May 19, 2012, 02:23 PM
Granada Hills Ca.
Joined Nov 2009
Hi Mike
My wood shop friend has a nc router so he can cut me some 3/32" balsa front rib clips that fit in the top & bottom rib bows, then the front will be cut to fit the 3/8" dowel about half way in.
The rib glueing fixture will have a 3/8" pin to locate the front 3/32" balsa clip, so the L.E. shoud be nice and straight.
Still working on a clean small T.E. with out being way too trick for what it needs.Have my mounting & strut brackets worked out so i'am about ready to draw up the wing half's for real.
I'am going to use some .020 small alum 90 dregree brackets with .020 brass nails to hold the ribs to the spars, just like the big guys did in the 30's. Larry Milo has some .020 by 3/32" brass nails that will be perfect for this.
later
G Don
