Old Feb 26, 2012, 01:43 PM
hurleybt is offline
Find More Posts by hurleybt
United States, GA, Woodstock
Joined Mar 2007
HK 450 tail servo - shudder / noise
Hey guys... It's been over 2 years since I built or flew one of these things, and I can't remember this bit... I have a HK 450 with an Align, DS 520 on the tail. When I plug the servo directly into the receiver, there is no chatter at all. It's quiet and finds center with no noise.
When I plug the servo into the gyro (HK 401b) and power on, the servo seems to be having difficulty finding center and it chatters incessantly. Is this normal, or could one of you fine gentlemen point me in a good direction?? (I know, I know... the futaba 401 is better...)
Also, there is no slop in the tail and the linkage slides smoothly when not connected to the servo. I've tried different gain settings in my tx and that does not remove the chatter... although cranking up the gain seemed to make it worse.
Also I'm using the Turnigy 9x with the ER9x firmware.
hurleybt is offline Find More Posts by hurleybt
Old Mar 14, 2012, 11:29 AM
zjzc is offline
Find More Posts by zjzc
中国, 云南省, 昆明
Joined Jan 2012
Is it happening on flight? If yes, the gyro may need vibration reduction or the gyro is broken...
If this happens on the ground, maybe the gyro is set in narrow-band mode makes servo rotating~
Have you heard about Tarot GY550 & GY650? Both are good, in surprising price.
zjzc is offline Find More Posts by zjzc
Wanted Need a metal tail servo holders to finish hk-trex450 blueindian Aircraft - Electric - Helis (FS/W) 14 May 09, 2011 11:46 AM
Discussion Tail Servo 450PRO from HK TomSn0w Mini Helis 1 Apr 23, 2011 12:36 PM
Discussion tail wag hk 450 and hk401b gyro hendleyusmc Electric Heli Talk 1 Mar 27, 2011 08:39 AM
Careful! hk 450 gt tail blades flying FinalFrag Mini Helis 12 Mar 26, 2011 10:28 PM
Discussion HK and CopterX 450 Pro: Tail Servo Holder Design Flaw! jomf Mini Helis 3 Jun 03, 2010 04:20 PM
