Old Feb 25, 2012, 09:08 AM
901racer is offline
Find More Posts by 901racer
Joined Oct 2011
Change Sun 10 blade 70mm (Test Results Consolidated)
I have started this thread to make it easy for users of the Change Sun 10 blade 70mm fan to easily find motor combination test results.
This thread is intended only as an easy place to find the results. I will update this thread with results as new user tests are performed.
All questions and discussions about the Change Sun 12 blade fan should be directed to the Change Sun 10 blade 70mm thread.
Again this is only intended to be a place for the aggregation of all the test results from the other official thread that has become way to big for visitors to fine the information easily. I hope this will be helpful for new visitors looking for test information.
Update: 2/26/2011 include in plane tests of the Eflight BL32 in-runner.
Results are below as well an attachment in excel format for easier comparison.
4S Test Results:
Turnigy L2855 – 2300KV
4S 3300 25C
Vm: 14.42
Ap: 43.44
Wp: 656.3
Thrust(kg) 1.3
g/w: 1.98
4S 4000 40C
Vm: 14.82
Ap: 46.60
Wp: 704.5
Thrust(kg): 1.35
g/w: 1.92
Cyclone CP-480-3300kv
SkyLipo 4S 40C
Vm: 13.19
Ap: 89.57
Wp: 1297.0
Thrust(kg) 1.83
g/w: 1.41
Turnigy L2855 – 2800KV
4S 4000 40C
Vm 14.36
Ap 63.47
Wp 950.0
Thrust(Kg) 1.6
g/w: 1.67
Cyclone CP-480-2800kv
SkyLipo 4S 40C
Vm 14.78
Ap 69.55
Wp 1096.0
Thrust(Kg) 1.53
g/w: 1.39
Tacon 2858-2618kv
4S 30C
Vm: 15.00
Ap: 60.00
Ws: 778.0
Thrust(kg): 1.47
*g/w: 1.89
Turnigy L2855 - 2100kv
4S 3300 25C
Vm: 14.18
Ap: 35.32
Wp: 884.2
Thrust (kg): 1.3
g/w: 1.47
Turnigy XK2850-B-3000kv
SkyLipo 4S 40C
Vm: 14.43
Ap: 69.51
Wp: 1034.5
Thrust(kg): 1.70
g/w: 1.64
Turnigy L2226-3000kv
4S 25C
Vm: 14.3
Ap: 66.38
Wp: 949.8
Thrust(kg): 1.51
g/w: 1.59
HET RC 2w25
4S ??
Vm: 14.8
Ap: 59.4
Wp: 889.0
Thrust(KG): 1.48
g/w: 1.64
Turnigy SK3 Fandrive - 3516-3300kv
4S 3000 40C
Vm: 13.59
Ap: 87.5
Wp: 1215.0
Thrust(kg): 1.75
g/w: 1.44
5S Test Results:
5S 4400 65C
Vm 18.46
Ap 65.07
Wp 1248.0
Thrust(Kg) 2.0
g/w: 1.60
SkyLipo 5S 40C
Vm 17.95
Ap 90.18
Wp 1675.0
Thrust(Kg) 2.06
g/w: 1.23
5S 4400 65C
Vm 17.74
Ap 82.84
Wm 1478.6
Thrust(Kg) 2.2
g/w: 1.49
Tacon 2858-2618kv
5S 30c
Vm: 18.00
Ap: 87.00
Ws: 1600.0
Thrust(kg): 2.13
*g/w: 1.33
5S 4400 65C
Vm: 18.82
Ap: 54.70
Wp: 1067.10
Thrust (kg): 1.8
g/w: 1.69
SkyLipo 5S 40C
Vm: 17.65
Ap: 88.70
Wp: 1606.6
Thrust(kg) 2.1
g/w: 1.31
6S Test Results:
6S 4500 25C
Vm 20.79
Ap 70.4
Wp 1511.0
Thrust (Kg) 2.2
g/w: 1.46
6s 2x Turnigy 3s 20-30c
Vm 16.54
Ap 85.28
Wp 1613.2
Thrust(Kg) 2.6
g/w: 1.61
6S 4500 25C
Vm: 21.86
Ap: 71.80
Wp: 1642.7
Thrust (Kg): 2.4
g/w: 1.46
E-flite BL32 inrunner
6S 3300 35C nonotech
Vm: ?
Ap: 85.0
Wp: 2000.0
Thrust(Kg): 1.81+
g/w: ?
*Eflight V15 shroud w/ cs 10 rotor
*Installed in plane
* Watts settled vs. peek
901racer is offline Find More Posts by 901racer
Old Mar 26, 2012, 06:44 PM
nighthawk0077 is online now
Find More Posts by nighthawk0077
Canada, ON, Vaughan
Joined Oct 2009
Quick question, why is the 2100kv 2855 producing more thrust on 6S than the 2300kv?
nighthawk0077 is online now Find More Posts by nighthawk0077
Old Mar 26, 2012, 07:56 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Volts on the packs, its really important to look at volts even when just watts are posted
erh7771 is online now Find More Posts by erh7771
Old Apr 02, 2012, 02:24 PM
Strussen is offline
Find More Posts by Strussen
Joined Mar 2012
Wow, great job on the results!
Strussen is offline Find More Posts by Strussen
Old Apr 02, 2012, 02:32 PM
frank40 is offline
Find More Posts by frank40
frank40's Avatar
Denmark
Joined Sep 2005
Great work, this will be a great help....Thanks
frank40 is offline Find More Posts by frank40
Old Apr 03, 2012, 01:51 AM
MrBlobby is offline
Find More Posts by MrBlobby
Nederland, NB, Waalwijk
Joined Sep 2006
Nice list, thanks! If you have time, something similar for the 90mm fan would be great. Nobody wants to read through 150+ pages of posts :-)
MrBlobby is offline Find More Posts by MrBlobby
Old Apr 03, 2012, 07:53 AM
darmar is offline
Find More Posts by darmar
USA, PA, Pittsburgh
Joined Jul 2001
List should include ESCs used. There is a difference in output of let's say SuperSimple HK ESC(suppo) and HobbyWing genuine ESC.
That's at least what I found out testing EDF with few programmable speed controls.
darmar is offline Find More Posts by darmar
Old Jun 25, 2012, 07:03 AM
mopetista is offline
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
Great resource! Bummer there are no more results of the 2855 2800kV on 3s, great combo and good for a light setup on, e.g., the HK Vampire
The test results are buried in the CS70 thread, if you have them ready it would be great if you could include those for reference
thx!
Clemens
mopetista is offline Find More Posts by mopetista
Old Jun 25, 2012, 03:43 PM
Jacques.Eloff is offline
Find More Posts by Jacques.Eloff
Jacques.Eloff's Avatar
United Kingdom, England, Cobham
Joined Oct 2007
Very useful data, what would make it even better is if you could compute g/W^(2/3). This get's around the issue of declining g/W as power increases and will tell you instantly which is the most efficient combo.
g/W is not very helpful when comparing results at differing power levels. Took me a while to get my head around the value, but you will see the light when you compute it.
The reason for misleading nature of g/W is that much of the energy turns to efflux rather than raw thrust, as power is increased. But since you are not measuring efflux, you are blind to this energy.
Jacques
Jacques.Eloff is offline Find More Posts by Jacques.Eloff
Old Jun 29, 2012, 02:34 PM
Foskje is offline
Find More Posts by Foskje
Norway
Joined Dec 2009
Change Sun 10 blade 70mm from hobbyking, paired with the Turnigy L2855 - 2100kv
4S 2650 40C (itīs an old zippy battery..)
Vm: 13.25 Volts
Ap: 24,9 Amps
Wp: 329,9 Watts
Thrust: 800 grams
grams/watts: 2,4 g/w (!)
Why is mine so much more efficient? - is it because the fan and the motor is brand new? - or is it because the motor is cold (20 *C) under/before test?
6S 2200 30C (itīs two old turnigy batteries..)
Vm: 20,14 Volts
Ap: 46,7 Amps
Wp: 940 Watts
Thrust: 1400 grams
grams/watts: 1,49 g/w
After a couple of tries I measured up to 70 *C inside the motor, I might turn down the trottle a bit on 6s...
3S 2200 30C
Vm: 10,9 Volts
Ap: 18,3 Amps
Wp: 200 Watts
Thrust: 550 grams
grams/watts: 2,75 g/w (!)
Foskje is offline Find More Posts by Foskje
Old Jun 29, 2012, 08:29 PM
Gamalier is offline
Find More Posts by Gamalier
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
Great job on collecting all the data but to compare apples to apples it would been good to use the same battery pack (and I mean the same not the same capacity). That way the numbers would be comparable. (variables kept within a minimum change).
Gamalier is offline Find More Posts by Gamalier
Old Jun 29, 2012, 09:10 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
I just did some bench test with TJ70 shroud and BL32 2150KV motor.
Upload the video tonight.
Tamjets is offline Find More Posts by Tamjets
Old Jun 29, 2012, 11:35 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Tam I just watched the vid WOW!!!!!! that is pretty damn impressive for the little bl32 motor.......man I knew that was a good setup but now its locked in and proven, and on top of that its reliable and still going with over 100 flights on the first one Nick and I put together.
vid is up here ya go
the bl32 in this test is out of sean's habu and has well over 200 flights on it
TJ70 CS rotor BL32 2150kv (5 min 0 sec)
jcdfrd is offline Find More Posts by jcdfrd
Old Jul 02, 2012, 11:16 AM
Joined Nov 2005
Originally Posted by Foskje View Post
....Why is mine so much more efficient? - is it because the fan and the motor is brand new? - or is it because the motor is cold (20 *C) under/before test?
Vm: 20,14 Volts
Ap: 46,7 Amps
Wp: 940 Watts
Thrust: 1400 grams
grams/watts: 1,49 g/w...
This isn't more efficient, there are thrust to watts above that are in the 1.6 and 1.7 range.
Your packs are dipping here pretty bad at WOT, you're also below 3.0 volts a cell....that cause's packs to heat up pretty bad. Get a cell checker, it'll allow you to cell if you have a popped cell in the pack.
70c is pretty good, a Scorpion motor does around 385F on it's motor elements so half of that is pretty good.
Old Aug 16, 2012, 08:55 AM
T-BONEZ is offline
Find More Posts by T-BONEZ
Joined Jun 2007
I'm firing mine on 4s,
freewing 70mm 3000kv motor... would it be okay?
T-BONEZ is offline Find More Posts by T-BONEZ
New Product Change Sun 10 blade 70mm Flip Flop Electric Ducted Fan Jet Talk 7452 Jun 11, 2016 06:05 AM
Sold Change Sun 10blade EDF 70MM Tacon 2550KV motor hi2nr Aircraft - Electric - Jets (FS/W) 1 Feb 24, 2012 01:01 PM
Sold Change Sun 10 blade 70mm edf w/motor 420flyboy Aircraft - Electric - Jets (FS/W) 2 Dec 16, 2011 12:42 PM
