Old Feb 25, 2012, 12:56 AM
disneytoy is offline
Find More Posts by disneytoy
Joined Feb 2012
Multicopter Motor Guide 101
Hello!
I've been doing a lot of research on building a quad. Read a lot of the beginner threads here. I'm still confused regarding motor selection. I was hoping some of you could give a brief guide to selecting and comparing one of the most important decisions.
What you should know before selecting your motors...
What exactly is the KV rating?
How do you match a prop for a particular motor?
How does the weight of the motor come into consideration?
What to look for regarding max RPM and Working current?
Any recommendations on inexpensive motors.
Thanks!
disneytoy is offline Find More Posts by disneytoy
Old Feb 25, 2012, 01:18 AM
yashmack is offline
Find More Posts by yashmack
Joined Jan 2012
KV rating is the RPM per Volt
so a 1000KV motor will rotate at 11,100 RPM at 11.1V
will have to wait for answers from those with experience for the rest of the questions
yashmack is offline Find More Posts by yashmack
Old Feb 25, 2012, 04:22 AM
AusTelemetry is offline
Find More Posts by AusTelemetry
Australia, NSW, Glen Innes
Joined Sep 2011
Here's a useful resource for comparing motor/ battery/ ESC /prop combinations :
http://www.ecalc.ch/xcoptercalc_e.htm
Happy flying
P
AusTelemetry is offline Find More Posts by AusTelemetry
Old Feb 25, 2012, 10:50 AM
Joined Feb 2012
So, higher KV is not necessarily better for a quad? Is their a rule of thumb high or lower KV for acrobatic, or as a stable camera platform, how does the KV selection effect your prop choice? High KV with a smaller prop equals lower KV with a larger prop?
Old Feb 25, 2012, 11:18 AM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
"I've been doing a lot of research on building a quad.
How do you match a prop for a particular motor?"
What is the projected weight of your quad ?
200g, 1000g or more ?
Mortimer is offline Find More Posts by Mortimer
Old Feb 25, 2012, 11:34 AM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
weight of EVERYTHING you plan to fly
rpm of motor at a given voltage
by the amp draw with the prop selected
the lighter the less you have to carry?
whatever you like as long as you know what you are doing
loads but this has been said so many time the thread is flooded with setup info
Thanks!
no worries
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Discussion "new to multirotor? start here, multicopter 101" n3m1s1s Multirotor Talk 910 Mar 13, 2012 01:31 PM
Discussion End all brushless motor selection guide jbrracer Power Systems 11 Apr 16, 2011 08:28 AM
Discussion Is there an 'idiots guide' or 'Sticky 101' to getting started in Quadrocopters? Tommygunn Coaxial Helicopters 5 Nov 23, 2009 05:43 PM
Discussion Need assembly 101/primer/idiots guide.... tim hooper DIY Electronics 13 Jun 29, 2006 06:17 AM
