Old Feb 24, 2012, 08:02 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
Help!
FrySky FLD-02 Telemetry -- Help programming alarms
Hello Everyone
I bought some moths ago (before winter) the FrSky FLD-02 Telemetry Display Screen for my FrySky module. I am having trouble programming the alarm tresholds and the manual is not really helpful :P
Does anyone knwos how to program these alarms? I am planning to use it in combination with the Thermal Scout
regards
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Feb 24, 2012, 08:58 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
You mean operating the display, or computing alarm values ?
There are guys in the Frsky threads who already did this, you can found there examples of everything.
renatoa is offline Find More Posts by renatoa
Old Feb 26, 2012, 02:38 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
Yeap the values and inputing them :P
I could nto find the proper thread, could you please share a link wiht me??
thanks in advance
EZ
Old Feb 26, 2012, 02:47 AM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
FrSky thread link.
Here you go EZ. Very good thread too!
http://www.rcgroups.com/forums/showthread.php?t=1176328
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Feb 26, 2012, 02:56 AM
renatoa is offline
Joined Sep 2007
Or this search, will led you to all posts related to Thermal Scout and Frsky in several 4-5 various threads:
http://www.rcgroups.com/forums/searc...0Scout%20frsky
Old Feb 26, 2012, 08:40 AM
hoh is offline
hoh
Find More Posts by hoh
hoh
Spandau, Berlin / Las Vegas,US
hoh's Avatar
Joined Dec 2010
Hi Guys,
I'm using D6FR receiver which already has Battery monitor Built-in and FLD-02 monitor, as the power I'm using 3S Lipo and BEC to power my receiver(5V). Now the questions are
1. What should I put on the A1 (FLD-02) as th Volt devider?
2. The number that shows up on the monitor fld-02. Is it the actual voltage ?
Regards
Andi
hoh is offline Find More Posts by hoh
Old Feb 26, 2012, 10:03 AM
renatoa is offline
Joined Sep 2007
1. you must put 4.
2. the left number is the receiver voltage, as provided by the BEC. The right number could be the pack voltage, if A2 is connected using an appropriate divisor to the propulsion pack.
Old Feb 26, 2012, 03:06 PM
hoh is offline
hoh
hoh
hoh's Avatar
Joined Dec 2010
Originally Posted by RENATOA View Post
1. you must put 4.
Thanks Renatoa, now regarding the A2. I have made some of your voltage sensors last week as described on this http://www.rcgroups.com/forums/showt...1#post16889744
I'm using 3 Lipos and BEC, and I tried to measure the voltage on that Lipos.
1. What number should I put on A2?
2. What will display on the Fld-02 (the right side) for my 3s Lipo?
Thanks a million
Andi
Old Feb 26, 2012, 03:20 PM
renatoa is offline
Joined Sep 2007
The link is broken.
I remember I posted somewhere a method to DIY a voltage sensor, but that post was for a D8R.
D6FR A2 is a complete different beast, and I don't have one handy to make some tests. I think for the D6FR the simplest method would be using a potentiometer, set A2 to 6 and fin tune from potentiometer to read the right lipo value, measured with a multimeter. As posted by Lindsay here:
http://www.rcgroups.com/forums/showp...postcount=2999
Old Feb 28, 2012, 03:07 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
@Renatoa: thanks for your input
I got the software to program the module if I suceceed I will make a mini how to.
In the mean while I would be glad if you guys can share with me the values you used to program your therman scouts eg. Alarm1= XXX RSII= YYYY to make a bit of a database for other to use
regards
EZ
Old Feb 28, 2012, 04:08 AM
renatoa is offline
Joined Sep 2007
RSII = YYYY ? what is this ?
If I rememeber well from other threads, they ended with an alarm in the 116-118 ballpark, fine tuning for your taste is mandatory.
Old Apr 10, 2014, 08:19 AM
speed100 is offline
Find More Posts by speed100
Canada, ON, Timmins
Joined Aug 2013
Is it possible to show the actual voltage of the LiPo instead of the voltage provided by BEC without external voltage sensor using the D8R-II Plus built in voltage sensor?
speed100 is offline Find More Posts by speed100
Old Apr 11, 2014, 12:41 AM
renatoa is offline
Joined Sep 2007
The hack inside receiver don't worth the trouble, much simpler to DIY an external sensor of the servo connector size !
Discussion alarms for 2nd battery and rssi yuvala4 Eagle Tree Systems 6 Jan 18, 2012 05:42 PM
Sold Lipo Alarms! 4 shipped a piece! CHEAPPPP! edu01jose Aircraft - Electric - Batteries & Chargers (FS/W) 9 Sep 14, 2011 04:47 PM
Discussion Frysky module install on futaba 8u ant? newelectro Radios 11 May 23, 2011 01:58 PM
Discussion Help-need lost plane alarms for 2.4 quadshot Slope 32 Nov 10, 2009 05:28 PM
New Product Lost model alarms, low voltage alarms and many more. Inflexo Parkflyers 0 Dec 22, 2008 07:23 AM
