Old Feb 09, 2013, 10:01 PM
Ginohio is offline
Find More Posts by Ginohio
Ginohio's Avatar
United States, OH
Joined Mar 2012
Finally a semi decent day to go out and fly..It's been since late October since I have had the right weather. right time you all know how that goes..Plane was twitchy because I just velco taped 808 cam to the belly and didn't mess with checking COG. Cam is cheapy gotta get a HD in the coming months. I tried to fly my Champ prior to this and the gust were just blowing it around. Hopefully tomorrow temps in the 40's and wind about the same and going to Maiden my AXN...after I have a flight with the Stratos for warm up.. btw.. voltage 8.4 after approximately 11 minutes of flying it was at 7.9 with approx half throttle majority of time.
Cheers... it was fun to fly again.
Greg
stratos29 (2 min 39 sec)
Ginohio is offline Find More Posts by Ginohio
Old Feb 10, 2013, 07:25 AM
JayY is offline
Find More Posts by JayY
Foam Temple Pilot
JayY's Avatar
United States, NC, Raleigh
Joined Sep 2012
Originally Posted by flightpunch34 View Post
stratos Aerobatics time.
just what is this planes limit,well i pushed mine to the limit and beyond today,this thing goes great with V/instructor off and on high rate mode.however i would NOT recommend it for newbies to switch them off.i'm getting back in to the flying again,will have to progress already for something larger soon.this stratos is unique and has a lot of flying to offer any pilot at any level.a great plane for sure.
Nice flying. I've tried to fly mine inverted with Virtual Instructor on and it didn't work well, I'll have to try it again with VI off. Have you tried an outside loop?
JayY is offline Find More Posts by JayY
Old Feb 10, 2013, 11:57 AM
Nighthawk74 is offline
Find More Posts by Nighthawk74
RC addict? I'm not addicted...
Nighthawk74's Avatar
Danmark, Midtjylland, Roslev
Joined Jul 2011
Originally Posted by Corran View Post
Made another little video...in the cold winter Sweden
Got some good speed going stragiht down.... ^^ Just about 1,35
http://www.youtube.com/watch?v=CnEmkgS_GTI
Yes another Viking Nice flying there. Numb fingers are one of the perks of winter flying.
Nighthawk74 is offline Find More Posts by Nighthawk74
Old Feb 10, 2013, 04:25 PM
black6088 is offline
Find More Posts by black6088
United States, WA, Ferndale
Joined May 2012
Originally Posted by jrtubb View Post
I recommend that you look at why they are bowing. I added pin hinges to the elevator and made sure the push rods where straight and smooth. I might do this to the rudder but right now it is pretty good.
I have two Stratos and eventually ended up with bowing push rods on both. I'm not sure why this happens (too many crashes, perhaps), but the push rods are bowing INSIDE the fuselage as well as outside near the control surfaces. This results in a "delay" effect once the stick is moved. Also, the throw of the control surface gets highly variable. Physically, my control surfaces and hinges are fine. I've ordered new push rod sets, and to avoid the bowing problem, I've inserted styrene plastic tubing through the fuselage along the "track" of the push rods. I'm also thinking of upgrading the gauge of the wire used for the push rods--- it's really small, like 0.015" or 0.020"--- to maybe 0.032". Anyone tried this? Any additional advice on installing push rods for the Stratos before I dive into it will be greatly appreciated,
Tom
black6088 is offline Find More Posts by black6088
Old Feb 10, 2013, 06:09 PM
flightpunch34 is offline
Find More Posts by flightpunch34
At High Altitude...
flightpunch34's Avatar
Ireland
Joined Jan 2013
Tom
the bowing effect IMO is because the servo is not set in neutral position,if it was me i would set all trims on handset to center position,at that point the elevator and rudder should be exactly centered,if off ever so slightly they can cause this bowing effect on the rod because the servo is traveling too far,at the end of the rod you will see where the rod joins,here it can be turned in or out to adjust,i would use this point to set things up bang on,then check the travel of the servos on low/high rate mode and check for bowing of the rod,if still persists then the elevator or rudder needs to be made to travel further so the position where the rod is mounted needs to be changed on the clevis.
hope that helped,it did do it for me.
f/punch
flightpunch34 is offline Find More Posts by flightpunch34
Old Feb 10, 2013, 06:22 PM
wjs is offline
wjs
Find More Posts by wjs
wjs
William
United States, MI, Brighton
Joined Oct 2012
f/punch
Even when setup perfect, they still bow on push stroke. At least mine still does. The control surfaces fight too much because of heavy hinge points. Could protentially be the worst (in a few ways) pushrod setup HH sells unfortunately. I might just go with a std 2-56 rod (forget the weight) with a std clevis and jb weld the smaller z-bend wire at the servo end.
wjs is offline Find More Posts by wjs
Old Feb 10, 2013, 08:45 PM
jrtubb is offline
Find More Posts by jrtubb
I Fly!
jrtubb's Avatar
United States, AL, Huntsville
Joined Jan 2011
Getting connections on those micro linear servos is going to be hard with any upgraded wire. My son has been pushing the limits and this weekend miscalculated his pull out too close to the ground. Took a few hours but is back to normal. Push rods are still working fine they do have some bowing.
jrtubb is offline Find More Posts by jrtubb
Old Feb 11, 2013, 09:54 AM
Jim Buzzeo is offline
Find More Posts by Jim Buzzeo
Jim Buzzeo's Avatar
Willmar, Minnesota, United States
Joined Sep 2004
the pushods flex because:
the hinges on the flying surface (elevator or rudder) are binding/ do not move freely.
OR
the pushrods themselves are binding (probably near the surface/ far from the servo) perhaps a decal, look closely where the pushod exits the fuselage.
Jim Buzzeo is offline Find More Posts by Jim Buzzeo
Old Feb 11, 2013, 04:09 PM
Joined May 2012
more on push rods
Thanks to all who responded about Stratos pushrods. I don't think the hinges are the problem. If they were, I would have experienced this problem from the beginning--- in my experience, the push rod bending happens over time and increases with number of hard landings. I agree that friction on the push rod is probably the problem. I haven't figured out the exact "track" of the Stratos push rods through the fuselage (if there is one), but I'm guessing that the push rod gets "off-track" somehow through use and impacts and then starts to bow. So, I'm trying inserting plastic tubing through the length of the fuselage for the push rod to run through. As far as going to a larger gauge wire, I think the suggestion of going to a 2-56 threaded rod is overkill and way too thick to work with the Stratos push rod ends. I'm planning on connecting the push rod ends (z-bend and threaded parts) to 0.032" music wire instead of the Stratos push rod (which is maybe 0.020"). Even that difference in size is significant though, but I think it will work--- just don't know whether I should glue the joint as before or try to solder it. Wish there was a video showing the Stratos push rod replacement process......
Tom
Old Feb 11, 2013, 05:16 PM
At High Altitude...
Ireland
Joined Jan 2013
hi
black6088
i think you could upset the weight of it if you use plastic tubing on the rods the extra weight will only slow it down,i know it's not much extra weight but it make a big differnce on these.
Old Feb 11, 2013, 05:17 PM
At High Altitude...
Ireland
Joined Jan 2013
some more aerobatics this evening at home with the plane,this thing can reach a serious altitude,madyson my seven year old son loves it,he wants me to fly it all the time and i'm not complaining stay tuned also for the new plane coming soon...all i will say is it will be mental and very fast! not long to wait now,i got an e-mail today saying it was sent :]
Flight Aerobatics prt-2. (by dan) (3 min 16 sec)
Old Feb 11, 2013, 05:52 PM
Jim Buzzeo's Avatar
Joined Sep 2004
Yeah, if the flexing pushrod issue gets worse over time and worse with hard landings, I have to think there's an internal pushrod guide or two that's fallen off/broken or something internal is binding on those pushrods.. a tiny amount of added weight in the tail is better than having flexing pushrods (as long as the plane is still balanced before flight)
Old Feb 11, 2013, 07:29 PM
At High Altitude...
Ireland
Joined Jan 2013
jim, think i might have another soloution for that problem,move in the rod on the clevis a hole and see how it goes.
well that's my stratos ready for a flight tomorrow in full elevator and rudder trim,i moved to the highest position for the clevis control horns to travel,now it has great rudder,also i cut away the tape and retaped the elevator so it all moves together,looks like the aerobatics could get even more intresting tomorrow,let's see
Old Feb 11, 2013, 08:29 PM
.quietguy is offline
Find More Posts by .quietguy
Closed Account
Joined May 2012
Minor suggestion with that elevator change: BE CAREFUL. I've read some hairy stories about that particular change. Good luck.
.quietguy is offline Find More Posts by .quietguy
Old Feb 12, 2013, 09:54 AM
chucksolo69 is offline
Find More Posts by chucksolo69
United States, CA, Oceanside
Joined Apr 2011
Changes like those should be made only after you have turned off the VI on this plane. The VI will not let the plane fly right if you make changes contrary to those settings stated in the manual.
chucksolo69 is offline Find More Posts by chucksolo69
Discussion HobbyZone Firebird Commander 2 jakob98 Electric Sailplanes 0 Sep 09, 2011 06:48 PM
Sold Hobbyzone Firebird Phantom parts - $30 take all PACubFlyer103 Aircraft - Electric - Airplanes (FS/W) 2 Sep 07, 2011 06:34 AM
Sold Hobbyzone Firebird Outlaw RTF - Great for kids and/or beginners baddb1 Aircraft - Electric - Airplanes (FS/W) 0 May 08, 2011 08:36 PM
Discussion Why was HobbyZone Firebird Freedom RTF dicontinued? cschrein Beginner Training Area (Aircraft-Electric) 2 Apr 19, 2011 08:15 AM
Sold Hobbyzone Firebird Commander 2 Plus Extras banjo_nc Aircraft - Electric - Airplanes (FS/W) 2 Apr 01, 2011 08:49 PM
