Pete and Sparks.
Nothing that complicated. Just scrap plywood doubled up to obtain the required spacing I needed. Actually the plywood is Russian Birch. I have also seen it labelled as Baltic Birch. It is metric measured and comes in around 18mm thick and 13 layers. Not quite 3/4". The plywood is just some scrap pieces I had left over from when I built my folding field assembly stand. I picked up the Baltic birch plywood from the local Home Depot. Smaller sheets than the 4'x8' were available. I am surprised no one has made a comment about the deck screws to hold the motor to the standoffs. ![]() I do know the screws and standoffs work as I am using a similar setup in a 6s lipo system and have never had an issue. I will post some more pics of the mount tomorrow. ![]() Chris |
Just adding a couple of additional pictures of the motor mount with motor attached.
The mount is secured only with screws in case I need to remove it and add down or side thrust. Two of the screws are hidden under the servo plate. As it stands now the motor is set at 0 degrees. I also added some balsa wedges around the inside of the firewall for strength. Chris |
Time to add an update to this thread.
![]() With most of the front of the Falcon finished it is time to start the work on the tail feathers. Remember the Falcon is a free flight bird and I will be making a lot of changes to the next part of the build so there will be RC control. I will try to add as much detail to the thread with this part of the build of the changes I make. If you guys want extra details on this part do ask. The challenge is to add the control without loosing the original shape which makes it the Plecan Falcon. Also I want to minimize any control rods showing. Starting with the tail ribs. Again from paper cutouts to the balsa ribs. Chris |
Laminating up the leading edges for the stabilizer.
I must say for the size of the plane, the designer sure liked to use thick pieces of balsa. The pic shows two 1/4" pieces being glued together to yield a 1/2" square leading edge that will be tapered down to 3/8" on the outer ribs. Chris |
Have all the pieces cut out to assemble the stabilizer and have them nicely arranged for the picture.
![]() As I did on the wing the leading and trailing edges are notched to accept the ribs. I decided to build the elevator width at 2 3/4" and have cut the necessary amounts off the ribs. I will be building the elevator in two pieces with a wire joiner. As you can see in the picture the three center ribs are first glued in place along with the wire joiner and sleeve. The only other item to mention is the maple key I added for strength between the balsa leading edges where they will be joined together. Chris |
The rest of the ribs are glued into place.
I haven't trimmed back the leading edge ends yet but I will be leaving a 3/16" extention past the last rib on each end of the stab. You can see in the picture the two spars extending past the last rib already. The extensions will help orientate the fin to the correct position and will be a stronger joint by slotting into the fin, instead of just gluing the fin to the side of the last rib. I will have to do a little trimming to the extentions at a later date. Chris |
I am building the Stab a little more solidly than what I normally would. I am a little worried with the fins mounted to the ends of the stab. The fins are also the contact points for the tail section when the Falcon is resting on the ground. I just have visions of something letting go if it is just a regular glue joint. That is why I am adding all the mortise and tenon joints. ![]() Chris |
| Thread Tools | |
| Build Log 1/15th Scale Falcon Model's DH60 "Cirrus Moth" kit Build** | Joe Pierson | Indoor and Micro Models | 49 | Jan 22, 2012 10:42 AM |
| Build Log bobcat/condor/falcon type of scratch build, first ever | eccvets | Pusher Prop Jet Models | 7 | Dec 11, 2011 05:40 AM |
| Build Log bobcat/condor/falcon type of scratch build, first ever | eccvets | Foamies (Scratchbuilt) | 0 | Nov 07, 2011 07:31 PM |
| Discussion to build a LAPIDAR 1940's flyingwing | robin andrew | Scale Electric Planes | 63 | Feb 20, 2010 08:38 AM |
| Build Log buzzard 1940 bombshell fff build | popedan | Foamies (Kits) | 0 | Nov 10, 2009 01:19 PM |
