the capacity of the battery you are using and what flight time do you get?
Old Sep 01, 2012, 03:19 AM
dambit is offline
dambit's Avatar
Joined Oct 2011
At the moment I am using a 2600mAh 3s. i get around 7 min flight time and then the battery cells are at 3.65V
I seem to have sorted the ESC issue. I plugged into the computer again today and re installed the firmware. It all seems to be working fine now. Still confused as to why it went weird though.
Cheers,
Steve
Old Sep 09, 2012, 05:18 PM
aeroseb is offline
Find More Posts by aeroseb
fly to the moon :)
aeroseb's Avatar
Canada, QC, Terrebonne
Joined Apr 2009
Cut or no cut?
deleted
aeroseb is offline Find More Posts by aeroseb
Old Sep 10, 2012, 10:31 AM
Peter
Joined Dec 2011
Originally Posted by aeroseb View Post
I bought a DJI naza FC to fit on the st550 bumblebee quad with the stock motors and stock esc from the kit(20A, http://www.hobbylord.com/en/20A_en.html). Do i need to remove the red wire from the esc to the FC to make the system safe or i can leave them without taking chance to brake the naza FC ? Thks in advance.
I am not sure about BB stock ESC, i use DJI ESC. I also use Naza on my Quad and I am happy with it.
Will you use stock props?
Build Log Bob Starr Bumble Bee ---video added--- AJWoods Scratchbuilt Indoor and Micro Models 36 Aug 14, 2013 10:58 AM
Bumble Bee - It's CUTE !! ChrisP Parkflyers 26 Jul 19, 2006 04:07 PM
Hobby-Lobby Bumble Bee ratman Parkflyers 3 Jun 12, 2002 05:42 PM
Hobby Lobby Bumble Bee Twin Tom Smith Foamies (Kits) 12 May 10, 2002 11:23 AM
Hobby Lobby Bumble Bee ? Tom Smith Parkflyers 1 May 06, 2002 03:34 PM
