Old Feb 25, 2012, 07:03 PM
Tr4sHCr4fT is offline
Find More Posts by Tr4sHCr4fT
Joined Feb 2012
Idea
anyone tried 3D/Stereo with 2 Keycams?
after seeing the sophiscated GoPro 3D Adapter which needs 2 HD Heros of course, me came the idea, that should be possible cheaper in DIY too.
take 2 keycams, mount them ~3 inches far away on x-z adjustable holders, then use the usb webcam feature to aling them both on one spot.
the both recorded movies then only need to be synced and merged/converted.
did anyone tried already? i cant, no cams arrived so far, but it will be tested
Tr4sHCr4fT is offline Find More Posts by Tr4sHCr4fT
Old Feb 26, 2012, 01:52 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Yes, VRFlyer, and a similar system is for sale at nghobbies.
Nothing spectacular to have followers, though...
renatoa is online now Find More Posts by renatoa
Old Feb 26, 2012, 02:20 AM
nabazul is offline
Find More Posts by nabazul
Joined Jun 2010
there is one big problem: Both cameras have to be synched while recording so that they are switching their brightness settings at exact the same time. I f you do not do this you will always have brightness different on both cameras.
GoPro is using the synch cable to achieve that and the ng camera is using one controller to control both cameras at the same time. With the currently available keycams there is no way to do it.
nabazul is offline Find More Posts by nabazul
Old Feb 26, 2012, 06:57 AM
Joined Feb 2012
Is there no way to do just do that in software afterwards?
as long as the cameras are pointed to the same spot, the brightness should be rather equal, but one cam can change the aperture earlier/later than the other. so define a max difference threshold and all frames above will be adjusted
Old Feb 26, 2012, 10:23 AM
Ceros007 is offline
Find More Posts by Ceros007
Ceros007's Avatar
Montreal, Québec, Canada
Joined Apr 2010
Use a RaspberryPi.org !
Ceros007 is offline Find More Posts by Ceros007
Old Feb 26, 2012, 12:16 PM
Joined Feb 2012
ok what does that exactly has to do with the topic? xD
Old Feb 27, 2012, 05:02 PM
VRflyer is offline
Find More Posts by VRflyer
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
I Renatoa, glad to see you again
out of topic, but I don`t use the same system with two cmos camera that sold at NGhobbies. That system combine the two camera pictures and send them via one receiver, you need goggle that have 3D capabilities.
My system use two RCV922 ccd camera and I transmit live the two picture via two receivers set on differents channels. My headset was modified, it is like two goggle are combine in one goggle, I mean I connect one receiver output to the left picture of my goggle, and the second receiver output is connect to the right picture of my goggle. I got full 30 frames per secondes. It work very well and I still love it very much. Everyone that I tried my 3D goggle was very satisfy with the result. The reason that no one follow me is obvious, you need to buy two goggles and make one with them...
The NGhobbies 3D camera is not good, I tried it and do not recommend it
I never tried to do 3D video using two keychains
VRflyer is offline Find More Posts by VRflyer
Discussion Stereo Vtx, 1,2/2,4/5,8 GHz Kaspers1 FPV Talk 4 Apr 14, 2011 06:17 PM
Discussion Anyone tried stereo-optic video? helibubba FPV Talk 1 May 30, 2008 02:35 PM
Has anyone tried 3D with a HB CP? Kyle2baseball Micro Helis 0 Jul 29, 2004 07:30 PM
Anyone tried 3D with a GWS PT-17? barnyardflyer 3D Flying 6 Mar 28, 2004 01:27 AM
