Old Feb 26, 2012, 02:11 PM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
the A-10 designed and cut by cnc .
We joked at little about doing it. and the hell took me and did it.
Jonas is going to assemble it, when he have finished the Crusader.
Here it is with helping tools for wingsadle cut out as well as the elevator cut out.
and naturally support block for the tail when you work on the model.
More details will follow.
Claus
clausxpf is offline Find More Posts by clausxpf
Old Feb 26, 2012, 02:47 PM
jweber009 is offline
Find More Posts by jweber009
PH.D in Scratchbuilding
Denmark, Region Zealand, Holbaek
Joined Sep 2005
Just a little additional pictures....
jweber009 is offline Find More Posts by jweber009
Old Feb 26, 2012, 07:14 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
nice to see an A-10 being done with this construction method. deffinitely watching this one.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Feb 27, 2012, 06:48 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Lighter wings
the accuracy of cnc makes hollow wings real possible.
the solid 97 grams
the hollow 60 grams.
Claus
Old Feb 27, 2012, 09:55 AM
frank40 is offline
Find More Posts by frank40
frank40's Avatar
Denmark
Joined Sep 2005
I have seen this with my own eyes and the cutting and prework is awesome, relay not much other than glue it together. Awesome work!!!
frank40 is offline Find More Posts by frank40
Old Feb 28, 2012, 10:33 AM
Ronys is offline
Find More Posts by Ronys
Depron Panda
Ronys's Avatar
Ramat Hasharon, Israel
Joined Feb 2006
This is very nice.
What software are you using for the design and for the CNC cutting?
Rony
Ronys is offline Find More Posts by Ronys
Old Feb 28, 2012, 02:26 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Rony.
we are using Rhino with an ad on from Joergen Vendorf, that creates the G-codes-
and it works in next to no time .
Claus
Old Mar 07, 2012, 07:46 PM
Lojik is offline
Find More Posts by Lojik
Hope is not a Strategy
Lojik's Avatar
Australia, VIC, Caroline Springs
Joined Apr 2011
Very nice, what size is it going to be in the end?
any idea on what edf's you are going to use 70's, 90's?
I'd be interested in maybe purchasing one if your thinking of selling a set.
Lojik is offline Find More Posts by Lojik
Old Mar 07, 2012, 08:08 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
another cool Claus XPF project ...i always wanted to try hollowed out wing cores like that
Can you show us a pic of the CNC foam Cutter?
AIR SALLY is online now Find More Posts by AIR SALLY
Old Mar 08, 2012, 11:49 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
the way we do it here.
The A-10 is designed for 2 X 70 mm fans (wm400)
but should be able to take all 70 mm fans tractors as well as pushers.
Size is 1500 X1500 mm ( 5' x5')
the whole idea with this project is to see can i make them like industrie.
and pack i down in a box that does not kill the project by too high costs for transport .
all of this model is done a simple cnc hot wire cutter.
Later it will be done on the combo router/ hot wire cutter as it would run double as fast as the one i use right now.
http://www.rcgroups.com/forums/showthread.php?t=1585260
it is made in the living room, the garden house & and the lathe.
Old Mar 08, 2012, 11:52 AM
Joined Jan 2009
Claus,
have you seen the way qwerty cuts his kits? he uses the CNC machine to make all the cuts, but leaves the cut material inside, so basically, he ships the cut pieces inside the block it was cut from. is this a possibility for you too?
Old Mar 08, 2012, 05:01 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
that would be fully possible but at a cost..as the box would be bigger
Claus
Old Mar 08, 2012, 06:05 PM
podiumjets is offline
Find More Posts by podiumjets
Romnia, Bihor, Oradea
Joined Feb 2011
Hi there Claus,
Shipping will get you in trouble like this. Customers will receive their models trashed.
You have 2 options:
a) - to fill the box with foam leftovers. You can build yourself a sort of a mesh, a nichrome grid, heated up, and just put the leftovers on it. They will melt trough this mesh in smaller sizes. Put the model parts in the box, and then just fill the box up with the leftover foam, like confetti.
b) - leave the parts in the block. You can check qwertys or my method. Also, it'll save you material. While designing your models, just before cutting, do a search on google for nesting software. There are few available, for free. The nesting software will find you the best match of the parts onto the sheet. You save material and time. You can cut a whole fuse with just one cut!
For my models I used both a. and b. methods.
Hope it was helpful.
Take care and good luck with your models.
Mitzu
podiumjets is offline Find More Posts by podiumjets
Old Mar 09, 2012, 07:05 PM
Joined Jan 2009
it's great to see you around Mitzu. glad you didn't go anywhere. can't wait to see what you've got up your sleeve next.
Rich
Old Mar 09, 2012, 07:27 PM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
I want one of those cnc's!! Gimmie!!
D_FAST is offline Find More Posts by D_FAST
For Sale West Wings Orion HLG CNC cut kit Bud Morrison Aircraft - Sailplanes (FS/W) 0 Nov 28, 2011 12:51 PM
Discussion Has anyone done a DIY CNC machine to cut out foam? NeveSSL Foamies (Scratchbuilt) 6 Nov 15, 2011 10:14 PM
Help! Need someone to cut a few CNC G-10 parts for me. badbill CAD/CAM 2 Mar 20, 2011 11:30 AM
Discussion Micro Ultimate Biplane cut by CNC *KIT available now* jusos Scratchbuilt Indoor and Micro Models 45 Jan 28, 2011 06:59 AM
Trying to cut cnc ribs for E-sport 10 Landarts Sport Planes 1 Mar 13, 2004 09:50 AM
