Old Feb 25, 2012, 06:49 AM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Question
Hard points in stabs or CF?
I'm puttin some very nice OBI tail feathers on a plane but there are no hard points on the stab. Should I drill it and make hard points or just put a strip of CF to tighten the the screw heads to?
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Feb 25, 2012, 06:53 AM
ThomasLee is online now
Find More Posts by ThomasLee
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
I like to make hardpoints
ThomasLee is online now Find More Posts by ThomasLee
Latest blog entry: Vibe Assembly Instructions
Old Feb 25, 2012, 07:55 AM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Canada, ON, Morriston
Joined Apr 2010
Drill it then take a L shaped Piece of wire or something and gouge out some foam beyond the hole opening , fill back up with epoxy and then redrill the final hole.
If it has a spar drill some where other than through the spar.
You gotta put something to handle the compression of the screw. On my own personal stuff I put vertical balsa in that area before bagging.
DLGjunkyard is online now Find More Posts by DLGjunkyard
Old Feb 25, 2012, 08:25 AM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
Vertical balsa.... Hum... I think I could cut the skin off the bottom, gouge out the foam and put some vertical balsa in there with some foam safe ca. Then just sand the bottom side flush. I could then drizzle some thin ca over it just to make it a little harder. What do yo think?
They wouldn't be round but then I'm not drilling a thin piece of foam.
Old Feb 25, 2012, 08:42 AM
Joined Apr 2010
Go with the resin hard point. The balsa is done best before bagging the core and it also a fairly large shape to reduce a stress riser.
The supergee plan is a good reference for the balsa approach FWIW http://www.charlesriverrc.org/articl...2/sg2_tail.pdf
Old Feb 25, 2012, 08:56 AM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
Resin it is.... In from the bottom an leave the top skin untouched.... Except to drill the screw hole, that is.
Thanks!
Old Feb 25, 2012, 04:45 PM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Its not to hard to drill a single hole for a 3-56 nylon screw and then gouge out the foam and not take a larger hole from the bottom.
davidjensen is offline Find More Posts by davidjensen
Old Feb 27, 2012, 08:24 PM
glidermang is offline
Find More Posts by glidermang
Mr. Wiz:
I recommend what DLGjunkyard did: epoxy hard points.
Personally, I go in from the top with the L-shaped wire. Make the hard point about twice the diameter of the hole you intend. Cover the bottom with masking tape, so if anything leaks out, it has no where to go. I use 20-minute epoxy with micro-balloons. Other materials work well, but the mixture I use is easily drilled without fractures or chips.
You can counter-sink for flat-head screws, no sweat.
Oh, yeah: about the 20-minute epoxy. Wait at least four (4) hours before drilling. Sometimes the inside doesn't cure so fast.
Yours, Greg
glidermang is offline Find More Posts by glidermang
Old Feb 27, 2012, 09:36 PM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
I just cut some approx 1/4" square holes in the bottom of the stab where the hard points were to go. Then I gouged out the foam. Next I put in a mixture of 20 Min epoxy and some micro balloons. You think that's going to be OK? It seemed simple enough.
Old Feb 27, 2012, 10:08 PM
Will fly for food
Bellevue WA,
Joined Dec 2003
40% to 50% micro balloons (by volume) to epoxy mix
Old Feb 28, 2012, 07:42 AM
Mr. Wiz:
Sounds like you're done.
Never really tighten the screws, anyway - just firm, no slop.
Yours, Greg
Discussion 1mm motor mount in fg or cf for TechOne mini Yak red_z06 Scratchbuilt Indoor and Micro Models 2 Feb 17, 2012 12:35 PM
Discussion 1mm motor mount in fg or cf red_z06 Scratchbuilt Indoor and Micro Models 0 Jan 11, 2012 02:06 PM
Wanted 2 or more hard case 2S 4000s or bigger lmopar69 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Nov 14, 2011 01:17 AM
Question Uh? Points? what points? papabearflying Site Chat 8 Sep 20, 2011 03:48 AM
Wanted Stabs for Shadow or similar molded sailplane billg Aircraft - Sailplanes (FS/W) 3 Jul 22, 2011 05:14 PM
