Old Sep 28, 2012, 08:43 PM
arrowking is offline
Find More Posts by arrowking
Joined Mar 2011
I'm not distributing the dwgs yets, but I will soon. In the mean time, the bulkhead dwgs I used to base mine on can be found on the first post of this thread!
arrowking is offline Find More Posts by arrowking
Old Sep 28, 2012, 09:14 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Okely Doke!
Keenan smith is offline Find More Posts by Keenan smith
Old Sep 29, 2012, 11:07 AM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
um, isnt using the intake duct for support for the front gear asking for trouble on any hard landing,
D_FAST is offline Find More Posts by D_FAST
Old Sep 29, 2012, 11:41 AM
Joined Mar 2011
That's a good point. I don't see any other alternative, there just is no space and nothing else to provide support.
I'm not worried, the duct in this area has a lot of strength, due to shape and thickness of the duct in that area. I'm also planning to help prevent crushing the duct with a load bearing member like in the real thing:
I'm assuming that's a load bearing member... Looks kinda flimsy in the real thing... Anyone know what that bar in the intake is designed for?
Old Sep 29, 2012, 05:28 PM
St. Martin is online now
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
I would think it is to stiffen the intake area against collapse or intake flutter?
Fuzz
St. Martin is online now Find More Posts by St. Martin
Old Sep 29, 2012, 09:53 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
I wouldn't like to use the duct as a structural member. Too flexible.
You have two bulkhead either side of the retract. If they were made nice and tough (bagged ply for example), they would give a much better structural solution.
As a rough estimate, the nose gear should be able to take the whole weight of your aircraft. That will allow somewhere in the vicinity of 5-10g on landing. anything over 3 is "hard", so that gives a bit of safety margin.
Do you have any carbon? That makes quick work of stiffening things up
Odysis is offline Find More Posts by Odysis
Old Sep 30, 2012, 02:13 PM
Joined Mar 2011
I thought about using plywood for those bulkheads, the problem was that the wood solution is heavier and wood is harder to work with. It came down to making a design decision.
Plywood former support
Pros:
-minimise crushing loads on duct,
Cons:
-cutting wood by hand sucks.
-Because formers must be split to insert the duct, extra reinforcement is required.
-extra weight
-not much wood to play with, must rely on glue for strength.
Intake duct as structural member
Pros:
-less work
-duct shape inherently stiff
-only need extra fiberglass for reinforcement around front gear area
-simple
Cons:
-compressive loads + suction load = trouble
-a vertical "anti-collapse member" inside duct may be needed.
I keep saying to myself the goal is minimize mass to minimize loads. My estimates/goal points to ~1.5 kg. The lighter weight/easier solution won out. I'll let you know how it works out for me.
If I decide to release the plans under an open license, other people could modify my design to suit their needs/wishes. If I have a bad experience, I'll modify the design.
Old Sep 30, 2012, 04:43 PM
danj31 is offline
Find More Posts by danj31
Greenwood Indiana
Joined Jun 2004
The bar in the intake is heated for engine anti ice. It is not structural.
danj31 is offline Find More Posts by danj31
Old Sep 30, 2012, 05:44 PM
Joined Mar 2011
ah! I thought that bar was kinda small. Nice tidbit.
Old Sep 30, 2012, 06:57 PM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
ahhhh...thanx!
Old Sep 30, 2012, 07:05 PM
Odysis is offline
Joined May 2007
If you were to put a quart and a half of water in a bottle on the intake duct at the nose gear location, would it bend/collapse/break? That's about the load it'll need to take.
If ply's not on the cards, depron with either lots of glass or carbon works too.
Old Sep 30, 2012, 08:18 PM
Castel101 is offline
Find More Posts by Castel101
Castel101's Avatar
United States, OR, Portland
Joined Sep 2011
It might be the the duct is enough to handle the load without plywood. The problem however is that the duct might hold ok for the first landings but with all the vibration and load maybe cracks would start to form overtime? Maybe not, the design looks great so far though!
Castel101 is offline Find More Posts by Castel101
Old Oct 02, 2012, 11:19 AM
Joined Mar 2011
Perhaps it'll be reassuring to hear that the rear gear is mounted to plywood parts that transmits the load to the two longitudinal bars.
In modelling-speak, what would you call the two main structural members which all the formers are mounted to?
Old Oct 02, 2012, 05:43 PM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
spline maybe, good question
Old Oct 05, 2012, 07:20 PM
Joined Mar 2011
My prototype has fiber glass reinforced formers to provide reinforcement for the rear gear. It's plenty strong for a bit of testing, but it really should have plywood reinforcement like my dwgs call for.
I need a CNC machine
Sold F-16 and F-86 80mm edf airframes drats Aircraft - Electric - Jets (FS/W) 3 Jul 03, 2012 04:13 AM
For Sale F-16 and F-86 80mm edfs drats Aircraft - Electric - Jets (FS/W) 3 Jun 28, 2012 11:24 PM
