Letchworth, Great Britain (UK)
Joined Jul 2004
Having said that, there's only a certain amount of watts you can efficiently get out of a certain size propellor. I don't know what the formula is, but hopefully someone will be able to chip in with it. |
Tucson
Joined Nov 2009
Think about motors that are rated at least 6 lbs x 150 watts. Then add 30%.
leadershobby has a Power 46 motor that can put out 1600 continuous watts, and spike to 2300 watts. hobbyking has 190-200 A speed controllers ("opto", or without the power to the receiver and servos -- use a separate voltage regulator). 4-cell Lipos will sport fly the plane, but 6 cell voltage will be ballistic. I use a Turnigy $5 voltage regulator that plugs into the receiver with a servo plug, and I plug a 1200 mAh battery into the voltage regulator to power the receiver and servos. This power insures that your receiver will not brownout if the motor battery runs way dawn. I think that the body on that plane will not allow the big, flat 4S Lipos, so you will have to go with the thin long ones. I fit 2 x 5000 3S LiPos in series to get 6S power, for the nitroplanes Giles. Ballistic, but doesn't fly for very long. |
Joined Jul 2004
So, in my opinion, if you're using a separate 2S LiPo to power a BEC to power the receiver you might as well simply use a standard 1200mAh NiMh pack or A123 pack without the BEC, and eliminate the extra complexity. With a stand-alone BEC running off its own LiPo, you can still lose your radio because the 2S LiPo has run down -- and you won't get any prior warning because the motor may still be running
Sverige, Värmlands Län, Filipstad
Joined Jan 2009
Hi,
What is the weight of this Gilles 202 plane ready to fly? Since it is a taildragger You can add larger main wheels or change landing gear to higher to get better prop clearance. I do not know but maybe a 6 cell LiPo around 5000 mAh could be enough. Anyway try eCalc to get some values with various motors, APC Electric props and lets say 100 Amp ESC.. http://www.ecalc.ch/motorcalc_e.htm?ecalc /Bo |
| Thread Tools | |
| Discussion Buy electric or convert existing glider to electric? | Autotechwagon | Electric Sailplanes | 11 | Sep 23, 2012 10:51 PM |
| Discussion Lanier Extra 3.25 Convert to Electric | Cub Flyer Fresno | Glow to Electric Conversions | 115 | Mar 14, 2012 12:09 AM |
| Question Have anyone had convert a BRIDI XLM to electric? | claude_3d | Glow to Electric Conversions | 2 | Apr 05, 2011 07:02 AM |
| Newbie wanting to convert CD-rom.... | papasmurf | Power Systems | 2 | Apr 15, 2004 06:35 AM |
| Wanting to convert sky scooter to a Twin | kushal_22 | Foamies (Kits) | 0 | Nov 02, 2002 02:28 PM |
