Old Feb 25, 2012, 09:11 AM
anonamous is offline
Find More Posts by anonamous
cereal killer
Joined Jan 2012
Help!
Turnigy 9x Wont Turn On
I opened my brand new Turnigy 9x box, put eight AA batteries in the holder and nothing happened when I moved the off/on switch to the on position. Several tries later after removing and re-seating the batteries (which I checked in two other transmitters, and the batteries are OK) I was able to get a "SWITCH ERROR" and some beeps, which quickly stopped and then a blank screen.
I downloaded the manual and read it, not much help. I found some pages on the internet that explained the "SWITCH ERROR" message and kinda bashed the manual for no mention of it. I put all the switches in the right position, re-seated all the batteries, moved the switch to the ON position several times, and the screen still stays blank, can't even get beeps.
I know this is a low cost TX and I suspect there is some sort of loose wire or similar issue. I have also seen some threads about how the battery holder is a POS and there are several options to use different batteries.
I am considering simply returning the 9X, but I had to wait over a month for HK to get it in stock and ship it.
Any help welcome.
anonamous is offline Find More Posts by anonamous
Old Feb 25, 2012, 10:10 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
They are so low in price that many will order two just in case one is DOA.
There is a thread and video showing an owner getting a DOA and fixing it. Most likely what you mentioned, loose wire or cold solder joint.
It's up to you what you do with it.
freechip is offline Find More Posts by freechip
Old Feb 25, 2012, 10:51 AM
Lonemountain is offline
Find More Posts by Lonemountain
Lonemountain's Avatar
United States, AZ, Cave Creek
Joined Oct 2001
I've got a Sky Fly TH9X -- same as the Turnigy. I had a similar problem. I boiled mine down to the battery tray and battery connector on the main board. I fine sanded all the connections in the tray and was able to get it working by carefully finding a position in which the leads from the battery tray would work. It's a tight fit with 8 AA batteries and that lousey tray. I've temporarily switched to an 8 cell small NiCd transmitter pack that I had laying around and that fits nicely -- uses KR600AE cells. I'm thinking that won't be my permanent solution, but it's okay for now. Until it is rock solid I'm not flying anything with it. The battery connection to the main board bears further investigation. I'll eventually put in a Smartie Parts board and upgrade it to the er9x software.
Lonemountain is offline Find More Posts by Lonemountain
Old Feb 25, 2012, 11:47 AM
ttabbal is offline
Find More Posts by ttabbal
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
Just get a different battery holder. The stock one is a cheap pos. The radio is fine, you got it to power up for a minute, that indicates to me that you have trouble getting power into the radio..
Another option is a TX pack using another battery type if you have one or are willing to order one. Or even some other random source of 8-12v. Just make sure you don't reverse the polarity.
ttabbal is offline Find More Posts by ttabbal
Old Feb 25, 2012, 12:43 PM
ScottSails is offline
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
agree on the crappy original battery holder - TRIPLE check before you plug a new one in! Too many people have toasted their 9x due to wrong connector or off by 1 type of thing.
ScottSails is offline Find More Posts by ScottSails
Old Feb 25, 2012, 12:45 PM
tigermoth is offline
Find More Posts by tigermoth
United States, TN, Loretto
Joined Feb 2001
Try to tighten up the tabs and connectors in the holder with a couple of 1/4 in flat punches and vise. Just tapp em like tightening up rivets.
tigermoth is offline Find More Posts by tigermoth
Old Feb 25, 2012, 06:27 PM
Joined Oct 2001
One of the things I did was solder all the rivet connections. This is a bit tricky to do because you can easily melt through the plastic on the holder ends. I used a good amount of paste flux applied with a tooth pick, a good hot 25 watt iron, and gave each connection a wipe with a solder pool on the iron tip. It worked fine and is much more reliable now. Another alternative is to use a Walkera battery holder. They are much better quality than the Turnigy/Fly Sky holder.
Old Feb 27, 2012, 04:46 PM
ricknoon is offline
Find More Posts by ricknoon
United States, IA, Orange City
Joined Feb 2012
My 9x was finicky to start off with. I had to install the batteries a couple different times to get power; and then the menu buttons wouldn't respond. Twice I held the "exit" button while turning it on to reboot the software and after the second reboot it starting working normally.
It just takes a few minutes to come out of hibernation or something.
ricknoon is offline Find More Posts by ricknoon
Old Feb 27, 2012, 05:09 PM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
The battery box is always a trouble maker. Battery contacts are not reliable.
Replace it with a battery pack but use the original connector which came with the box to assure correct polarity. If you use a different connector, you are liable to burn TX.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Feb 29, 2012, 07:40 AM
chenbot is offline
Find More Posts by chenbot
Joined Dec 2011
Make sure all of your switches are either up or back away from you
chenbot is offline Find More Posts by chenbot
Discussion imax b5 wont turn on help!? oisin_cassidy Batteries and Chargers 1 Feb 13, 2012 12:26 PM
Discussion Viefly wont turn on pfisto Mini Helis 0 Dec 29, 2011 06:15 AM
Discussion Dx7 Wont turn on allstarbubby Electric Plane Talk 25 Dec 05, 2011 10:51 PM
Help! Jr 9303 wont turn on capt soap Radios 15 Nov 03, 2011 02:56 PM
Discussion Turnigy 9x won't turn on colombiandaniel Radios 2 Aug 10, 2011 03:20 PM
