Old Feb 24, 2012, 04:13 PM
Emimec
Emimec
Guest
n/a Posts
Electrical power requirement question
Considering getting a VMC but need to check I have the power to run it. As
I'm no electrician, I am trying to understand what the text I pasted below
means
electrics - voltage/frequency 380 / 50 V/Hz
main drive DC 20 kW
spindle drive 15 kW
How many Horses ? How many amps supply do I need ?
My now scrapped Auto lathe had a big beast of a motor on it, the plate says
5.5/5.5/3,?? forgot the last bit. I think it was a 7.5 horse 2 speed motor,
but I cant seem to grasp the KW - horsepower confidently. I also understand
this is spread across 3 phases ?
Advice welcome.
Bob
Old Feb 24, 2012, 04:57 PM
Tony Jeffree
Tony Jeffree
Guest
n/a Posts
Re: Electrical power requirement question
On Fri, 24 Feb 2012 22:13:55 -0000, "Emimec"
>means
> main drive DC 20 kW
> spindle drive 15 kW
>Advice welcome.
>Bob
1 HP is approx 3/4 of a KW. So your 20KW is about 26 horses...and
would be a major space-heater. I suspect you have lost a decimal point
somewhere.
Regards,
Tony
Old Feb 25, 2012, 01:41 AM
Emimec
Emimec
Guest
n/a Posts
"Tony Jeffree" <tony@jeffree.co.uk> wrote in message
news:qa5gk7l3aqdsv0aca2obub8cc83a9jvp08@4ax.com...
>>means
>> main drive DC 20 kW
>> spindle drive 15 kW
>>says
>>motor,
>>understand
>>Advice welcome.
>>Bob
> somewhere.
> Regards,
> Tony
I pasted the info as supplied from the seller. Must admit, sounded a lot to
me as well !!
The "DC" bit worries me. I think I'll have to get the info again from him
and hope there is a mistake in the original.
In the meantime, maybe someone on here has Bridgeport 460 or similar and
they could suggest what the power for that is ?
Bob
Old Feb 25, 2012, 02:28 AM
Andrew Mawson
Andrew Mawson
Guest
n/a Posts
"Emimec" wrote in message news:gf2dneh4-LMJDdXSnZ2dnUVZ8gidnZ2d@bt.com...
>news:qa5gk7l3aqdsv0aca2obub8cc83a9jvp08@4ax.com.. .
>>>As
>>>below
>>>means
>>> main drive DC 20 kW
>>> spindle drive 15 kW
>>>says
>>>motor,
>>>understand
>>>Advice welcome.
>>>Bob
>> somewhere.
>> Regards,
>> Tony
>Thanks
>me as well !!
>Bob
The DC will undoubtedly be internally generated within the machine control,
and is quoted as a description of the type of drive, however it still is
power that you have to supply. What you need is what the rating plate on the
machine quotes as AC power input.
This post quotes the spindle as 2.2 kw:
http://www.cnczone.com/forums/produc...420_4axis.html
Regards,
AWEM
Old Feb 25, 2012, 03:56 AM
news.plus.net
news.plus.net
Guest
n/a Posts
> means
> main drive DC 20 kW
> spindle drive 15 kW
> Advice welcome.
> Bob
Power is 746W/horsepower, plus about 15% losses to be sure. Sounds like
some exotic motor with a plate like that. Is it a normal induction motor?
Rob.
Old Feb 25, 2012, 03:58 AM
news.plus.net
news.plus.net
Guest
n/a Posts
>> it. As
>> below
>> means
>> main drive DC 20 kW
>> spindle drive 15 kW
>> says
>> motor,
>> understand
>> Advice welcome.
>> Bob
> Rob.
Sorry did auto pilot response.....embarrassing.
Rob.
Old Feb 26, 2012, 07:57 AM
Uffe Bærentsen
Uffe Bærentsen
Guest
n/a Posts
I whished that was the whole truth.
In USA it is correct but where I live (Denmark) it is not.
Here it is 736W/horsepower.
Not a great difference but enough to add some confusion.
AFIK the 736 goes for Europe and the 746 goes for USA and whatever more
countries, I do not know.
Uffe Bærentsen
Old Feb 26, 2012, 08:58 AM
David Billington
David Billington
Guest
n/a Posts
>> motor?
> more countries, I do not know.
Actually what you're referring to would correctly be Pferdestarke,
abbreviated PS, and often referred to as metric horsepower. Car ads in
the UK usually have it mentioned in the small print somewhere indicating
the figures are PS rather than hp but for most purposes the 1.3%
difference doesn't matter and in kW we should all know that's
unambiguous and can convert to whatever else we like. /
Old Feb 26, 2012, 10:33 AM
David Littlewood
David Littlewood
Guest
n/a Posts
In article <4f4a3a41$0$292$edfadb0f@dtext01.news.tele.dk>, Uffe
Bærentsen <leiti_FJERNES_@hotmail.com> writes
Interesting. According to the Oxford Dictionary of Weights and measures,
the term horsepower was coined by James Watt as part of the marketing of
his steam engines. Its value in the UK settled down to be defined as 550
ft.lb.s^-1, which converts to 745.699872 W. Continental Europe seems to
have decided on a metric version, defined as 75 kgf.m.s^-1, which is
735.499 W. The USA seems to dislike untidy numbers, so they appear to
define it as 746 W, though I can't find definitive proof of this.
Since the UK invented the term, I claim we should take priority, though
I'm quite happy to use 746 W in everyday use :-)
David
David Littlewood
Old Feb 26, 2012, 12:49 PM
Andrew Mawson
Andrew Mawson
Guest
n/a Posts
"David Littlewood" wrote in message
news:b9P1VLBA7lSPFwmg@dlittlewood.co.uk...
>In article <4f4a3a41$0$292$edfadb0f@dtext01.news.tele.dk>, Uffe Bærentsen
>>> motor?
>Since the UK invented the term, I claim we should take priority, though I'm
>David
Well it rather depends if you're talking Clydesdales weighing in at a tad
short of a ton, or a New Forest Pony. I've had a Clydesdale step on my foot
so I know they're genuine heavy horses worthy of generating a one horsepower
grunt, whereas the New Forest Pony is regarded by the French as suitable for
a mid day snack!
AWEM
Old Feb 27, 2012, 01:14 AM
Emimec
Emimec
Guest
n/a Posts
"Andrew Mawson" <andrew@please_remove_me.mawson.org.uk> wrote in message
news:UImdnTm06pICBtXSnZ2dnUVZ8judnZ2d@bt.com...
>>news:qa5gk7l3aqdsv0aca2obub8cc83a9jvp08@4ax.com. ..
>>>>As
>>>>below
>>>>means
>>>> main drive DC 20 kW
>>>> spindle drive 15 kW
>>>>says
>>>>motor,
>>>>understand
>>>>Advice welcome.
>>>>Bob
>>> somewhere.
>>> Regards,
>>> Tony
>>Thanks
>>to me as well !!
>>Bob
> control, and is quoted as a description of the type of drive, however it
> still is power that you have to supply. What you need is what the rating
> plate on the machine quotes as AC power input.
> Regards,
> AWEM
Many thanks all
Seems the most reliable way is once again to see for myself, and follow
advice given here, and get the info from the machine maunufactures plate. I
did request this from the seller, but he seems to be confused along the line
somewhere.
To answer one question about the motor I mentioned that was 5.5/5.5/3 XX It
is a Brook Crompton 2 speed beastie, powered my now scrapped, 2 inch
capacity EMI-MEC auto lathe, but is still sitting on the floor, as its very
heavy, and cant decide if its to be sold or go to the scrappy
Bob>
Discussion Power Requirement of about 500 watts cityuav Power Systems 8 Jan 04, 2012 03:16 PM
Discussion power requirement sri Large Electric Helis 2 Dec 25, 2011 12:27 PM
Discussion GoPro electrical question polar8 Batteries and Chargers 6 Dec 03, 2011 05:16 PM
Help! Fw 190 power requirement? PeterH Scale Kit/Scratch Built 11 Nov 14, 2011 07:36 AM
Question General Electrical Glider Building Question -- Power Switch ? Kai@UCSB Electric Sailplanes 8 Jan 06, 2007 11:52 AM
