Old Feb 25, 2012, 05:05 PM
Austria
Joined Jan 2010
Racewood 900MHz video tx - need to identify damaged SMD component
I have a Racewood 900MHz 500mW video transmitter (possibly the same as Range Video and LawMate units of the same spec?) which I have damaged in a botched attempt to replace the SMA connector. In trying to desolder the connector from the PCB I appear to have used too much heat and inadvertently damaged a nearby SMD component. I believe the component is a capacitor however it has no markings and I have no way to measure the value even if it were functioning correctly.
The attached images are of an identical unit found via Google, my camera couldn't get a clear shot that close. The circled component is what I'm looking to identify. Does anyone know what I need here? Maybe someone is able to calculate the value of a replacement? Thanks in advance!
Similar transmitter: http://www.dronesvision.com/racewood...r-green-label/
Image source: http://esquinaelectronica.blogspot.c...ansmitter.html
altek is offline Find More Posts by altek
Old Feb 26, 2012, 09:20 AM
Canada, ON
Joined Jan 2009
That is a capicator and value would be 100pf.
Martin Y is offline Find More Posts by Martin Y
Old Feb 26, 2012, 10:03 AM
Austria
Joined Jan 2010
Thanks Martin! I saw that value on a 900MHz amplifier schematic but was unsure if it was relevant.
I've taken your word for it and already have a pack of replacements on the way, but as I'm still curious could you please tell me how you worked it out?
Old Feb 26, 2012, 01:35 PM
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
In my (humble, and often wrong) opinion, that SMD cap would be rather difficult to destroy just trying to de-solder the jack, even if you did use a lot of heat. They're pretty rugged. Check for something else, like a trace that lifted from the PCB and is broken, or a solder bridge, something like that. If the new cap doesn't fix it, post some info on exactly what the radio is or isn't doing, and one of the "gurus" on here might be able to point you in the right direction.
Now that I've said all that, the new cap is almost certain to fix it.
dmccormick001 is offline Find More Posts by dmccormick001
Old Feb 26, 2012, 02:03 PM
Austria
Joined Jan 2010
Thanks for the input Dave. Unfortunately there is no question about the cap being destroyed, I just didn't specify how I know because of how embarrassing it is! The contact on one side of the cap is physically missing, presumably in the middle of a glob of solder in the trash, and all that is visible on that side is ceramic and a little circle of something dark and conductive.
Fortunately I have made two very important upgrades since this mishap: I now have a proper temperature controlled soldering station instead of my previous $10 iron, and perhaps even more critically my first pair of much needed reading glasses.
Just as a quick note, I measured the damaged cap and it appears to be 0603 size (1608 metric). The replacements I ordered are here.
Old Feb 26, 2012, 05:06 PM
Canada, ON
Joined Jan 2009
That will work.
Old Feb 27, 2012, 10:46 PM
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
They are fairly rugged after they are soldered on and cooled properly. However, the ends can crack fairly easily due to stresses from soldering especially if cooled too quickly or heated unevenly. I have done quite a lot of commercial PCB bringup and repair and have found very many that were bad with no external signs of a crack. However when replacing the caps one or the other end would fall right off.
jeffs555 is offline Find More Posts by jeffs555
For Sale Racewood 900MHz 500mW Wireless AV Transmitter kevinlib FPV/RPV - Equipment and Vehicles (FS/W) 3 Jul 20, 2011 05:04 PM
Help! Hey, can you guys help me identify this component? Pics included! diret56 Power Systems 2 Apr 29, 2011 08:04 PM
For Sale Like New 900Mhz FPV 2x Video Tx, 500mW Video Tx, WDR600 Sony 550 Line $335 Shipped cbcalhoun Aircraft - General - Miscellaneous (FS/W) 2 Oct 30, 2010 08:56 PM
Discussion 500mW 900Mhz Video TX Need cooling? stevenf Video Piloting (FPV/RPV) 2 Mar 04, 2010 06:47 AM
Discussion Racewood tech, China video TX/RX units. cheap! JustinONE Video Piloting (FPV/RPV) 30 Mar 24, 2009 02:28 PM
