United States, TX, Sherman
Joined May 2012
Joined May 2012
Stratos down--- suggestions?
Doing high speed loops and turns, I lost my hatch cover and battery in mid-flight and ended up spiraling into a nearby creek. Pretty much everything got wet, but nothing broken. Now when I turn on the TX I do not get the familiar servo "binding" sound but instead the rudder servo just runs and runs (gears spinning), and the rudder is way out of alignment (tried realigning but no effect on how the servo behaves). Also, one motor keeps running even when the throttle is cut all the way. Do I need to replace the electronics? Any tips on this procedure from Stratos owners who may have had a similar experience will be appreciated.
Tom |
tom,
firstly i'm no expert about electrics and the after effects of water,the first thing i would reccomend and i suppose the most logical thing would be to dry out the complete plane with a blow/hair dryer,turn it off and don't let it connected after injesting so much water,all that is happening is minor short circuits and bad connections,you might be lucky you could end up drying everything out. the next step is a good circuit board spray/cleaner,you know the electric board cleaners? i would make enquiries here and see if you can get a safe product to spray over everything and seal things up and drive out the moisture. before spraying a good contact cleaner over everything i would first after the hairdryer goingover i would plug it in and see what it's doing. maybe you could be lucky. as for the rear tail of the plane,it's very easy to bend and re-shape the foam,you could cut it if needs be and reglue it...to retain the shape,but be carefull with where the servo rods connects (clevis) as they are easy to break,it will just make life more awkward if you do....you can reglue them too though in the event of an incident. i personally never fly over rivers or ponds,the worst thing is sealed servos can take a lot of damage by water if they are not fully waterproff,you might be able to dry the stratos ones cause they are not sealed,but corrosion is the enemy of water incidents. last resort if all above fails is a new fueslage and elecs included,not cheap though i think around 80euros here as far as i know. hope this helps. f/punch |
United States, MI, Brighton
Joined Oct 2012
Joined Feb 2013
Hi!
I am all new to this site. And have a problem with my Stratos Firebird. I have two, and really love them...but I think something is messed up with my power controll. It has happend sometimes...on the ground. For ex. when I change battery...that I get NO power to my engines. The rudder and all that works...but the props dosent spinn at all. Any ideas? |
since the same battery is used both to power the motor AND power the servos, when ESC /BEC senses that the battery is nearly used up, the esc/bec shuts down power to the motor while still providing power to the servos. (this way you've still got control of the airplane to land) |
Joined Feb 2013
Thx for the answer! It acts just like that...but my battery is charged. Itīs a pitty to have this problems...cause I really love to fly the plane. Here is a little vid of me taking it to the skies ![]()
burned out / bad motor OR Burned out / Bad ESC. since it happened to BOTH motors at the same time, it's likely the ESC |
| Thread Tools | |
| Discussion HobbyZone Firebird Commander 2 | jakob98 | Electric Sailplanes | 0 | Sep 09, 2011 05:48 PM |
| Sold Hobbyzone Firebird Phantom parts - $30 take all | PACubFlyer103 | Aircraft - Electric - Airplanes (FS/W) | 2 | Sep 07, 2011 05:34 AM |
| Sold Hobbyzone Firebird Outlaw RTF - Great for kids and/or beginners | baddb1 | Aircraft - Electric - Airplanes (FS/W) | 0 | May 08, 2011 07:36 PM |
| Discussion Why was HobbyZone Firebird Freedom RTF dicontinued? | cschrein | Beginner Training Area (Aircraft-Electric) | 2 | Apr 19, 2011 07:15 AM |
| Sold Hobbyzone Firebird Commander 2 Plus Extras | banjo_nc | Aircraft - Electric - Airplanes (FS/W) | 2 | Apr 01, 2011 07:49 PM |
