Old Feb 24, 2012, 12:57 AM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
Build Log
build log peanut M5 Sparrowhawk.
walt mooney peanut scale miles M5 Sparrowhawk. looks about right for a 3inch prop. what i go so far. the wing was finished, but warped from the beginning. i am going to deviate from the plans a bit on the wing, never could use the 1/16 stringer for ant curved surface.
made out of 9.5 pound balsa.
covering is Esaki white.
nemoskull is offline Find More Posts by nemoskull
Old Feb 24, 2012, 03:20 AM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
A favorite. In fact I love all the Miles racing planes, but what kind of gear can you stick in there?
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Feb 24, 2012, 06:57 AM
AMARILLO1978 is offline
Find More Posts by AMARILLO1978
AMARILLO1978's Avatar
Argentina, Corrientes
Joined Jan 2009
nice start... I love mooney planes... iŽll be watching...
AMARILLO1978 is offline Find More Posts by AMARILLO1978
Old Feb 24, 2012, 11:54 AM
nemoskull's Avatar
Joined Sep 2009
dont really know. i dont have much at the moment. i could go RET, i got a p51 motor and 3020 ready to install. one could fit a ar6400 brick in there. i might just not install anything and store it or maybe sell it.
Old Feb 24, 2012, 02:13 PM
nemoskull's Avatar
Joined Sep 2009
fuse top....
started the fuse. i am making seperatable. (not sure if that is a word.) it will make accessing the innards much eaiser. planing on only RET for this one for sure. i just got in some tiny magnets from bidproduct, so i will be using those as hinges.
not sure how to make the front, i am guessing a balsa carved block will not covered with tissue very well.
EDIT:
going with a scale elevator, i figure this was made for passive control, free flight, and installing a servo will reduce the need for the over large elevator.
Old Feb 24, 2012, 07:55 PM
nemoskull's Avatar
Joined Sep 2009
small update. got more 9 lbs balsa! yay! and i killed some flys.
I hate flys (1 min 0 sec)
Old Feb 25, 2012, 01:39 AM
nemoskull's Avatar
Joined Sep 2009
finished most of the fuse. top half seperates. ising tiny mangets from bidproduct. will attach the lower magnets later. good nite.
Old Feb 25, 2012, 07:03 AM
SpleenRippa is offline
Find More Posts by SpleenRippa
Yes, right there.
SpleenRippa's Avatar
Comox, BC, CAN
Joined Jul 2003
This is awesome. Keep the updates coming
SpleenRippa is offline Find More Posts by SpleenRippa
Old Feb 25, 2012, 11:11 AM
nemoskull's Avatar
Joined Sep 2009
power plant.....
cant decide on the motor. i got a um p51 motor and gws 3020, or i got a 2gram bl motor that probly be better suited, with a gws 2510.
what you all say?
EDIT: more pics
got the rudder and elevator covered and assembeled
p.s. ahhh! time to clean my table again!
edit 2: started the wing. time to pause and rethink the L.E. probly put in some washout
Old Feb 26, 2012, 01:50 PM
nemoskull's Avatar
Joined Sep 2009
wing...
got the wing mostly done. magnetic attached. not sure of th AUw as of now.
Old Feb 27, 2012, 09:28 AM
Yellow Baron is offline
Find More Posts by Yellow Baron
Back in the game.
Yellow Baron's Avatar
3" from insanity, 2' from the computer ,Richford, Tioga county, Southern Tier, New York, U.S., North American Continent, Northern hemisphere, Earth, The Sol System, Milkyway Galaxy, The Universe, The Current Dimension, Your Selected Realm of Reality.
Joined Dec 2006
Very cool, I'm wondering what gear you are going to use? Also love the carbon LE.
Yellow Baron is offline Find More Posts by Yellow Baron
Old Feb 27, 2012, 02:16 PM
nemoskull's Avatar
Joined Sep 2009
thanks, the LE was bugigng me, i needed something strong, and balsa was not it.
i dont know about the gear. i have a bunch of as2000L servos, but i hate them. the only rx i have is an rx415, but i dont have enough connectors to retrofit the AS2000L. i might just solder then, but the weight is comming out close to 20 grams, i only have 17 of thrust with this motor.
i was hoping for full 4 ch, but cuz of weight i might go with 3. or i might try some actuators.......
EDIT:
i decide to sell her. i dont really have the gear i need for this, and dont want a flying pig.
started covering!
next question; to shrink or not to shrink?
Link RC kite build logs.. show your kite and link it to your build log davereap RC Paragliders and Kites 19 Mar 31, 2016 06:03 PM
Discussion Finally Got My Anderson M5 Race Kit. (Build Thread) ParacordPaul Motorcycles 76 Dec 02, 2011 03:15 PM
Discussion Bernard-3 Peanut build draganbt Free Flight 44 Aug 21, 2011 05:25 AM
Discussion Miles M5 Sparrowhawk vp46 Scale Kit/Scratch Built 30 Mar 08, 2009 10:15 PM
Scale Build of F9C-2 Sparrowhawk ZRS4 Scale Kit/Scratch Built 87 Aug 29, 2004 04:43 PM
