Old Feb 25, 2012, 05:35 AM
KJELL is offline
Find More Posts by KJELL
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Kjell-Wiggle-Drive
New video
Kjell Wiggle Drive.wmv (2 min 0 sec)
KJELL is offline Find More Posts by KJELL
Old Feb 25, 2012, 05:59 AM
Legendary_Agent is offline
Find More Posts by Legendary_Agent
Joined Dec 2011
Originally Posted by KJELL View Post
Cool so your design is achieving same wing flapping with gearless mechanism or am i getting the point wrong?
Legendary_Agent is offline Find More Posts by Legendary_Agent
Old Feb 25, 2012, 06:27 AM
swami is offline
Find More Posts by swami
swami's Avatar
Ursel, Belgium, Europe
Joined Jul 2001
How does the wiggle drive work if your wing is hinged in a line (front and back ball-bearing) ?
What about the power needed?
It seems to me like a system with a lot of resistance.
Dirk.
swami is offline Find More Posts by swami
Old Feb 25, 2012, 06:57 AM
therealthing691 is online now
Find More Posts by therealthing691
therealthing691's Avatar
australia
Joined Apr 2007
Kjell wing drive.mpg (1 min 15 sec)
therealthing691 is online now Find More Posts by therealthing691
Old Feb 25, 2012, 08:58 AM
seagull10 is offline
Find More Posts by seagull10
Joined May 2011
Mr .Kjell , Your tail propulsion drive from 1972 is one really original and smart mechanism .I am sure ,it can be adapted for ornitopters' wings propulsion as well and probably for simple membrane wings ornithopters it will work better than your latest W - drive version.
Also the demonstration of vectored trust is very interesting ,It make the model very,very maneuverable.
Thank you for sharing. Nice idea.Good job.
seagull10 is offline Find More Posts by seagull10
Old Feb 25, 2012, 08:59 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Dirk.
The Wiggle Drive has less friction than crank movement because all power transmitting is rotating parts with ball bearings.
Old Feb 25, 2012, 02:13 PM
Larry Jolly is offline
Find More Posts by Larry Jolly
Larry Jolly's Avatar
Joined Oct 2003
Kjell
Very impressive solution. Thanks for sharing, I am very impressed with this transmission. LJ
Larry Jolly is offline Find More Posts by Larry Jolly
Old Feb 25, 2012, 05:35 PM
Joined Dec 2011
So... is it suposed to be gearless flapping mechanism or not? by gearless i mean the wing flapping, not the speed reduction obviously.
Old Feb 25, 2012, 10:18 PM
australia
Joined Apr 2007
the wiggle drive video i put in there if im not wrong was made by willi but of Kjells design im sure Kjell will correct me if i am wrong willi is one of the older members of this forum cheers brian
Old Feb 26, 2012, 02:27 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
The two wiggle heads have to rotate in opposite direction so they are connected with gears. The fan-flapping rate is depending on wing size.
Old Feb 26, 2012, 02:30 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Willi made the Wiggle Drive in collaborating with me. He made a very professional work. He had problems to make it fly because he was using SK wings Do to the active wing twist and, the 8 way movement the wing has to be made different.
Old Feb 26, 2012, 02:45 AM
australia
Joined Apr 2007
cool i thought that was Willi's and yes it was made very professional
Old Apr 10, 2015, 12:44 AM
ZTEX is offline
Find More Posts by ZTEX
Joined Aug 2013
Halve of the W-drive in IKEA's hammering drill. Since IKEA is worldwide spread it's probably available everywhere.
Watch after 20 th minute.
BOLTR: Ikea SDS Hammer Drill Gut Check Part A (29 min 18 sec)
ZTEX is offline Find More Posts by ZTEX
Discussion Crank vs. Wiggle drive? Socalfusions Ornithopters 38 Feb 02, 2012 03:15 AM
Discussion New Wiggle-Drive. KJELL Ornithopters 177 Nov 15, 2010 04:05 PM
Discussion Wiggle Twin Drive. KJELL Ornithopters 3 Jul 13, 2010 02:30 PM
Discussion Membrane wings upgrades by Mr KJELL khaled_abobakr Ornithopters 1 May 07, 2010 01:52 PM
Discussion The Wiggle-Drive. KJELL Ornithopters 0 Oct 18, 2009 04:16 AM
