Old Feb 25, 2012, 10:46 PM
Joined Jul 2010
Tee Dee carb on a Black Widow
Any reason not to fit a tee dee venturi/needle assy on the back of a Black Widow? (Other than having to make a custom backplate that will take a reed in front and threaded for the venturi at the back?).
I notice that most rear-inlet engines have the carb mounted at an upward slant (eg the Queen Bee). Is there any reason for this?
What would the downside of such a conversion be? (I have a couple of BWs without fuel tank/backplate, and would like to use oversize conventional fuel tanks with them).
vh2q is offline Find More Posts by vh2q
Old Feb 26, 2012, 10:30 AM
Canada
Joined Nov 2000
Buy this and screw it on:
http://coxengines.ca/product.php?pro...&cat=25&page=3
Bare is offline Find More Posts by Bare
Old Feb 26, 2012, 10:50 AM
I think you are trying to reinvent the Thermal Hopper.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Feb 27, 2012, 12:54 AM
Joined Jul 2010
Thanks for the suggestion .... however I don't want to do a standard backplate, I want to see if the "trumpet" air intake of the Tee Dee and the multiple spray holes improve the performance of the engine, over the standard backplate design.
Old Feb 27, 2012, 07:29 AM
surfer_kris's Avatar
Sweden
The angled design of the QB is mostly likely from a practical point of view. Easier to prime (there is no access to the exhaust with the muffler on) and easier positioning of the tank.
Again, take a look at the Space Hopper and similar designs;
surfer_kris is offline Find More Posts by surfer_kris
Old Feb 27, 2012, 04:01 PM
"Unnecessary Necessity"
coriolan's Avatar
Canada, BC, Vancouver
Joined Sep 2006
Tarno used to have a motor mount for reedy Cox to accept their carb(same tread as Cox .049/.051 venturi/1/4"-32). They do work(I have two of them)well with venturi!
coriolan is offline Find More Posts by coriolan
Old Feb 27, 2012, 08:29 PM
Canada
Joined Nov 2000
Uhh OK.. I want to see a 21 year old Vixen in my room.
Ain't gonna happen either
Old Feb 27, 2012, 11:11 PM
Cox Engine Hoarder
Jason_WI's Avatar
Neenah, Wisconsin, United States
Joined Jun 2004
You will want the Tarno AR carb. Details can be found here:
http://coxengineforum.forumakers.com...-2-ar-details?
As Bare mentioned above they are hard to find if not almost impossible. Usually command a hefty price on ebay when they do show up.
I did manage to find and buy a Tarno AR but that 21 year old Vixen remains elusive.
Jason_WI is offline Find More Posts by Jason_WI
Old Feb 28, 2012, 12:28 AM
Joined Jul 2010
Well I happen to have a Tarno A carb here (I thought I would try one BW with the Tarno and the other with the Tee Dee venturi/needle) and tonight I turned a backplate to fit on the BW, with a reed (e clip) on one end and threaded for the carb on the other end. By sheer coincidence, it looks a lot like the AR except the round flange is bigger and drilled for the 4 screws that go into the crank case, and I left my carb boss a full .500". However, I wasn't paying close attention (winging it) so I bored the hole .250" which is the major thread diameter on the Tarno carb, not the minor diameter. So I quit in disgust and had a beer. Start over tomorrow. In any case, I like the sheet metal mount and will try to develop my own version of that as well, it calls for a smaller and thinner flange. I hadn't really thought through how I was going to mount my back breathing Black Widow ... I figured I would use the larger flange somehow and a firewall with a hole in it.
Old Feb 28, 2012, 12:46 PM
Actually, you are making at Thermal Hopper, rather than a Space Hopper. Incidentally the carb fittings on the Space Hopper are the same as on the TD. I have checked. I imagine the Thermal Hopper was the same, but don't have one to check. There was a cage mount for the Thermal Hopper.
Old Feb 29, 2012, 09:33 PM
Joined Jul 2010
She Runs!
Solved the turning mistake by boring out the hole and CA'ing in a bushing with the right .250 OD 32 pitch internal thread. Inserted a steel reed and an E clip. Bolted the backplate the the BW, affixed the carb, and made a mount from a piece of brass sheet and bolted the engine to the mount (I should have copied Tarno's solution as I later found out.). Got the assembly screwed to my vise (I use wood shims to hold stuff) and hooked up fuel and electric. Well to my surprise she roared to life and blew the gas tank and the clip off! Some more Heath Robinsoning and I got it to run, but then the engine mounting bolts vibrated loose. After some crawling around, I found the little nuts and bolts on the floor and this time I CA'd the nuts. Got it to run again but the whole head/cylinder assy started rotating off the motor while running! That's where the carb came in handy, I was able to shut down and fix that. Final run was successful, see video. I need to fine tune the air bleed a bit I think. Next step is to put this on a Baby Flite Streak RC and annoy the neighbors. Love that raspy exhaust note - don't know RPM but seemed pretty decent even on 15% nitro
Custom Conversion RC Cox 049 Black Widow (1 min 43 sec)
Old Feb 29, 2012, 10:02 PM
1/2as actually fit in my car
United States, PA, West Grove
Joined Aug 2011
that thing sounds good. kind of makes me wanna do the same thing lol
bushcub is offline Find More Posts by bushcub
Old Mar 03, 2012, 03:52 PM
Canada, ON, Cottam
Joined Jan 2012
Another way to do it is to cut a slot in the tank and just get the needle assembly over the inside venturi stub. I have seen this done and it worked very well with a 1/8" hole in the venturi and a bladder and 80% nitro. Sometimes the fit is just right. It is 1/4". A hole must be drilled to match up with the needle assembly, or if you want to try the three holes, it could be done with a groove as on the original Tee Dee venturi if you have a lathe. The original venturi is not needed at all. You will ruin the tank for anything else, and the plastic backplate is easier to play with.
aspeed is offline Find More Posts by aspeed
Wanted Cox Tee Dee 049/051 Carb. bodies flyer368 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 09, 2011 06:02 PM
Discussion 051 Tee Dee Cloning to a .050 Tee Dee R/C astronomer1 1/2A Planes 17 Sep 16, 2011 07:52 PM
Discussion Cox tee dee black widow phill98765 Control Line 7 Nov 20, 2010 03:08 PM
Tee Dee .020 carb bodies Bipe Flier 1/2A Planes 27 Jan 18, 2005 05:28 AM
WTB Used Cox Tee Dee .049 carb base (black plastic) amike_321 Aircraft - Fuel - Airplanes (FS/W) 3 Dec 18, 2003 01:04 PM
