Old Feb 24, 2012, 12:37 AM
jwalker590 is offline
Find More Posts by jwalker590
Joined Sep 2010
Hk kk v2.1 help
Could someone please tell or preferably show me how to plug a kk board together for a tricopter. I'm having much difficulty . I've tried everything I can think of. Oh and I also can't get the receiver to bind with my dx8 when it's plugged into the kk board.
First time setting up a tricopter. I flashed it with tricopter v2.5 [m168] Minsoo Kim. Is this right?
Thanks!
jwalker590 is offline Find More Posts by jwalker590
Old Feb 24, 2012, 09:45 AM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
As far as I know most are using KKTricoptor1.6 for M168. Might get you a little more help. Your rx binding has nothing to do with the board other than board provides power. True spektrum rx or orange rx? Rx will dimmly light led but not bind if channel plugged in backwards. You may also have to setup complete new model again if binding got corrupted.
Thanks!
pug398 is offline Find More Posts by pug398
Old Feb 24, 2012, 01:40 PM
Joined Sep 2010
Its a real ar600-x. When plugging from kk board to receiver, i see people only using two male to male leads? Ive not fiqured this out yet either. Do you have a diagram for this?
Much thanks
Old Feb 24, 2012, 06:49 PM
Dave8888 is offline
Find More Posts by Dave8888
United States, AZ, Seligman
Joined Nov 2011
Much thanks
This is a picture off ebay. The one male lead is connected to 3 signal pins (where the white wires go) of the board and 3 signal pins on the receiver. The other male lead is connected normally and will supply power.
Dave8888 is offline Find More Posts by Dave8888
Old Feb 24, 2012, 07:20 PM
pug398 is offline
VA
Joined Nov 2009
Good pic. You only need one power and one ground wire. Thats made with one connector with the signal wire going to a channel. On the other connector all 3 wires go to a different channel. Cuts down on wires and weight.
Old Feb 25, 2012, 04:09 PM
Joined Sep 2010
Its really weird, motor one starts , then two and then motor 3 when i push the throttle. No matter what i do, the motors dont start together. Is this normal?
Old Feb 25, 2012, 05:58 PM
pug398 is offline
VA
Joined Nov 2009
Have you calibrated the throttle range of the esc so they all match? There is a built in utility for that in the kk firmware
;---- ESC Throttle range calibration. This outputs collective input to all motor outputs ---
;---- This mode is entered by turning yaw gain pot to zero and turning on the flight controller. LED will blink 2 times.
Turn on tx and move throttle to max. Turn yaw gain pot to 0. Turn on flight controller. When you hear two beeps move throttle to low and wait for long beep. Disconnect battery and return yaw pot to previous position. You can also calibrate each esc to the throttle channel of rx individually.
Old Mar 09, 2012, 06:09 AM
Joined Sep 2010
haha i did it individually but that didnt work. so i did it your way through the kk board and now it works all fine. thanks for the help.
Discussion Improved firmware for the KK multicopter, also the HK KK. kapteinkuk Multirotor Electronics 2965 Apr 05, 2016 09:08 AM
Rave HK KK V2 Quad board (and other recent KK boards) randall1959 Multirotor Electronics 2584 Aug 11, 2014 02:01 PM
Discussion Convert HK T6A V2 (Mode 2) to V1 (Mode 1) Beruang Radios 3 May 11, 2014 06:35 PM
Question Connect the ESC to the KK Board V2.1 (Atmega168PA) Flying Barry Multirotor Talk 3 Jan 24, 2012 01:03 PM
Discussion I want to buy HK T6A V2 Receiver for HK T6A V2 nuketown Radios 1 Nov 28, 2011 03:19 AM
