Old Feb 25, 2012, 05:39 AM
Rc Heli Halle is offline
Find More Posts by Rc Heli Halle
Rc Heli Halle's Avatar
Berlin / Germany
Joined Feb 2010
Use the CYCLOPS NOVA OSD System Auto-return function
Hi all , I see this Video today :
Cyclops NOVA OSD with RTH Function RCTESTFLIGHT Review (8 min 15 sec)
Now in the Video you see the RTH function works fine with RC Plane. Can we use this for ouer Multicopters ? I thinkso.
In Manual there is to connect the NICK and Roll and an output to Nicj and Roll to the Servos of Plane. Why not connect to the Multicopter FC ? When Fly by Hand all is Loopthrough directly to FC. When switch tor RTH , the Speed and High is Manual over Throttle by Pilot and Direktion per Nick and Roll by NOVA.
So , it cant fly a Curve , because can not mix NICK -ROLL - Gier. But when Input to Nova Aileron used for Gier and Aileron output goes to Gier at Multic FC ? Then the Nova Turns the Multicopter to Home Point and Elevator ( Nick ) makes the forward Flight. All when the Pilot give Speed by Throttle ??
What do you think ?
Rc Heli Halle is offline Find More Posts by Rc Heli Halle
Old Feb 25, 2012, 05:44 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Planes fly forward.
Multis don't.
Also, I'm not familiar with "Nick", "Roll", "Gier".
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Feb 25, 2012, 08:21 AM
javemtr is offline
Find More Posts by javemtr
Joined Sep 2011
It's German for pitch/roll/yaw angles.
javemtr is offline Find More Posts by javemtr
Old Feb 25, 2012, 08:45 AM
randall1959 is offline
Find More Posts by randall1959
Joined Feb 2004
I have a Nova set up in a plane and I'm not sure how well it would work in a multi.
But for just 150 dollars it's worth experimenting with. I just wouldn't do it with a quad I'm fond of.
It just works with pitch and roll. It does not have yaw. I think if you hooked it up to yaw, it would confuse the IR sensor.
randall1959 is offline Find More Posts by randall1959
Old Feb 26, 2012, 12:42 AM
sickwitit is offline
Find More Posts by sickwitit
sickwitit's Avatar
Lewisville, TX
Joined Sep 2010
Today, I sent the same question to FoxTech. No reply yet.
While the plane (or multicopter) is "returning to home", can we add Rudder input with the rudder stick on the radio...to help it turn around and face home?
Or maybe after we activate RTH...the multicopter will just fly itself backwards all the way home?
sickwitit is offline Find More Posts by sickwitit
Old Feb 26, 2012, 01:50 AM
timecop is offline
Joined Dec 2010
This is not possible to do without compass, GPS heading alone is not enough. It works in planes because they always go forward, thus you have a proper heading vector from GPS. You can't get a heading vector from a multi without a compass.
Old Feb 26, 2012, 02:08 AM
sickwitit's Avatar
Lewisville, TX
Joined Sep 2010
Ok, very good to know. Thanks for the info!
Old Jun 19, 2012, 03:21 PM
cabecinhas is offline
Find More Posts by cabecinhas
Joined Jun 2012
Angle from Home
Hi folks.. Do you know if the Cyclops NOVA OSD shows the angle that the plane is?
I mean...
how can I point the antenna to the plane?
the Remzibis does have the Azimuth that shows in angle () where the plane is.
tks
cabecinhas is offline Find More Posts by cabecinhas
Old Jul 30, 2012, 08:54 AM
fredouille is offline
Find More Posts by fredouille
Estonie, Tallinn
Joined Nov 2010
so what is the conclusion ? works or not with a multi rotor ?
fredouille is offline Find More Posts by fredouille
Old Oct 11, 2012, 06:13 AM
DaveyLC is offline
Find More Posts by DaveyLC
DaveyLC's Avatar
United Kingdom, England, Wokingham
Joined Sep 2011
I mean...
tks
It gives you the planes current heading and it also shows you the direction to home from the plane (via a line drawn from a central point)..
Not sure if that helps
DaveyLC is offline Find More Posts by DaveyLC
Old Oct 15, 2012, 05:14 AM
bolo1234 is offline
Find More Posts by bolo1234
United States, TX, Laredo
Joined Oct 2012
Err
bolo1234 is offline Find More Posts by bolo1234
Old Nov 10, 2012, 07:01 PM
matix101 is offline
Find More Posts by matix101
Joined Aug 2012
i have one of these in my finwing penguin and it is not suitable for multirotors as above mentioned you need a compass to tell which way a multi rotor is facing i would suggest the dji naza system it can be setup for waypoints and rth with multirotors quite a bit more buck but worth all of it imo
matix101 is offline Find More Posts by matix101
Old Nov 23, 2012, 10:54 AM
Infernumpsychopa is offline
Find More Posts by Infernumpsychopa
Infernumpsychopa's Avatar
Joined Nov 2012
Hello ! i really appreciate any info about my issue.! i have a pixim camera and cyclops nova osd. but the osd information doenst fit my googles/monitor. i mean all the important information at the bottom is lost. i thought it was the camera but i found a video from a guy who has the same pixim camera with cyclops nova osd and it works just perfect here is the video
osd nova rth test.m4v (1 min 42 sec)
Infernumpsychopa is offline Find More Posts by Infernumpsychopa
Old Dec 10, 2012, 09:06 PM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
I'm looking at this system and have a question. Being a noob to FPV I trying to figure out how this system works the throttle for RTH?
davecrash is offline Find More Posts by davecrash
Old Dec 22, 2012, 08:08 PM
firedawg1998 is offline
Find More Posts by firedawg1998
Canada, ON, Greater Sudbury
Joined Nov 2011
I still learning as well, but from what I can tell, most people have receivers that you set your throttle failsafe. It will then take care of the throttle where you set it, say 60% and you get back your control once your radio link regain a signal. My orange full range has this as well as the rmilec UHF module so it's just something else you may have to look into if gliding isn't your planes best feature, lol
firedawg1998 is offline Find More Posts by firedawg1998
Wanted Cyclops Nova OSD main board rellik demanon FPV Equipment (FS/W) 2 Mar 12, 2012 12:22 PM
Wanted Cyclops NOVA OSD with RTH Bolstad FPV Equipment (FS/W) 2 Feb 08, 2012 02:29 AM
For Sale For sale Cyclops easy OSD V1.5 and NOVA Schmoopiebunny FPV Equipment (FS/W) 17 Jan 09, 2012 12:12 PM
Discussion Tracking system for Cyclops OSD. sundown798 FPV Talk 5 May 20, 2011 10:39 AM
Wanted Good osd with return to home function ROCKY2 FPV Equipment (FS/W) 1 Nov 26, 2010 01:36 PM
