Old Feb 24, 2012, 08:48 AM
Jetro223 is offline
Find More Posts by Jetro223
Joined Jan 2006
Help!
HK Multicopter Control Board - motor doesn't spin - need help
Hi everyone,
I built a quadcopter and I have a problem with HK Multicopter control board - so I'm unable to fly or even test it :-(
I've connected all 4 motors to the board to the M1-M4 pins and also connected my RX. All ESCs initialize and do their standard pip pip... Now if I increase the throttle - one motor starts, then the second, then the third and nearly at full throttle the fourth.
At first I thought it could be a problem with the ESCs throttle range - but I think it isn't.
What have I done so far:
- calibrated the ESCs (yaw pot to zero, power, pip pip, power off, restore yaw pot) - OK
- tested the ESCs and motors directly on a RX - OK
- tried different firmwares - XCopter 4.7, XCopter 2.5
- tried with one BEC, two BEC, external BEC
- switched the cables for the motors - so for example motor 1 on pins for M4 and motor 4 on pins for M1 ==> now motor 1 is the last spinning up. So it seems that it's the control boards fault - the order of the motors starting is the same as the pins on the board...
Has anyone an idea what that could be?
Thank you!
Jetro223 is offline Find More Posts by Jetro223
Old Feb 24, 2012, 08:57 AM
mdjohnson is offline
Find More Posts by mdjohnson
Never left one up there yet...
mdjohnson's Avatar
Canada, BC, Campbell River
Joined Jun 2009
See post 1778
http://www.rcgroups.com/forums/showt...26492&page=119
Cheers
MJ
mdjohnson is offline Find More Posts by mdjohnson
Old Feb 24, 2012, 02:58 PM
Jetro223 is offline
Joined Jan 2006
Hi, thank you for your answer. Unfortunately I couldn't get it to work with just trimming. Now I've flashed the firmware "XXcontroller KR version by Minsoo Kim ***Latest Firmware***" from kkmulticopter.com and my motors spin up simultaneously
There's also another discussion I just found about this here => http://www.rcgroups.com/forums/showthread.php?t=1587021 <= maybe I'll give it another try later
Discussion Wow Hobbies Brushless System continualy beeps and doesn't spin up? GetterDragun Micro Helis 9 Feb 10, 2012 10:19 PM
Discussion How to trim the heli so it doesn't spin CADiver Micro Helis 0 Feb 06, 2012 06:53 PM
Help! My motor doesn't run right Please help! Alex Schauer Electric Motor Design and Construction 47 Dec 19, 2011 06:46 PM
Discussion HK SS Series 18-20A ESC + OrangeRx Futaba FASST - No beeps, motor doesn't move :( lpinho Power Systems 5 Aug 16, 2011 05:29 PM
Help! T3amp ESC Motor 1302 doesn't work Help P.M.S Scratchbuilt Indoor and Micro Models 3 Jul 25, 2011 07:45 PM
