Old Feb 26, 2012, 03:52 PM
Jam1e is offline
Find More Posts by Jam1e
Worcestershire, England
Joined Nov 2007
Help!
SAITO FG-14/82 Petrol/Gas A Good Motor???
Hi folks,
I'm after a few constructive opinions on an engine i'm considering.
As above it's the Saito FG-14/82 Petrol/Gas engine with electronic ignition.
I've heard Saito's are top engines, yet i've read a few posts indicating the first batch of this particular model had ignition issues, and/or fueling problems causing poor running.
I've read a few posts i've found, but in all honesty i didn't understand much of what was said as i know very little about 4 strokes and the terminology used with it.
The engines back plate has been mentioned as a problem as it's plastic, yet mine is alluminium.
Any help would be appreciated
Jam1e is offline Find More Posts by Jam1e
Old Feb 26, 2012, 08:26 PM
MercerMaggot is offline
Find More Posts by MercerMaggot
Canberra Australia
Joined Jun 2009
Have a look at RCuniverse under gas engines. There are a few threads on the FG-14. Basically, the engines are fine, but can be fiddly to tune if you are new to 4-strokes and gas. It might be worthwhile checking out if someone can help you at your club. The fuel tubing and set-up is different to nitro and can be confusing.
MercerMaggot is offline Find More Posts by MercerMaggot
Old Feb 27, 2012, 03:05 AM
Jam1e is offline
Joined Nov 2007
Thanks alot.
Will do.
Old Feb 27, 2012, 07:28 PM
Fokker DII is offline
Find More Posts by Fokker DII
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
I run an FG 14 in a .61 Escapade. Love the engine. It needs to be tuned VERY SLOWLY and only after a few hours of break in before it settles down. When "fiddling" with the needles, do the high speed first then the low. SMALL adjustments, such as a single click of the HS and less than 1/8 turn of the LS are in order once you are close. Once set, it Never needs fiddling with again. Enjoy.
Fokker DII is offline Find More Posts by Fokker DII
Wanted Saito fg 14 PontiusPilate Aircraft - Fuel - Engines and Accessories (FS/W) 3 Feb 20, 2012 11:46 PM
Sold piper pawnee and saito fg 14 gas 4 stroke skypup Aircraft - General - Miscellaneous (FS/W) 2 Sep 30, 2011 10:53 AM
Sold saito fg 14 gas 4 stroke/combo skypup Aircraft - Fuel - Engines and Accessories (FS/W) 1 Sep 30, 2011 10:48 AM
Discussion Ignition module for Saito FG 14 Fokker DII Engines 2 Aug 09, 2011 04:51 PM
Discussion Saito FG 14? skypup Engines 7 Mar 07, 2011 05:47 AM
